#define MIN_SOFTWARE_ENDSTOPS True
то опускаться ниже нуля не будет, т.к. будет ограниченно программно в прошивке, сменил на false заработало, теперь могу примерять сопло по высоте к столику
#define ADVANCE
#if ENABLED(ADVANCE)
#define EXTRUDER_ADVANCE_K .0
#define D_FILAMENT 1.75
#endif
#define LIN_ADVANCE
#if ENABLED(LIN_ADVANCE)
#define LIN_ADVANCE_K 120 // по дефолту 75
#define LIN_ADVANCE_E_D_RATIO 0 // The calculated ratio (or 0) according to the formula W * H / ((D / 2) ^ 2 * PI)
// Example: 0.4 * 0.2 / ((1.75 / 2) ^ 2 * PI) = 0.033260135
#endif
echo: Free Memory: 3770 PlannerBufferBytes: 1232
echo:V41 stored settings retrieved (498 bytes; crc 3077)
echo: G21 ; Units in mm
echo: M149 C ; Units in Celsius
echo:Filament settings: Disabled
echo: M200 D1.75
echo: M200 D0
echo:Steps per unit:
echo: M92 X100.00 Y100.00 Z100.00 E100.00
echo:Maximum feedrates (units/s):
echo: M203 X200.00 Y200.00 Z200.00 E25.00
echo:Maximum Acceleration (units/s2):
echo: M201 X2500 Y2500 Z2500 E2500
echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
echo: M204 P1500.00 R1500.00 T1500.00
echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_ms> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk>
echo: M205 S0.00 T0.00 B20000 X20.00 Y20.00 Z20.00 E5.00
echo:Endstop adjustment:
echo: M666 X0.00 Y0.00 Z0.00
echo:Delta settings: L<diagonal_rod> R<radius> H<height> S<segments_per_s> B<calibration radius> XYZ<tower angle corrections>
echo: M665 L218.00 R101.00 H251.00 S160.00 B73.00 X0.00 Y0.00 Z0.00
echo:Material heatup parameters:
echo: M145 S0 H195 B60 F0
M145 S1 H240 B100 F0
echo:PID settings:
echo: M301 P24.77 I1.84 D83.61
echo:Z-Probe Offset (mm):
echo: M851 Z0.10
echo:SD init fail
G33 Auto Calibrate
Checking... AC
.Height:251.00
Calibration OK std dev:211.008
.Height:39.99
Save with M500 and/or copy to Configuration.h
ok
#define Z_CLEARANCE_DEPLOY_PROBE 0
#define Z_CLEARANCE_BETWEEN_PROBES 3
Если хоть один из параметров выше не 0, то сопло после выравнивания будет
подниматься на эту величину + Z_PROBE_OFFSET_FROM_EXTRUDER
Z_PROBE_OFFSET_FROM_EXTRUDER то же самое что и Offset в слайсере регулирует положение сопла при печати относительно нулевого уровня после выравнивания.
Также может влиять параметр
#define Z_MIN_POS 0 // При положительных значениях каретка опускается на это значение, при отрицательных задирается на это значение вверх
#define Z_MIN_ENDSTOP_INVERTING true
#define Z_MIN_PROBE_ENDSTOP_INVERTING true
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 15
