может порт сгоред и тихо молчит об этом?
This program was produced by the
CodeWizardAVR V1.24.7 Evaluation
Automatic Program Generator
© Copyright 1998-2005 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
e-mail:office@hpinfotech.com
Project :
Version :
Date : 15.02.2008
Author : Freeware, for evaluation and non-commercial use only
Company :
Comments:
Chip type : ATmega16
Program type : Application
Clock frequency : 4,000000 MHz
Memory model : Small
External SRAM size : 0
Data Stack size : 256
#include <mega16.h>
void main(void)
// Port A initialization
// State7=T State6=P State5=P State4=P State3=P State2=P State1=P State0=P
PORTA=0x7F;
DDRA=0x00;
// Port B initialization
// Func7=In Func6=In Func5=In Func4=In Func3=Out Func2=Out Func1=Out Func0=Out
// State7=T State6=P State5=P State4=P State3=0 State2=1 State1=0 State0=1
PORTB=0x75;
DDRB=0x0F;
// Port C initialization
// State7=P State6=P State5=P State4=P State3=P State2=P State1=P State0=P
PORTC=0xFF;
DDRC=0x00;
// Port D initialization
PORTD=0xFF;
DDRD=0x00;
// Clock source: System Clock
// Mode: Normal top=FFh
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Timer 1 Overflow Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// Analog Comparator: Off
ACSR=0x80;
SFIOR=0x00;
while (1)
while (PINB.7){PORTB.0=0;};
while (1)
PORTB.0 = PINB.7;
