Copyright = Mcs Electronics
Www = Http ://Www.mcselec.com
Email = Avr@mcselec.com
Comment = KS0108 Graphic Display Library for 128 * 64
Libversion = 1.00
Date = 1 Okt 2003
Statement = No Source Code From The Library May Be Distributed In Any Form
Statement = Of Course This Does Not Apply For The Compiled Code When You Have A Bascom -avr License
History= special thanks to Bob Gardner who got me a display
[_GLCD]
$EXTERNAL _LPMBYTE
_set_display:
  Clr r20
  rcall _SelChip
* Cbi _glcd_portm , _glcd_reset ; Reset
* Sbi _glcd_portm , _glcd_rd
* Cbi _glcd_portm, _glcd_enable
  Ldi r24,100                      ; reset 100 mS
  Clr R25
* Call _waitms
  ser r25
* Out _glcd_port_ddr , R25          ; Make Output Port
* Sbi _glcd_portm , _glcd_reset ; Reset High
_set_display1:
   Rcall _gRead_Status
   sbrc r1,4
   rjmp _set_display1
   rcall _Init_display
   ser r20
   rcall _SelChip
_Init_display:
  ldi r24,$3F
  rcall _gwrite_cmd
  ldi r24,$C0
  rcall _gwrite_cmd
  ldi r24,$40
  rcall _gwrite_cmd
  ldi r24,$B8
  rcall _gwrite_cmd
ret
_selChip:
  Cpi r20,64                                         ; check column
  Brlo _selChip2                                     ; smaller then 64
_selChip1:
* sbi _glcd_portm , _glcd_ce                         ; select the SECOND chip
* cbi _glcd_portm , _glcd_ce2
  subi r20,64
  ret
_selChip2:                                            ; do not confuse labelname with CHIP
* sbi _glcd_portm , _glcd_ce2
* cbi _glcd_portm , _glcd_ce                         ; select the FIRST chip
ret
_gwrite_cmd:
* Cbi _glcd_portm , _glcd_cd            ; Command
Rjmp _Gwrite_DataMisc                   ; same code
_gwrite_data:
* Sbi _glcd_portm , _glcd_cd            ; Data
_gwrite_datamisc:
  @genus(5)
* Out _glcd_port , R24                  ; Write
* Cbi _glcd_portm , _glcd_rd            ; Write Low
* Sbi _glcd_portm , _glcd_enable        ; Enable Chip
  @genus(1)
* Cbi _glcd_portm , _glcd_enable            ; Disable Chip
 ;rcall _gRead_Status
Ret
_gRead_Status:
* Cbi _glcd_portm , _glcd_cd            ; Status
  Rcall _gRead_data1
  sbrc r1,7
  rjmp _gRead_Status
Ret
_gRead_data:
_gRead_data1:
  clr r25
* Out _glcd_port_ddr, R25               ; read direction
  Ser r25
* Out _glcd_port , R25                  ; read pull ups high
  @genus(5)
* Sbi _glcd_portm , _glcd_rd            ; read High
  @genus(2)
* In r1, _glcd_port_in                  ; get byte
* Out _glcd_port_ddr, R25               ; write direction
ret
;there is no difference between clear text and clear graphics!
_clear_graph:
_clear_text:
  clr r20
  rcall _selchip
  rcall _clear_graph3
  ser r20
  rcall _selchip
_clear_graph3:
  Ldi r16, 0  ; 8 pages
_clear_graph2:
  Ldi r24,64
  Rcall _gwrite_cmd        ; address 0
  Ldi r24,&B10111000       ; page 0
  Add r24,r16
  Rcall _gwrite_cmd
  Ldi r17,64
_clear_graph1:
  CLr r24
  rcall _GWrite_data                    ; write 0
  Dec r17
  Brne _clear_graph1                    ; write 64 times
  Inc r16
  Cpi r16,8
  Brne _clear_graph2
ret
;character in r24
;in order to draw multiple fontsizes the fontdata stores the
;number of bytes and the number of rows.
_gwrite_lcdchar:
$EXTERNAL _LPMBYTE, _MUL8, _GLOCATE
  Push r30                               ; save registers
  Push r31
* lds r21,{___lcdrow}                    ; the row Y
  push r21                               ; save it
* lds r7,{___lcdcol}
* Lds r30 ,{___fonttable}                ; start of font data
* Lds r31 ,{___fonttable +1}
*#IF _ROMSIZE>65536
*  Clr r0                                ; temp reg
*  lsl R30                               ; shift to left
*  Rol r31                               ; rotate left with carry
*  Rol R0                                ; MSB of address is in R0 LS bit
*  Out RAMPZ, R0                         ; set the page
*#ENDIF
  call _lpmbyte                          ; get Y bytes  1 for example
  mov r18,r0                             ; save Y
  call _lpmbyte                          ; get X bytes , 8 for  an 8*8 font
  mov r19,r0                             ; save X
  call _lpmbyte                          ; get blocksize
  mov r16,r0                             ; in accu
  adiw r30,1                             ; adjust for words
  subi r24,32                            ; chars start at 32 (space)
  mov r20,r24
  call _mul8                             ; get offset
  Add r30,r20                            ; add to start of font data
  Adc r31,r21
_gwrite_lcdchar_rows:
 sts {___lcdcol},r7                     ; restore column
  mov r23,r19                            ; x bytes (8)
_gwrite_lcdchar1:
  lds r20,{___lcdcol}
  lds r21,{___lcdrow}
  rcall _Glocate
  call _lpmbyte                          ; get byte
  mov r24,r0
 lds r21,{___LCDrev}                    ; reverse display?
  tst r21
  breq _gwrite_lcdchar3
  com r24                                ; not 0 so complement
_gwrite_lcdchar3:
 rcall _GWrite_data                     ; write char data
 lds r21,{___lcdcol}                    ; increase column
 inc r21
 sts {___lcdcol},r21                    ; save column
 dec r23                                ; dec bytes dones
 brne _gwrite_lcdchar1                  ; not ready
*lds r21,{___lcdrow}                    ; inc row
 inc r21
* sts {___lcdrow},r21
  dec r18                                ; dec rows
  brne _gwrite_lcdchar_rows              ; for all rows
  pop r21                                ; get original row back
* sts {___lcdrow},r21                    ; restore
  Pop R31
  Pop R30
ret
[END]
[_GLOCATE]
; called with R20 X/column  R21 row/Y
_glocate:
  Dec r20                          ; adjust
  Dec r21                          ; adjust
_setcol:
  rcall _selChip
  ldi r24,&B10111000
  add r24,r21                      ; add X
  rcall _GWrite_cmd                ; page address
  Ldi r24,64
  Add r24,R20                      ; add Y
  rjmp _GWrite_cmd
[END]
[_GPIXEL]
$EXTERNAL _DIV8 ,  _GLOCATE , _ADJUST_PIN
; set or reset a single pixel
; X=R20 , Y=R21 , R25 is on/off
_gpixel:
  Push r0
  Push r1
  Push r2
  Push r3
  Push r16
  Push r25
    Push r20
    Mov r16,r21                      ; row
    Ldi R20 , 8                      ; 8 Bits In Byte
    call _Div8                       ; r16 contains proper Y/row address now
    Mov r0, r24                      ; save remainder
    Pop r20                          ; get X back
  Mov r21,r16                      ; y data location
  mov r2,r20                       ; save for later
  mov r3,r21
  rcall _setcol                    ; use the code from locate
  rcall _gread_data                ; return data in r1
  rcall _gread_data                ; return data in r1  DO NOT REMOVE !!!
  mov r20,r2
  mov r21,r3
  Mov r24,r0                       ; remainder
  call _Adjust_pin                 ;
  Pop r16  ;param r25
  tst r16
  breq _gpixel_clear
  or r1,r24
  rjmp _gpixel_set
_gpixel_clear:
  and r1,r25
_gpixel_set:
  mov r24,r1
  rcall _GWrite_data               ; write data
  Pop r16
  Pop r3
  Pop r2
  Pop r1
  Pop r0
ret
[END]
[_getbytefromrom_eprom]
$EXTERNAL _READEEPROM, _LPMBYTE
; get a byte from code ROM or from EEPROM
;you could write code to get the data from an external EEPROM
_getbytefromrom:
  Tst R23                          ; is it 0 ?
  Breq _GetByteFromROM1            ; yes get from flash
  Clr R26                          ; point to R0
  Clr R27
  jmp _ReadEEPROM1                ; get data in r0
_getbytefromrom1:
  jmp _LpmByte                    ; returns data in r0
[END]
[_showpicture]
$EXTERNAL _DIV8 , _MUL8 , _GETBYTEFROMROM_EPROM , _GLOCATE
; RLE encoded. When the data after the byte is AA, it means it is a repeating
; sequence and the byte after it hold the number of repeats
; AB, AC , AF,AA, EE means show AB,AC and AF EE times
; needs more code but needs less picture data!
; show a picture with ShowPic x,y , label
; y+2 holds X, y+1 holds Y , y+0 holds EPROM/ROM flag, Z points to picture data
; The calling code uses for example
; clr r20
; clr r21
; st -y,r20      this way it will be referred to with  y+4
; st -y,r21                   and                      y+3
; ldi zl,low(plaatje * 2)        to point to picture data
; ldi zh,high(plaatje * 2)
; in the SED data is stored column after column with 8 rows of data
_showpicture:
 CLR R1                           ; repeats
 CLR R2                           ; char to repeat
 clr r3                           ; temp register
 ld r23,y+                        ; 255 means get from EEPROM, 0 means get from flash
 Call _getbytefromrom             ; Get Height Of Picture In Pixels
 Mov r16,r0                       ;
 Ldi r20,8
 Call _Div8                       ; divide by 8
 St -y,r16                        ; y+2  number of rows to do
 Call _getbytefromrom             ; Get Width Of Picture In Pixels
 st -y,r0                         ; number of cols into  y+1
 st -y,r0                         ; number of cols into  y+0
 ld r16,y+3                       ; get Y pos
 Ldi R20 , 8
 Call _div8                       ; Correct
 st y+3,r16                       ; save row
_showpicture1:
 ld r20,y+4                       ; get X
mov r15,r20
 ld r21,y+3                       ; get Y
 Rcall _setcol                    ; set address
_showpicture2:
; *** New RLE encoding routine ***
  cp r1,r3                        ; is repeats 0 ?
  brne _ShowPicture8              ; no
  Call _getbytefromrom            ; Get Next Char
  mov r2,r0                       ; save char
  mov r24,r0
  cpi r24,&HAA                    ; test for repeat char must always be shown
  breq _ShowPicture9              ; we need to show AA
  Call _getbytefromrom            ; Is It Rle print
  mov r24,r0
  cpi r24,&HAA                    ; is it a RLE encoded char?
  breq _ShowPicture10             ; yes
  sbiw R30,1                      ; no readjust pointer to graphic data
  rjmp _ShowPicture11             ; show it
_showpicture9:
  adiw r30,1  ; skip 0
  rjmp _ShowPicture11
_showpicture8:
  ;we are repeating
  dec r1                          ; adjust repeat counter
  breq _showpicture2
_showpicture10:
  Call _getbytefromrom            ; Get Number Of Repeats
  Mov r24,r0
  Tst r24                         ; is it zero?
  Brne _showpicture15             ; no a real sequenc
  Sbiw r30,2                      ; adjust pointer
  Rjmp _showpicture11             ; skip somebytes
_showpicture15:
  mov r1,r0                       ; save number of repeats
_showpicture11:
  mov r24,r2
; *** end of RLE code ***
* lds r25,{___LCDrev}             ; reverse display?
  tst r25
  breq _showpicture12
  com r24
_showpicture12:
  push r24
  mov r20,r15
  ldd r21,y+3
  pop r24
  inc r15
  rcall _Gwrite_Data
  ld r24,y+1                      ; get column counter
  dec r24
  st y+1,r24                      ; save col counter
  brne _ShowPicture2              ; for all columns
  ld r24,y+3                      ; next page
  inc r24
  st y+3,r24
  ld r24,y+0                      ; get num of cols
  st y+1,r24                      ; save for the new row
  ld r24,y+2                      ; get row counter
  dec r24
  st y+2,r24
  brne _showpicture1              ; for all rows
  adiw r28,5                      ; adjust soft stack
  Ret
[END]
