Приведите содержимое файла init, посмотрим что там вообще запускается.::sysinit:/etc_ro/rcS
ttyS1::respawn:/bin/sh
#!/bin/sh
mount -a
mkdir -p /var/run
cat /etc_ro/motd
# generate Dev Node
# Linux 2.6 uses udev instead of devfs, we have to create static dev node by myself
mounted=`mount | grep mdev | wc -l`
if [ $mounted -eq 0 ]; then
mount -t ramfs mdev /dev
mkdir /dev/pts
mount -t devpts devpts /dev/pts
mdev -s
fi
mknod /dev/spiS0 c 217 0
mknod /dev/i2cM0 c 218 0
mknod /dev/rdm0 c 254 0
mknod /dev/flash0 c 200 0
mknod /dev/swnat0 c 210 0
mknod /dev/hwnat0 c 220 0
mknod /dev/acl0 c 230 0
mknod /dev/ac0 c 240 0
mknod /dev/mtr0 c 250 0
mknod /dev/gpio c 252 0
mknod /dev/PCM c 233 0
mknod /dev/I2S c 234 0
echo "# <device regex> <uid>:<gid> <octal permissions> [<@|$|*> <command>]" > /etc/mdev.conf
echo "# The special characters have the meaning:" >> /etc/mdev.conf
echo "# @ Run after creating the device." >> /etc/mdev.conf
echo "# $ Run before removing the device." >> /etc/mdev.conf
echo "# * Run both after creating and before removing the device." >> /etc/mdev.conf
echo "sd[a-z][1-9] 0:0 0660 */sbin/automount.sh \$MDEV" >> /etc/mdev.conf
#enable usb hot-plug feature
echo "/sbin/mdev" > /proc/sys/kernel/hotplug
nvram_daemon &
internet.sh
#for telnet debugging
telnetd
#for syslogd
mkdir -p /var/log
