Проблема с CodeVision и Протеусом
Сообщение slava » 17 май 2005, 17:44
Вот код:
This program was produced by the
CodeWizardAVR V1.24.6 Evaluation
Automatic Program Generator
© Copyright 1998-2005 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
e-mail:office@hpinfotech.com
Project :
Version :
Date    : 17.05.2005
Author  : Freeware, for evaluation and non-commercial use only
Company :
Comments:
Chip type           : ATmega128
Program type        : Application
Clock frequency     : 16,000000 MHz
Memory model        : Small
External SRAM size  : 0
Data Stack size     : 1024
#include <mega128.h>
#define RXB8 1
#define TXB8 0
#define UPE 2
#define OVR 3
#define FE 4
#define UDRE 5
#define RXC 7
#define FRAMING_ERROR (1<<FE)
#define PARITY_ERROR (1<<UPE)
#define DATA_OVERRUN (1<<OVR)
#define DATA_REGISTER_EMPTY (1<<UDRE)
#define RX_COMPLETE (1<<RXC)
// Get a character from the USART1 Receiver
#pragma used+
char getchar1(void)
char status,data;
while (1)
     while (((status=UCSR1A) & RX_COMPLETE)==0);
     data=UDR1;
     if ((status & (FRAMING_ERROR | PARITY_ERROR | DATA_OVERRUN))==0)
        return data;
#pragma used-
// Write a character to the USART1 Transmitter
#pragma used+
void putchar1(char c)
while ((UCSR1A & DATA_REGISTER_EMPTY)==0);
UDR1=c;
#pragma used-
void main(void)
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Port E initialization
PORTE=0x00;
DDRE=0x00;
// Port F initialization
PORTF=0x00;
DDRF=0x00;
// Port G initialization
// Func4=In Func3=In Func2=In Func1=In Func0=In
// State4=T State3=T State2=T State1=T State0=T
PORTG=0x00;
DDRG=0x00;
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0 output: Disconnected
ASSR=0x00;
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// OC1C output: Discon.
// Noise Canceler: Off
// Compare C Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
OCR1CH=0x00;
OCR1CL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// Timer/Counter 3 initialization
// Clock value: Timer 3 Stopped
// OC3A output: Discon.
// OC3B output: Discon.
// OC3C output: Discon.
// Timer 3 Overflow Interrupt: Off
TCCR3A=0x00;
TCCR3B=0x00;
TCNT3H=0x00;
TCNT3L=0x00;
ICR3H=0x00;
ICR3L=0x00;
OCR3AH=0x00;
OCR3AL=0x00;
OCR3BH=0x00;
OCR3BL=0x00;
OCR3CH=0x00;
OCR3CL=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
// INT3: Off
// INT4: Off
// INT5: Off
// INT6: Off
// INT7: Off
EICRA=0x00;
EICRB=0x00;
EIMSK=0x00;
TIMSK=0x00;
ETIMSK=0x00;
// USART1 initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART1 Receiver: On
// USART1 Transmitter: On
// USART1 Mode: Asynchronous
// USART1 Baud rate: 56000
UCSR1A=0x00;
UCSR1B=0x18;
UCSR1C=0x06;
UBRR1H=0x00;
UBRR1L=0x11;
// Analog Comparator: Off
ACSR=0x80;
SFIOR=0x00;
while (1)
     // Place your code here
Компилируется великолепно, но при попытке исполнения в протеусе - говорит такую лабуду:
SIMULATION LOG
Design:   C:\hobby\test128.DSN
Doc. no.: <NONE>
Revision: <NONE>
Author:   <NONE>
Created:  25/04/05
Modified: 17/05/05
Compiling source files...
Build completed OK.
Compiling netlist...
Linking netlist...
Partition analysis...
Simulating partition 1 [A7D34524]...
Animation started sucessfully...
PROSPICE Release 6.7 SP0 (C) Labcenter Electronics 1993-2005.
SPICE Kernel Version 3f5. (C) Berkeley University ERL.
Reading netlist...
Reading SPICE models...
Loading library 'ANALOGD.SML'
Loading library 'APEX.SML'
Loading library 'BURRBROWN.SML'
Loading library 'ELANTEC.SML'
Loading library 'FAIRCHLD.SML'
Loading library 'INTERSIL.SML'
Loading library 'LINTEC.SML'
Loading library 'NATOA.SML'
Loading library 'SUPERTEX.SML'
Loading library 'TECCOR.SML'
Loading library 'TEX101.SML'
Loading library 'TEX301.SML'
Loading library 'TEX3_1.SML'
Loading library 'TEX401.SML'
Loading library 'TEX5_1.SML'
Loading library 'VALVES.SML'
Loading library 'ZETEX.SML'
Building circuit...
Added GEARTH resistor for net #00008.
Added GEARTH resistor for net #00009.
Added GEARTH resistor for net #00010.
Added GEARTH resistor for net #00060.
Added GEARTH resistor for net #00061.
Added GEARTH resistor for net #00062.
Instantiating SPICE models...
[U1] AVR model release 6.7 SP0.
[U1] Loaded 4096 bytes of persistent EEPROM data.
[U1] Loading HEX file 'sourceC\7.hex'.
[U1] Read total of 426 bytes from file 'sourceC\7.hex'.
LOOP LIMIT: TIME = 0.00129125. CALLBACK = 00000001, STATE =???
DSIM ERROR: DSIM: race condition detected at time 0.00129125.
[DSIM] RUN Error.
Real Time Simulation FAILED.
он, что - не может симулировать УСАРТ1 ?
slava
Сообщение casper_r » 17 май 2005, 21:59
я еще до УСАРТа не дошел..
но возник интересный вопрос, как в ПРОТЕУСе посмотреть содержимое переменной?
в WatchWindow можно выбрать только адресс, но как узнать адрес этой переменной, если я компилил из CodeVisiona ?
я не волшебник, я даже на него не учусь
casper_r
Сообщение -= Александр =- » 18 май 2005, 00:35
Ну, переменные кладутся в память в порядке создания - отсчитай нужное смещение и будет тебе адрес! А те что автоматические - попадают в стек - их уже не поймаешь...
Сообщение Tracer » 18 май 2005, 15:47
Посмотри на свой код в AVR Studio  в режиме ассемблера там увидиш строки на С и соответствующий им код ассемблера там и ищи адреса своих переменных.
Но для этого НЕПЛОХОБЫ разбираться в ассемблере.
Tracer
Сообщение casper_r » 18 май 2005, 16:32
мда.. мороки много
легче подключить в протеусе LCD и выводить туда переменную :))
casper_r
Сообщение Tracer » 18 май 2005, 23:31
ИЛИ в Виртуальный терминал но надо будет свой
fprintf(UART,"%x %x %x %x",a,b,c,d); написать
Tracer
