File main.hex:
loaded...
New Extended Linear Address Record [04] out of memory range
Current Memory starts at: 0x00000000, new Address is: 0x40000000
telnet_port 4444
gdb_port 3333
gdb_memory_map enable
gdb_flash_program enable
interface ft2232
ft2232_device_desc "Olimex OpenOCD JTAG TINY A"
ft2232_layout "olimex-jtag"
ft2232_vid_pid 0x15BA 0x0004
jtag_speed 0
jtag_nsrst_delay 200
jtag_ntrst_delay 200
reset_config srst_only srst_pulls_trst
jtag_device 4 0x1 0xf 0xe
daemon_startup reset
anness> <variant>
target arm7tdmi little run_and_init 0 arm7tdmi
target_script 0 reset sam7s_reset.script
working_area 0 0x00200000 0x4000 nobackup
flash bank at91sam7 0 0 0 0 0
mww 0xfffffd44 0x00008000 # disable watchdog
mww 0xfffffd08 0xa5000001 # enable user reset
mww 0xfffffc20 0x00000601 # CKGR_MOR : enable the main oscillator
sleep 10
mww 0xfffffc2c 0x00481c0e # CKGR_PLLR: 96.1097 MHz
sleep 10
mww 0xfffffc30 0x00000007 # PMC_MCKR : MCK = PLL / 2 ~= 48 MHz
sleep 10
mww 0xffffff60 0x003c0100 # MC_FMR: flash mode (FWS=1,FMCN=60)
sleep 100
flash protect 0 0 1 off
sleep 10
flash write_bank 0 memory.bin 0
sleep 100
Я им как отладчиком не пользуюсь...
Виталий писал(а):Я им как отладчиком не пользуюсь...
А чем пользуешься?
