Attiny2313:
прошитые fuse:
spien
sut1,sut0
cksel0, cksel1, sksel3
кварц 16 Мгц
ATmega16:
прошитые fuse:
bootsz0, bootsz1
ccort
spien
sut1,sut0
кварц 16 Мгц
прога:
$regfile = "m16def.dat"
$crystal = 16000000
$lib "mcsbyte.lbx"
Config Rc5 = Pinb.4
Config Pinb.3 = Output
Config Portd.0 = Output
Speaker Alias Portd.0
Dim Address As Byte
Dim Command As Byte
Enable Interrupts
$hwstack = 32
$swstack = 10
$framesize = 40
Do
Getrc5(address , Command)
If Address = 0 Then
Command = Command And &B01111111
End If
If Command = 12 Then
Reset Portb.3
End If
If Command = 1 Then
Set Portb.3
Else
Reset Portb.3
End If
If Command = 2 Then
Set Portb.3
Wait 1
Reset Portb.3
Wait 1
Set Portb.3
Wait 1
Reset Portb.3
End If
If Command = 3 Then
Set Portb.3
End If
Loop
