_______ ________ __
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -__| || | | || _|| _|
|_______|| __|_____|__|__||________||__| |____|
|__| W I R E L E S S F R E E D O M
Backfire (10.03.1, r29592) ------------------------
* 1/3 shot Kahlua In a shot glass, layer Kahlua
* 1/3 shot Bailey's on the bottom, then Bailey's,
* 1/3 shot Vodka then Vodka.
root@OpenWrt:~# cat /etc.d/setserial
cat: can't open '/etc.d/setserial': No such file or directory
root@OpenWrt:~# cat /etc/init.d/setserial
#!/bin/sh /etc/rc.common
# Copyright (C) 2006 OpenWrt.org
START=15
boot() {
/usr/sbin/setserial /dev/ttyS0 irq 3
/usr/bin/stty -F /dev/ttyS0 speed 9600 raw
/usr/sbin/ser2net -u &
root@OpenWrt:~# cat /etc/ser2net.conf
# This is an example configuration file for ser2net. It has the following
# format:
# <TCP port>:<state>:<timeout>:<device>:<options>
# TCP port
# Name or number of the TCP/IP port to accept con-
# nections from for this device. A port number may
# be of the form [host,]port, such as 127.0.0.1,2000
# or localhost,2000. If this is specified, it will
# only bind to the IP address specified. Otherwise
# it will bind to all the ports on the machine.
# state Either raw or rawlp or telnet or off. off disables
# the port from accepting connections. It can be
# turned on later from the control port. raw enables
# the port and transfers all data as-is between the
# port and the long. rawlp enables the port and
# transfers all input data to device, device is open
# without any termios setting. It allow to use
# /dev/lpX devices and printers connected to them.
# telnet enables the port and runs the telnet proto-
# col on the port to set up telnet parameters. This
# is most useful for using telnet.
# timeout
# The time (in seconds) before the port will be dis-
# connected if there is no activity on it. A zero
# value disables this function.
# device The name of the device to connect to. This
# must be in the form of /dev/<device>.
# options
# Sets operational parameters for the serial port.
# Options 300, 1200, 2400, 4800, 9600, 19200, 38400,
# 57600, 115200 set the various baud rates. EVEN,
# ODD, NONE set the parity. 1STOPBIT, 2STOPBITS set
# the number of stop bits. 7DATABITS, 8DATABITS set
# the number of data bits. [-]XONXOFF turns on (-
# off) XON/XOFF support. [-]RTSCTS turns on (- off)
# hardware flow control, [-]LOCAL turns off (- on)
# monitoring of the modem lines, and
# [-]HANGUP_WHEN_DONE turns on (- off) lowering the
# modem control lines when the connection is done.
# NOBREAK disables automatic setting of the break
# setting of the serial port.
# The "remctl" option allow remote control (ala RFC
# 2217) of serial-port configuration. A banner name
# may also be specified, that banner will be printed
# for the line. If no banner is given, then no
# banner is printed.
# The tw, tr, and tb options take a tracefile name (
# specified in TRACEFILE that will take all traced data.
# tw is data written to the device, tr is data read from
# the device, and tb is both.
# or...
# BANNER:<banner name>:banner
# This will create a banner, if the banner name is given in the
# options of a line, that banner will be printed. This takes the
# standard "C" \x characters (\r is carraige return, \n is newline,
# etc.). It also accepts \d, which prints the device name, \p,
# which prints the TCP port number, and \s which prints the serial
# parameters (eg 9600N81). Banners can span lines if the last
# character on a line is '\'. Note that you *must* use \r\n to
# start a new line.
# TRACEFILE:<name>:filename
# This specifies a filename to trace output into, as tw:/tmp/trace1.
# This takes a large number of escape sequences, see the man page
# for details on these options.
# Note that the same device can be listed multiple times under different
# ports, this allows the same serial port to have both telnet and raw
# protocols.
BANNER:banner1:Welcome to ser2net TCP port \p device \d\r\n\
second line \
third line\r\n
BANNER:banner2:this is ser2net TCP port \p device \d\r\n\
second line \
third line\r\n
BANNER:banner3:this is ser2net TCP port \p device \d serial parms \s\r\n
TRACEFILE:tw1:/tmp/tw-\p-\Y-\M-\D-\H:\i:\s.\U
TRACEFILE:tr1:/tmp/tr-\p-\Y-\M-\D-\H:\i:\s.\U
#1500:raw:3600:/dev/ttyS0:9600 NONE 1STOPBIT 8DATABITS -XONXOFF LOCAL -RTSCTS
2001:raw:600:/dev/ttyS0:9600 NONE 1STOPBIT 8DATABITS XONXOFF LOCAL -RTSCTS
#2002:raw:600:/dev/ttyS1:9600 NONE 1STOPBIT 8DATABITS XONXOFF LOCAL -RTSCTS
2003:raw:5:/dev/ttyS2:9600
2004:raw:5:/dev/ttyS3:115200
2005:raw:5:/dev/ttyS4:9600
2006:raw:5:/dev/ttyS5:9600
2007:raw:5:/dev/ttyS6:9600 tw=tw1 tr=tr1
3001:telnet:0:/dev/ttyS0:19200 remctl banner1
3011:telnet:3:/dev/ttyS0:19200 banner2
#3002:telnet:0:/dev/ttyS1:9600
3003:telnet:0:/dev/ttyS2:9600 banner3
3004:telnet:0:/dev/ttyS3:115200
3005:telnet:0:/dev/ttyS4:9600
3006:telnet:0:/dev/ttyS5:9600
3007:telnet:0:/dev/ttyS6:9600
5001:rawlp:10:/dev/lp0
root@OpenWrt:~#
START=15
boot() {
/usr/bin/stty -F /dev/ttyS0 raw speed 9600
/usr/bin/mjpg_streamer -i "input_uvc.so -d /dev/video0 -r 640x480 -f 20" -o "output_http.so -p 8080" &
/usr/bin/mjpg_streamer -i "input_uvc.so -d /dev/video1 -r 176x144 -f 25" -o "output_http.so -p 8090" &
# /usr/bin/mjpg_streamer -i "input_uvc.so -d /dev/video1 -y -r 176x144 -f 10 -q 30" -o "output_http.so -p 8090" &
root@OpenWrt:~# dmesg | grep tty
Kernel command line: rootfstype=squashfs,yaffs,jffs2 noinitrd console=ttyS0,1152 00 board=TL-WR741ND
serial8250.0: ttyS0 at MMIO 0x18020000 (irq = 11) is a 16550A
console [ttyS0] enabled, bootconsole disabled
cesar писал(а):I do not have the linix instaldo on my pc
I use windows xp
elmot писал(а):1) run ipconfig /all >ipconfig.log on your pc and post and post ipconfig.log here.
cesar писал(а):hello elmot
Today I did the firmware update
following step by step as the site
I have a page control robot
wanted to know if the serial output is already activated
another thing I like to comes Faso with external control such as Visual Basic 8
cesar писал(а):when I enable the wifi led flashing red and blue
cesar писал(а):min to use your program Car WiFi v0.1
what should I change here
