SPI LCD Nokia 3310 84x48 200р.
Обсуждение и примеры готовых и самосборных компонент для построения роботов.
Сообщение EdGull » 24 окт 2007, 11:55
Взято у доброго буржуинского парня http://www.microsyl.com/nokialcd/nokialcd.html
I found this LCD make for cellular phone Nokia 3310 by browsing the web at http://www.jelu.se. There is many interesting things about this LCD: low price, easy to interface via SPI port, can support graphic and text and consume low current. The only thing that I did is writing code who gives you friendly functions to support this LCD. The last version of the library only send the bytes who had changed since the last update. It's considerably reduce the refresh time who can be very important in a batteries powered system.
Functions Features
LcdInit(void)
LcdClear(void)
LcdUpdate(void)
LcdGotoXY(byte x, byte y)
LcdChr(LcdFontSize size, byte ch)
LcdStr(LcdFontSize size, byte *dataPtr)
LcdPixel(byte x, byte y, LcdPixelMode mode)
LcdLine(byte x1, byte y1, byte x2, byte y2)
  Description  :  Header file for Nokia 84x48 graphic LCD driver.
  Author       :  2003-03-08 - Louis Frigon.
  History      :  2003-03-08 - First release.
#ifndef _NOKIALCD_H_
#define _NOKIALCD_H_
                                  General purpose constants
#define NULL                       0
#define FALSE                      0
#define TRUE                       1
#define LCD_X_RES                  84
#define LCD_Y_RES                  48
//  Mega8 port B pinout for LCD.
#define LCD_DC_PIN                 0x01  //  PB0
#define LCD_CE_PIN                 0x04  //  PB2
#define SPI_MOSI_PIN               0x08  //  PB3
#define LCD_RST_PIN                0x10  //  PB4
#define SPI_CLK_PIN                0x20  //  PB5
#define LCD_CACHE_SIZE             ((LCD_X_RES * LCD_Y_RES) / 8)
                                       Type definitions
typedef char                       bool;
typedef unsigned char              byte;
typedef unsigned int               word;
typedef enum
    LCD_CMD  = 0,
    LCD_DATA = 1
} LcdCmdData;
typedef enum
    PIXEL_OFF =  0,
    PIXEL_ON  =  1,
    PIXEL_XOR =  2
} LcdPixelMode;
typedef enum
    FONT_1X = 1,
    FONT_2X = 2
} LcdFontSize;
                                 Public function prototypes
void LcdInit       ( void );
void LcdClear      ( void );
void LcdUpdate     ( void );
void LcdGotoXY     ( byte x, byte y );
void LcdChr        ( LcdFontSize size, byte ch );
void LcdStr        ( LcdFontSize size, byte *dataPtr );
void LcdPixel      ( byte x, byte y, LcdPixelMode mode );
void LcdLine       ( byte x1, byte y1, byte x2, byte y2, LcdPixelMode mode );
#endif  //  _NOKIALCD_H_
                                         End of file.
  Description  :  This is a driver for the Nokia 84x48 graphic LCD.
  Author       :  2003-03-08 - Sylvain Bissonnette
  History      :  2003-02-08 - First release (v0.1) derived from Sylvain Bissonnette code base.
                  2003-03-09 - v0.2, Louis Frigon: 2x fonts support.
                  2003-03-20 - v0.3: Serialization optimized,
#include <macros.h>
#include <iom8v.h>
//#include <stdio.h>
#include "NokiaLCD.h"
#define LCD_FIRMWARE_VERSION       0.3
                                Private function prototypes
//  Function prototypes are mandatory otherwise the compiler generates unreliable code.
static void LcdSend    ( byte data, LcdCmdData cd );
static void Delay      ( void );
                                     Character generator
             This table defines the standard ASCII characters in a 5x7 dot format.
static const byte FontLookup [][5] =
    { 0x00, 0x00, 0x00, 0x00, 0x00 },  // sp
    { 0x00, 0x00, 0x2f, 0x00, 0x00 },   // !
    { 0x00, 0x07, 0x00, 0x07, 0x00 },   // "
    { 0x14, 0x7f, 0x14, 0x7f, 0x14 },   // #
    { 0x24, 0x2a, 0x7f, 0x2a, 0x12 },   // $
    { 0xc4, 0xc8, 0x10, 0x26, 0x46 },   // %
    { 0x36, 0x49, 0x55, 0x22, 0x50 },   // &
    { 0x00, 0x05, 0x03, 0x00, 0x00 },   // '
    { 0x00, 0x1c, 0x22, 0x41, 0x00 },   // (
    { 0x00, 0x41, 0x22, 0x1c, 0x00 },   // )
    { 0x14, 0x08, 0x3E, 0x08, 0x14 },   // *
    { 0x08, 0x08, 0x3E, 0x08, 0x08 },   // +
    { 0x00, 0x00, 0x50, 0x30, 0x00 },   // ,
    { 0x10, 0x10, 0x10, 0x10, 0x10 },   // -
    { 0x00, 0x60, 0x60, 0x00, 0x00 },   // .
    { 0x20, 0x10, 0x08, 0x04, 0x02 },   // /
    { 0x3E, 0x51, 0x49, 0x45, 0x3E },   // 0
    { 0x00, 0x42, 0x7F, 0x40, 0x00 },   // 1
    { 0x42, 0x61, 0x51, 0x49, 0x46 },   // 2
    { 0x21, 0x41, 0x45, 0x4B, 0x31 },   // 3
    { 0x18, 0x14, 0x12, 0x7F, 0x10 },   // 4
    { 0x27, 0x45, 0x45, 0x45, 0x39 },   // 5
    { 0x3C, 0x4A, 0x49, 0x49, 0x30 },   // 6
    { 0x01, 0x71, 0x09, 0x05, 0x03 },   // 7
    { 0x36, 0x49, 0x49, 0x49, 0x36 },   // 8
    { 0x06, 0x49, 0x49, 0x29, 0x1E },   // 9
    { 0x00, 0x36, 0x36, 0x00, 0x00 },   // :
    { 0x00, 0x56, 0x36, 0x00, 0x00 },   // ;
    { 0x08, 0x14, 0x22, 0x41, 0x00 },   // <
    { 0x14, 0x14, 0x14, 0x14, 0x14 },   // =
    { 0x00, 0x41, 0x22, 0x14, 0x08 },   // >
    { 0x02, 0x01, 0x51, 0x09, 0x06 },   // ?
    { 0x32, 0x49, 0x59, 0x51, 0x3E },   // @
    { 0x7E, 0x11, 0x11, 0x11, 0x7E },   // A
    { 0x7F, 0x49, 0x49, 0x49, 0x36 },   // B
    { 0x3E, 0x41, 0x41, 0x41, 0x22 },   // C
    { 0x7F, 0x41, 0x41, 0x22, 0x1C },   // D
    { 0x7F, 0x49, 0x49, 0x49, 0x41 },   // E
    { 0x7F, 0x09, 0x09, 0x09, 0x01 },   // F
    { 0x3E, 0x41, 0x49, 0x49, 0x7A },   // G
    { 0x7F, 0x08, 0x08, 0x08, 0x7F },   // H
    { 0x00, 0x41, 0x7F, 0x41, 0x00 },   // I
    { 0x20, 0x40, 0x41, 0x3F, 0x01 },   // J
    { 0x7F, 0x08, 0x14, 0x22, 0x41 },   // K
    { 0x7F, 0x40, 0x40, 0x40, 0x40 },   // L
    { 0x7F, 0x02, 0x0C, 0x02, 0x7F },   // M
    { 0x7F, 0x04, 0x08, 0x10, 0x7F },   // N
    { 0x3E, 0x41, 0x41, 0x41, 0x3E },   // O
    { 0x7F, 0x09, 0x09, 0x09, 0x06 },   // P
    { 0x3E, 0x41, 0x51, 0x21, 0x5E },   // Q
    { 0x7F, 0x09, 0x19, 0x29, 0x46 },   // R
    { 0x46, 0x49, 0x49, 0x49, 0x31 },   // S
    { 0x01, 0x01, 0x7F, 0x01, 0x01 },   // T
    { 0x3F, 0x40, 0x40, 0x40, 0x3F },   // U
    { 0x1F, 0x20, 0x40, 0x20, 0x1F },   // V
    { 0x3F, 0x40, 0x38, 0x40, 0x3F },   // W
    { 0x63, 0x14, 0x08, 0x14, 0x63 },   // X
    { 0x07, 0x08, 0x70, 0x08, 0x07 },   // Y
    { 0x61, 0x51, 0x49, 0x45, 0x43 },   // Z
    { 0x00, 0x7F, 0x41, 0x41, 0x00 },   // [
    { 0x55, 0x2A, 0x55, 0x2A, 0x55 },   // 55
    { 0x00, 0x41, 0x41, 0x7F, 0x00 },   // ]
    { 0x04, 0x02, 0x01, 0x02, 0x04 },   // ^
    { 0x40, 0x40, 0x40, 0x40, 0x40 },   // _
    { 0x00, 0x01, 0x02, 0x04, 0x00 },   // '
    { 0x20, 0x54, 0x54, 0x54, 0x78 },   // a
    { 0x7F, 0x48, 0x44, 0x44, 0x38 },   // b
    { 0x38, 0x44, 0x44, 0x44, 0x20 },   // c
    { 0x38, 0x44, 0x44, 0x48, 0x7F },   // d
    { 0x38, 0x54, 0x54, 0x54, 0x18 },   // e
    { 0x08, 0x7E, 0x09, 0x01, 0x02 },   // f
    { 0x0C, 0x52, 0x52, 0x52, 0x3E },   // g
    { 0x7F, 0x08, 0x04, 0x04, 0x78 },   // h
    { 0x00, 0x44, 0x7D, 0x40, 0x00 },   // i
    { 0x20, 0x40, 0x44, 0x3D, 0x00 },   // j
    { 0x7F, 0x10, 0x28, 0x44, 0x00 },   // k
    { 0x00, 0x41, 0x7F, 0x40, 0x00 },   // l
    { 0x7C, 0x04, 0x18, 0x04, 0x78 },   // m
    { 0x7C, 0x08, 0x04, 0x04, 0x78 },   // n
    { 0x38, 0x44, 0x44, 0x44, 0x38 },   // o
    { 0x7C, 0x14, 0x14, 0x14, 0x08 },   // p
    { 0x08, 0x14, 0x14, 0x18, 0x7C },   // q
    { 0x7C, 0x08, 0x04, 0x04, 0x08 },   // r
    { 0x48, 0x54, 0x54, 0x54, 0x20 },   // s
    { 0x04, 0x3F, 0x44, 0x40, 0x20 },   // t
    { 0x3C, 0x40, 0x40, 0x20, 0x7C },   // u
    { 0x1C, 0x20, 0x40, 0x20, 0x1C },   // v
    { 0x3C, 0x40, 0x30, 0x40, 0x3C },   // w
    { 0x44, 0x28, 0x10, 0x28, 0x44 },   // x
    { 0x0C, 0x50, 0x50, 0x50, 0x3C },   // y
    { 0x44, 0x64, 0x54, 0x4C, 0x44 }    // z
                                      Global Variables
static byte  LcdCache [ LCD_CACHE_SIZE ];
static int   LcdCacheIdx;
static int   LoWaterMark;
static int   HiWaterMark;
static bool  UpdateLcd;
  Description  :  Performs MCU SPI & LCD controller initialization.
  Argument(s)  :  None.
  Return value :  None.
    //  Pull-up on reset pin.
    PORTB |= LCD_RST_PIN;
    //  Set output bits on port B.
    DDRB |= LCD_RST_PIN | LCD_DC_PIN | LCD_CE_PIN | SPI_MOSI_PIN | SPI_CLK_PIN;
    Delay();
    //  Toggle display reset pin.
    PORTB &= ~LCD_RST_PIN;
    Delay();
    //  Enable SPI port: No interrupt, MSBit first, Master mode, CPOL->0, CPHA->0, Clk/4
    SPCR = 0x50;
    //  Disable LCD controller
    PORTB |= LCD_CE_PIN;
    LcdSend( 0x21, LCD_CMD );  // LCD Extended Commands.
    LcdSend( 0xC8, LCD_CMD );  // Set LCD Vop (Contrast).
    LcdSend( 0x06, LCD_CMD );  // Set Temp coefficent.
    LcdSend( 0x13, LCD_CMD );  // LCD bias mode 1:48.
    LcdSend( 0x20, LCD_CMD );  // LCD Standard Commands, Horizontal addressing mode.
    LcdSend( 0x0C, LCD_CMD );  // LCD in normal mode.
    //  Reset watermark pointers.
    LoWaterMark = LCD_CACHE_SIZE;
    HiWaterMark = 0;
    LcdClear();
    LcdUpdate();
  Description  :  Set display contrast.
  Argument(s)  :  contrast -> Contrast value from 0x00 to 0x7F.
  Notes        :  No change visible at ambient temperature.
void LcdContrast ( byte contrast )
    LcdSend( 0x80 | contrast, LCD_CMD );
    //  LCD Standard Commands, horizontal addressing mode.
  Description  :  Clears the display. LcdUpdate must be called next.
  Argument(s)  :  None.
    int i;
    for ( i = 0; i < LCD_CACHE_SIZE; i++ )
        LcdCache[i] = 0x00;
    LoWaterMark = 0;
    HiWaterMark = LCD_CACHE_SIZE - 1;
    UpdateLcd = TRUE;
  Description  :  Sets cursor location to xy location corresponding to basic font size.
  Argument(s)  :  x, y -> Coordinate for new cursor position. Range: 1,1 .. 14,6
    LcdCacheIdx = (x - 1) * 6 + (y - 1) * 84;
  Description  :  Displays a character at current cursor location and increment cursor location.
  Argument(s)  :  size -> Font size. See enum.
                  ch   -> Character to write.
    byte i, c;
    byte b1, b2;
    int  tmpIdx;
    if ( LcdCacheIdx < LoWaterMark )
        //  Update low marker.
        LoWaterMark = LcdCacheIdx;
    if ( (ch < 0x20) || (ch > 0x7b) )
        //  Convert to a printable character.
        ch = 92;
    if ( size == FONT_1X )
        for ( i = 0; i < 5; i++ )
            LcdCache[LcdCacheIdx++] = FontLookup[ch - 32][i] << 1;
    else if ( size == FONT_2X )
        tmpIdx = LcdCacheIdx - 84;
        if ( tmpIdx < LoWaterMark )
            LoWaterMark = tmpIdx;
        if ( tmpIdx < 0 ) return;
            c = FontLookup[ch - 32][i] << 1;
            b1 =  (c & 0x01) * 3;
            b1 |= (c & 0x02) * 6;
            b1 |= (c & 0x04) * 12;
            b1 |= (c & 0x08) * 24;
            c >>= 4;
            b2 =  (c & 0x01) * 3;
            b2 |= (c & 0x02) * 6;
            b2 |= (c & 0x04) * 12;
            b2 |= (c & 0x08) * 24;
            LcdCache[tmpIdx++] = b1;
            LcdCache[tmpIdx + 82] = b2;
            LcdCache[tmpIdx + 83] = b2;
        //  Update x cursor position.
        LcdCacheIdx += 11;
    if ( LcdCacheIdx > HiWaterMark )
        //  Update high marker.
        HiWaterMark = LcdCacheIdx;
    //  Horizontal gap between characters.
    LcdCache[LcdCacheIdx++] = 0x00;
                  according to font size.
                  dataPtr -> Pointer to null terminated ASCII string to display.
    while ( *dataPtr )
        LcdChr( size, *dataPtr++ );
  Description  :  Displays a pixel at given absolute (x, y) location.
  Argument(s)  :  x, y -> Absolute pixel coordinates
                  mode -> Off, On or Xor. See enum.
    word  index;
    byte  offset;
    byte  data;
    if ( x > LCD_X_RES ) return;
    if ( y > LCD_Y_RES ) return;
    index = ((y / 8) * 84) + x;
    offset  = y - ((y / 8) * 8);
    data = LcdCache[index];
    if ( mode == PIXEL_OFF )
        data &= (~(0x01 << offset));
    else if ( mode == PIXEL_ON )
        data |= (0x01 << offset);
    else if ( mode  == PIXEL_XOR )
        data ^= (0x01 << offset);
    LcdCache[index] = data;
    if ( index < LoWaterMark )
        LoWaterMark = index;
    if ( index > HiWaterMark )
        HiWaterMark = index;
  Description  :  Draws a line between two points on the display.
  Argument(s)  :  x1, y1 -> Absolute pixel coordinates for line origin.
                  x2, y2 -> Absolute pixel coordinates for line end.
    int dx, dy, stepx, stepy, fraction;
    dy = y2 - y1;
    dx = x2 - x1;
    if ( dy < 0 )
        dy    = -dy;
        stepy = -1;
    else
        stepy = 1;
    if ( dx < 0 )
        dx    = -dx;
        stepx = -1;
    else
        stepx = 1;
    dx <<= 1;
    dy <<= 1;
    LcdPixel( x1, y1, mode );
    if ( dx > dy )
        fraction = dy - (dx >> 1);
        while ( x1 != x2 )
            if ( fraction >= 0 )
                y1 += stepy;
                fraction -= dx;
            x1 += stepx;
            fraction += dy;
    else
        fraction = dx - (dy >> 1);
        while ( y1 != y2 )
                x1 += stepx;
                fraction -= dy;
            y1 += stepy;
            fraction += dx;
    UpdateLcd = TRUE;
  Description  :  Copies the LCD cache into the device RAM.
  Argument(s)  :  None.
    int i;
    if ( LoWaterMark < 0 )
        LoWaterMark = 0;
    else if ( LoWaterMark >= LCD_CACHE_SIZE )
        LoWaterMark = LCD_CACHE_SIZE - 1;
    if ( HiWaterMark < 0 )
        HiWaterMark = 0;
    else if ( HiWaterMark >= LCD_CACHE_SIZE )
    //  Set base address according to LoWaterMark.
    LcdSend( 0x80 | (LoWaterMark % LCD_X_RES), LCD_CMD );
    LcdSend( 0x40 | (LoWaterMark / LCD_X_RES), LCD_CMD );
    //  Serialize the video buffer.
    for ( i = LoWaterMark; i <= HiWaterMark; i++ )
        LcdSend( LcdCache[i], LCD_DATA );
    HiWaterMark = 0;
    UpdateLcd = FALSE;
  Description  :  Sends data to display controller.
  Argument(s)  :  data -> Data to be sent
                  cd   -> Command or data (see/use enum)
    //  Enable display controller (active low).
    PORTB &= ~LCD_CE_PIN;
    if ( cd == LCD_DATA )
        PORTB |= LCD_DC_PIN;
    else
        PORTB &= ~LCD_DC_PIN;
    //  Send data to display controller.
    SPDR = data;
    //  Wait until Tx register empty.
    while ( (SPSR & 0x80) != 0x80 );
    //  Disable display controller.
  Description  :  Uncalibrated delay for LCD init routine.
  Argument(s)  :  None.
    int i;
    for ( i = -32000; i < 32000; i++ );
                                         End of file.
чуток подправил, поставил тег CODE а то читать такую портянку... :) <V>
Re: SPI LCD Nokia 3310 84x48 200р.
Сообщение XMaster » 25 окт 2007, 11:18
За митинском или горбушке можно купить за 50 рэ в магазе запчастей. Дисплей очень вкусный - ток потребления меньше 1 mA. (при 3 В)
XMaster
Сообщение EdGull » 18 янв 2009, 21:58
на васике по немецки
http://www.mkprojekt.de/index.php/content/view/2/2/
3310.rar
Добавлено спустя 2 минуты 37 секунд:
на русском, псевдоСи
http://cyber-avr.narod.ru/LCD_NOKIA_3410_3310.htm
Добавлено спустя 19 минут 19 секунд:
вот исчо на васике
http://www.avrfreaks.net/index.php?modu ... showinfo=1
0.94 KB 04-09-07 11:10 3310example.bas
3.08 KB 04-09-07 11:05 3310init.bas
1.90 KB 04-09-07 11:10 3310bmp1.bas
7.14 KB 04-09-07 11:08 3310end.bas
6.83 KB 03-11-07 20:31 Character_generator.xls
79.43 KB 03-25-07 22:08 BMP_to_Hex.xls
78.25 KB 03-11-07 19:31 pcd8544-Nokia3310-display.pdf
37.53 KB 03-11-07 01:50 Back.JPG
37.02 KB 03-11-07 01:50 Front.JPG
0.32 KB 03-25-07 22:01 Mr_Walker.bmp
3310LibraryV2.zip
Сообщение algol1 » 18 янв 2009, 22:04
На самом деле индикатор стоит 50р. 8) вместе с подложкой и коннектором :)))
http://shop.siriust.ru/product_info.php/products_id/382
Добавлено спустя 2 минуты 13 секунд:
Интереснее использовать от Siemens S65 он конечно стоит дороже 50р (150р - по моему :) ), но зато он цветной и значительно больше :) Информации по нему достаточно чтобы его запустить, по крайней мере у нас получилось, значит и у всех получится :)
монтаж печатных плат http://www.mplata.ru
algol1
ФИО: Головлев Александр Александрович
Сообщение EdGull » 18 янв 2009, 22:05
1. я в курсе, ты посмотри на дату топика :wink:
я сейчас как раз там и буду их закупать
2. у них много чего написано, а по факту очень много привезти даже под заказ не могут...
Сообщение algol1 » 18 янв 2009, 22:09
Ну да, когда с ними в одном городе - все как-то проще... Позвонил, узнал, послал гонца.
А из Тольятти :(
Последний раз редактировалось EdGull 18 янв 2009, 22:17, всего редактировалось 1 раз.
Причина: Излишнее цитирование!
algol1
Сообщение EdGull » 18 янв 2009, 22:19
не боись Сириус у нас в Самаре есть... это 70км. всего :wink:
Сообщение algol1 » 18 янв 2009, 22:27
Цепкие лапы партии и туда проникли :)) ну и славно :)
algol1
Сообщение EdGull » 18 янв 2009, 22:30
заказал им 20шт. если привезут, то будет стандарт для миниботов.
Сообщение algol1 » 18 янв 2009, 22:37
правильно. а самое главное - недорого. :)
algol1
Сообщение Master » 19 янв 2009, 01:12
EdGull будь человеком учи С, а?
Сообщение EdGull » 19 янв 2009, 09:27
эт с какого еще перепуга?
1. меня васик более чем устраивает
2. на сях я тоже выкладываю, смотри например первый пост.
Сообщение $ilent » 19 янв 2009, 14:59
Тока там бяда есть, если отправить три строки:
Скажем.
LcdGotoXY(1,1);
LcdStr(1, "Be-Be-Be");
LcdGotoXY(1,2);
LcdGotoXY(1,3);
LcdUpdate();
То выйдет не предсказуемй результат. Точнее предсказуемый - мусор.
А две нормально переваривает.
$ilent
Вернуться в Готовые модули
