Форт-система
Re: Форт-система
Сообщение VANO22 » 21 апр 2014, 05:29
напиши в личку свой работающий номер плиз, это Иван
VANO22
Re: Форт-система
Сообщение chu » 22 сен 2014, 13:06
АЦП
\ chu 13:59 17.04.2013
\     22:57 17.04.2013
marker =adc=
: adc-start     ADCSRA    ADCSRA_ADSC over c@ or swap c! ;
: adc-complete? ADCSRA c@ ADCSRA_ADSC and  0= ;
: adc-data?     ADCSRA c@ ADCSRA_ADIF and     ;
: adc-end       ADCSRA    ADCSRA_ADIF over c@ or swap c! ;
\ adc turn on
: adc+
                           \    sound_sensor pin_pullup_off    \ input & low
     %01100000  ADMUX c!   \ REFS=01, ADLAR=1, MUX=00000
   [ ADCSRA_ADEN           \ ADC on
     ADCSRA_ADPS or        \ 16MHz/128=125KHz
   ] literal
     ADCSRA c!
\ turn off
: adc-
     ADCSRA
     ADCSRA_ADEN invert
     over c@ and swap c!
\ adc init
\  $20  constant ADLAR
: ad<left   ADMUX  ADMUX_ADLAR over c@ or swap c! ;
: ad>right  ADMUX dup c@  ADMUX_ADLAR invert and swap c! ;
\ select analog channel
: adc! ( n --- )
    ADMUX_MUX        and    ADMUX c@
    ADMUX_MUX invert and or ADMUX c!
\ read adc result
: adc@ ADC c@ ADC 1+ c@ 8 lshift + ;  ( --- un )
\ get ad convertion
: !adc@ adc-start begin adc-complete? until adc@ ;
: adc-tst begin !adc@ .x cr pause 500 ms key? until key drop ;
для коллекции
Добавлено спустя 26 минут 15 секунд:
\ ADC info
\ chu 1:23 19.04.2013
marker =adc-info=
: ?adc.
        ver bl emit ." AD Converter" cr
        ADMUX c@
        ." *******" cr
        ." (ADMUX) ADC Multiplexer Selection Register = "  dup .x cr
        dup ADMUX_REFS and dup ." Reference Selection Bits = " .x cr
        6 rshift
        case
           &0 of ." AREF, Internal Vref turned off "  endof
           &1 of ." AVCC with external capacitor at AREF pin " endof
           &2 of ." Reserved "  endof
           &3 of
." Internal 2.56V Voltage Reference with external capacitor at AREF pin "
             endof
        endcase cr
        ." ADLAR = "
        dup ADMUX_ADLAR and if
        ."  left adjust"   else
        ." right adjust"   then cr
        ." Analog Channel and Gain Selection Bits" cr
        ADMUX_MUX and dup
        case
           &0 &8  range of ." Single Ended Input - A" .x endof
           &9 &30 range of
." Differential Inputs, see p224 datasheet"   drop endof
              &30       of ." 1.22V (Vbg)"          drop endof
              &31       of ." 0V (GND)"             drop endof
        endcase cr
        ." ********" cr
        ADCSRA c@
        ." (ADCSRA) ADC Control and Status Register A = " dup .x cr
        ." ADC is turned "
        dup ADCSRA_ADEN  and if ." ON" else ." OFF" then cr
        ." AD Convertion is "
        dup ADCSRA_ADSC  and if
        ." in progress"    else
        ." complete"       then cr
        dup ADCSRA_ADATE and if
        ." triggered"      else
        ." single convertion" then cr
        dup ADCSRA_ADIF  and if
." ADC conversion completes and the Data Registers are updated" then cr
        ." ADC Interrupt "
        dup ADCSRA_ADIE  and if
        ." enabled"        else
        ." disabled"       then cr
        ." ADC Prescaler Select Bits = "
        ADCSRA_ADPS and dup .x ." ,  "
        ." ADC clocks = "
        f_cpu  &1000  um/mod swap drop
        swap
        case
        0 &2 range of &2   endof
          &2       of &4   endof
          &3       of &8   endof
          &4       of &16  endof
          &5       of &32  endof
          &6       of &64  endof
          &7       of &128 endof
        endcase /  base @ swap decimal . base ! ." KHz" cr
chu
прог. языки: Forth
Re: Форт-система
Сообщение chu » 23 дек 2014, 07:30
Release 5.6 is out and it is by far the biggest change in amforth ever.
It is the first version that runs on two different controller types:
AVR Atmegas and the TI MSP430 (Launchpad G2553).
Enjoy
Matthias
chu
прог. языки: Forth
Re: Форт-система
Сообщение chu » 23 янв 2016, 10:54
ilya73 любезно предоставил код для 3.2" TFT LCD 65K color 400x240 with the touch screen and SD card socket.
Graphics и fonts основаны на работах американца Craig A. Lindley для SSD1289 65K Color LCD Controller .
Добавлено спустя 17 минут 41 секунду:
Начинаем осваивать Mecrisp-Stellaris.
tft-lcd+touch.zip
chu
прог. языки: Forth
Re: Форт-система
Сообщение KPG » 16 авг 2018, 13:07
Тема больше не развивается?
Никого не заинтересовала? :)
KPG
прог. языки: Форт, С
Re: Форт-система
Сообщение setar » 16 авг 2018, 13:32
а в чем прикол ?
сейчас есть гораздо более интересные векторы приложения для обучения.
Например GoLang, который впитал в себя лучшее из C , Python , java , лишен их недостатков
и к тому же компилируемый и мультипоточный из коробки.
Синтаксис Go на порядок более читаемый и понятный интуитивно
Re: Форт-система
Сообщение KPG » 16 авг 2018, 13:56
setar писал(а):а в чем прикол ?
"Прикол" Форт языка в его "аморфности" и возможности "мимикрировать" под хотелки пользователя и максимальной портабельности как системы так и кода.
Каждый может найти в его подходе свой смысл.
Кто то нашёл такой свой смысл и создал, например, Factor язык программирования или, например, 8th
P.S. Литература по Форт языку
Чтабельность языка - это субъективный фактор отображаемый в субкультуре его пользователей. :)
KPG
Re: Форт-система
Сообщение setar » 16 авг 2018, 14:29
Этот фактор влияет прежде всего на количество ошибок, прежде всего логических
Re: Форт-система
Сообщение KPG » 16 авг 2018, 14:53
setar писал(а):Этот фактор влияет прежде всего на количество ошибок, прежде всего логических
Любая система программирования приводит к тем или иным ошибкам (тем более логическим не связанными с используемым языком)
язык лишь и практика его использования может подсказать те или иные "устоявшиеся" схемы и приёмы работы с ним минимизирующие тот или иной вид ошибок.
тем не менее это не служит общим критерием не использования программирования вообще. :)
А уровень "контроля" инструментальн(ых/ыми) средст(в/вами) можно выбирать самостоятельно.
Предположу ещё, что количество ошибок возрастает при освоении нового инструментария и из-за непонимания диапазона его возможностей
и отсутствия необходимой практики.
Например, гипотетически, язык общения роботов с ИИ не обязательно должен наследовать существующие схемы языков программирования в силу каких то отсутствующих ограничений в "разуме" робота. :)
P.S. Проекты с Factor языком, как и с Форт в достаточной мере для ознакомления с ними присутствуют и на Github.
Для примера, например, авторский софт для ПК написан на Форт, а для STM32 на С в теме Лазерная установка для засветки фоторезиста от AlphaCrow
при этом для ПК его размер составил чуть более 100Кб и софт показал свою надёжность.
Бои Grobots ведутся на Форт подобом языке да и Форт так или иначе можно встретить много где.
Для любознательных Рускоязычный форум пользователей Форт (Forth) языка
KPG
Re: Форт-система
Сообщение setar » 16 авг 2018, 15:47
Да кто же спорит, асемблер тоже много где встречается.
От этого от не становится более читаемым.
Лично я не горю желанием изучать язык если при первом взгляде на текст программы я не понимаю что в ней написано.
:) вероятно это моя личная фича, но предположу что так у 90% пользователей.
На мой взгляд выбрать для изучения Форт сегодня может только человек которому досталось "тяжелое наследство" которое нужно обслуживать
Re: Форт-система
Сообщение KPG » 16 авг 2018, 15:55
setar писал(а):Да кто же спорит, асемблер тоже много где встречается.
Думаю Форт выбирают те, кому с ним удалось познакомится в той степени чтобы его понять и использовать. :)
Увы, этот момент затронул, в большей степени людей, прочитавших о нём книжки 90-х годов, а дальше их понимание и возможность следовать его путём в разных аспектах. Люди из нового поколения тоже приходят к Форт, но уже не известно каким путём.
Ассембер и Форт трудно сравнивать т.к. ниша использования и возможности очень разные.
P.S. Для промышленного использования Форт предъявляет достаточно высокий уровень его понимания и контроля и маркетологи его не пропустят в продакшен,в отличии от задач исследовательского плана.
По Форт есть и такой небольшой рускоязычный подфорум на airbase
Про "проблему" читабельности языка, мнение было приведено выше, если бы он массово рассматривался в учебных заведениях, то понимание его текста было лучше.
Для того кто может использовать Форт - это очень удобный инструментарий, хотя и не лишённый каких то субъективных "несуразностей"
Мне он, например, позволяет экспериментировать и с такими темами в частном порядке. :)
Нечитабельность языка не привела бы к появлению, например, Win32Forth и такого ресурса
Думаю мало смысла изучать данное направление в текущих массовых реалиях создания ПО. Можно не заработать себе на "хлеб" этим.
Forth на Hackday
KPG
Re: Форт-система
Сообщение Eruman » 30 сен 2018, 18:27
"А не спеши ты Форт хоронить!
А у него еще есть дела..."
(почти как в песне)
Недавно попалась на вид плата Pololu Maestro Servo
Угадайте, какой скрипт используют? :)
https://www.pololu.com/docs/pdf/0J40/maestro.pdf
Соединяй и здравствуй.
Eruman
Re: Форт-система
Сообщение chu » 02 окт 2018, 11:05
setar писал(а):Лично я не горю желанием изучать язык если при первом взгляде на текст программы я не понимаю что в ней написано.
Абсолютно с Вами согласен. Очевидно же.
// Called 8 times per bit period
// Phase locked loop tries to synchronise with the transmitter so that bit
// transitions occur at about the time vw_rx_pll_ramp is 0;
// Then the average is computed over each bit period to deduce the bit value
void vw_pll()
    // Integrate each sample
    if (vw_rx_sample)
   vw_rx_integrator++;
    if (vw_rx_sample != vw_rx_last_sample)
   // Transition, advance if ramp > 80, retard if < 80
   vw_rx_pll_ramp += ((vw_rx_pll_ramp < VW_RAMP_TRANSITION)
            ? VW_RAMP_INC_RETARD
            : VW_RAMP_INC_ADVANCE);
   vw_rx_last_sample = vw_rx_sample;
    else
   // No transition
   // Advance ramp by standard 20 (== 160/8 samples)
   vw_rx_pll_ramp += VW_RAMP_INC;
    if (vw_rx_pll_ramp >= VW_RX_RAMP_LEN)
   // Add this to the 12th bit of vw_rx_bits, LSB first
   // The last 12 bits are kept
   vw_rx_bits >>= 1;
   // Check the integrator to see how many samples in this cycle were high.
   // If < 5 out of 8, then its declared a 0 bit, else a 1;
   if (vw_rx_integrator >= 5)
       vw_rx_bits |= 0x800;
   vw_rx_pll_ramp -= VW_RX_RAMP_LEN;
   vw_rx_integrator = 0; // Clear the integral for the next cycle
   if (vw_rx_active)
       // We have the start symbol and now we are collecting message bits,
       // 6 per symbol, each which has to be decoded to 4 bits
       if (++vw_rx_bit_count >= 12)
      // Have 12 bits of encoded message == 1 byte encoded
      // Decode as 2 lots of 6 bits into 2 lots of 4 bits
      // The 6 lsbits are the high nybble
      uint8_t this_byte =
          (vw_symbol_6to4(vw_rx_bits & 0x3f)) << 4
          | vw_symbol_6to4(vw_rx_bits >> 6);
      // The first decoded byte is the byte count of the following message
      // the count includes the byte count and the 2 trailing FCS bytes
      // REVISIT: may also include the ACK flag at 0x40
      if (vw_rx_len == 0)
          // The first byte is the byte count
          // Check it for sensibility. It cant be less than 4, since it
          // includes the bytes count itself and the 2 byte FCS
          vw_rx_count = this_byte;
          if (vw_rx_count < 4 || vw_rx_count > VW_MAX_MESSAGE_LEN)
         // Stupid message length, drop the whole thing
         vw_rx_active = false;
         vw_rx_bad++;
                        return;
      vw_rx_buf[vw_rx_len++] = this_byte;
      if (vw_rx_len >= vw_rx_count)
          // Got all the bytes now
          vw_rx_good++;
          vw_rx_done = true; // Better come get it before the next one starts
      vw_rx_bit_count = 0;
   // Not in a message, see if we have a start symbol
   else if (vw_rx_bits == 0xb38)
       // Have start symbol, start collecting message
       vw_rx_active = true;
       vw_rx_len = 0;
       vw_rx_done = false; // Too bad if you missed the last message
\ Called 8 times per bit period
\ Phase locked loop tries to synchronise with the transmitter so that bit
\ transitions occur at about the time vw_rx_pll_ramp is 0;
\ Then the average is computed over each bit period to deduce the bit value
  : vw_pll
            SAMPLE  ?TRANSITION
       LAST-SAMPLE? if  GET-BIT
         RX-ACTIVE? if
           WHOLE-BYTE?  if
             GET-BYTE   IS-COUNT? if  vw_rx_count !
                        RX-COUNT-GOOD? 0= if exit then
                                  else
             PUT-BYTE  ?ALL-BYTES then
       RESET-BIT-COUNT  then
                  else
    ?START-SYMBOL then  then
Virtual Wire
chu
прог. языки: Forth
Re: Форт-система
Сообщение KPG » 31 окт 2022, 12:03
STABLE an extreme small an fast FORTH-VM
arithmetic
+ ( a b--a+b) addition
- ( a b--a-b) subtraction
* ( a b--a*b) multiply
/ ( a b--a/b) division
% ( a b--a%b) modulo (division reminder)
_ ( n-- -n) negate
bit manipulation
& ( a b--a&b) 32 bits and
| ( a b--a|b) 32 bits or
~ ( n -- n') not, all bits inversed (0=>1 1=>0)
stack
# ( a--a a) duplicate top of stack
\ ( a b--a) drop top of stack
$ ( a b--b a) swap top of stack
@ ( a b--a b a) (over) copy next of stack on top
register
x ( --) select register x (x: a..z)
; ( --value) fetch from selected register
: ( value--) store into selected register
? ( --value) selected register contains an address. Fetch value from there
! ( value--) selected register contains an address. Store value there.
+ ( --) immediately after register, increment content by 1
- ( --) immediately after register, decrement content by 1
functions
{X ( --) start function definition for function X (A..Z)
} ( --) end of function definition
X ( --) call function X (A..Z)
I/O
. ( value--) display value as decimal number on stdout
, ( value--) send value to terminal, 27 is ESC, 10 is newline, etc.
^ ( --key) read key from terminal, don't wait for newline.
" ( --) read string until next " put it on stdout
0..9 ( --value) scan decimal number until non digit. to push two values
on stack separete those by space (4711 3333)
to enter negative numbers call _ (negate) after the number
0..9.0 ( --value) to enter float numbers digits must contain one . (only
available if float module is active, see 0`)
conditions
< ( a b--f) true (-1) if b is < a, false (0) otherwise
> ( a b--f) true (-1) if b is > a, false (0) otherwise
= ( a b--f) true (-1) if a is queal to b, flase (0) otherwise
( ( f--) if f is true, execute content until ), if false
skip code until )
[ ( f--f) begin while loop only if f is true. keep flag on stack
if f is false, skip code until ]
] ( f--) repeat the loop if f is true. If f is false, continue
with code after ]
extensions (expermiental)
` ( n--) call extension function n
0 ... switch to floating point mode
+ - * / . _ < >
1 ... switch back to interger mode
2 ... dbg, function dbg() to set breakpoint for debugging
3 ... switch traceing on (IP, TOKEN, SP, STACK) (not in stable_fast)
4 ... switch traceing off. Tracing int file trace
5 ... < = > without dropping their 2nd operand (NOS). This
is the behavior of Santors original virtual engine.
6 ... mstime, time in milliseconds, for timing
7 ... ( n--) edit block number n
8 ... ( n--) load block number n. Data segment remains. So this
is a kind of shared memory. Registers could be used as arguments.
After leaving the application and 0 is on TOS, STABLE will be
terminated. A value not equal 0 on TOS will load this block.
If the block is not valid, the command block will be loaded
Use block 0 as an index for all your block numbers
9 ... ( n 9--) copy block n (1000 cells) into memory begining of 1000.
write back the old content before. At exit write back current
data block. STABLE is starting with block 0 loaded.
10 ... trace only current state (ip, rp, sp, ..) on stdout
11 ... quit VM ( n--) n is exit code to os
12 ... ( --n) push current data block number on stack
13 ... ( --) copy 1000 cells from address 1000 to 2000
14 ... ( --) copy 1000 cells from address 2000 to 1000
P.S. . Вопросы автора проекта
Похожий по некоторым идеям топик uf \ micro forth \
Добавлено спустя 35 минут 50 секунд:
До сих пор на рынке нет "массовки" MISC контроллеров/процессоров.
После распада CCCP в Минском Интеграле осталась линейка Дофин процессоров (K1881BE1T (IN16C) - последний? в линейке), а в России есть и свой сделанный "процессор" в "MISC" исполнении TF-16 (К1894 номенклатура 5-я приёмка) Дизайн-центр «Проектирование интегральных микроэлектронных систем» в МИЭТ (ДЦ ПМС) с презентацией разработок
Возможно в "нашем" космосе, к примеру, используют RTX2010
по получаемым результатам к затратам MISC вполне годная архитектура.
MISC против RISC против CISC
Philip J. Koopman, Jr. "Стековые компьютеры, новая волна" (1989)
MuP21
MISC (компьютер с минимальным набором команд, Minimal Instruction Set Computer) — архитектура для проектирования процессора, которая отличается наилучшей эффективностью и простотой в сравнении с CISC и RISC. Может содержать в себе блок RISC, обрабатывающий в себе от 10 базовых команд (+, —, /, *, if, else & etc), из которых формируются более сложные операции над значениями, методом ветвления полученных результатов в ПЗУ. С точки зрения быстродействия, время выполнения инструкции, скорость записи и передачи данных в память, сократилось бы в разы, так как не нужно было бы ожидать, пока заполнится и очистится конвейер, а выполнять всё «потоково» без задержек.
Причиной, по которой данная архитектура не стала популярной в компьютерных технологиях – сложность написания программ под различные процессоры. Ведь все нюансы по подбору методов вычисления и оптимизаций возлагались на плечи программистов. К тому же, с повышением сложности выполняемых задач, требовалось более сложное ПО, что тормозило бы развитие микропроцессорного рынка. Поэтому, было разумнее переложить и стандартизировать процессы выполнения стандартных формул (инструкций) на плечи процессорных специализированных блоков и написать программу «дирижёр», которая управляла бы этими процессами (как в CISC).
Тем не менее, если встроить в данные процессоры более совершенный блок инструкций, который декодировал бы их на аппаратном уровне, то равных по производительности энергоэффективности и простоте, данному процессору практически не нашлось бы.
Первая вариация данного процессора под названием MuP21 (1995г)
, имеет вычислительную способность 100 MIPS, при техпроцессе 1.2 мкм (!), энергопотребление 50 мВт. Работа процессорa на 100 мГц и количество транзисторов равно 7000 штук (!).
Впечатляет. У Pentium 1 (60 МГц) с 3.1 млн. транзисторов, 0,8 мкм и до 15 ватт энергопотреблением, вычислительные возможности были примерно на том же уровне.
144-ядерный процессор Чарльза Мура поступил в продажу по $20
Лекция Чарльза Мура, создателя Forth: 144-ядерный процессор, зачем? Сложно ли запрограммировать 144 вычислительных ядра?
GA144: русские спецификации процессоров
MISC легко имплантируется в FPGA решения.
Добавлено спустя 7 минут 42 секунды:
Прагматичные процессоры (статья от 2001г)
В отличие и от самых эффективных эмуляторов Java-машины, и от лучших JIT-компиляторов
(осуществляющих трансляцию Java-кодов в коды целевой платформы в ходе загрузки
задачи), аппаратные стековые машины привлекательны не только (и не столько) очень
высокой производительностью, хотя их быстродействие впечатляет. Так, при потреблении
в 5 раз (!) меньшей мощности они уверенно — почти в 2 раза — обходят своих далеко
не самых медленных конкурентов из регистрового мира RISC: классическая стековая
машина "выдает" на тестах CM (CaffeineMark) 1900 единиц против 1000
единиц очень удачного процессора ARM7TDMI при тактовой частоте 100 MHz (для сравнения,
этот показатель соответствует уровню производительности процессора Intel Pentium
150 MHz или даже Pentium Pro 200 MHz — в зависимости от качества реализации виртуальной
машины Java). При этом следует учесть, что тесты CM комплексные, и полученная
оценка является интегрированной, включающей и интенсивные вычисления с плавающей
точкой, которые обычно производителями стековых машин аппаратно не поддерживаются!
Но все же главная привлекательность безадресных архитектур кроется в исключительно
высоких показателях скорости переключения между задачами/потоками в многозадачных/поточных
программных системах. Каноническим регистровым машинам в таких случаях надо сохранить
текущий контекст в стеке, размещающемся в некоторой области оперативной памяти.
Так как контекст современных процессоров достаточно объемен (обычно у них много
регистров), а операции записи во внешнюю память относительно медленны, то и время
переключения получается (в терминах процессора) очень продолжительным. Стековым
машинам такие операции не нужны — их контекст уже хранится в стеке, поэтому переключение
обычно осуществляется за один такт. Чтобы понять порядок величин, следует привести
такой пример: переключение между потоками даже в весьма неплохих ОС реального
времени, написанных на компилируемых языках и тщательно оптимизированных, отнимает
одну-две миллисекунды процессорного времени. Для процессора aJ-100 и программы,
написанной на Java, переключение между двумя потоками занимает строго 1 микросекунду.
Такая разница (на три порядка!) означает, что процессору легче "справляться"
со множеством разных задач, что исключительно важно уже не только для "настольных"
машин, но и для самых разнообразных персональных устройств.
P.S. В истории стековых процессоров (2000e года) был ptsc1000 (от Patriot Scintific)
так вот он участвовал в тестах от EMBC и показывал приличные результаты.
Х.З. почему его убрали с рынка и кто этому поспособствовал.
Тот же TF-16 (К1894 реализованный ещё на FPGA) сравнивался в тестах с 486DX в серии статей журнала "Компоненты и Технологии" в 2003-2004г (Стековые процессоры, или новое — это хорошо забытое новое)
т.е. стековые (MISC) процессоры почему то никак не представлены в нише МК, а теже Форт системы делаются и запускаются в рамках регистровой архитектуры.
У Atmel был 4-ёх битный стековый контроллер Marc4 (в автомобильном исполнении ), но его не развивали и не выводили особо на рынок возможно в угоду AVR.
Возможно XMOS (чем то близок MISC) более менее удачно зашёл на рынок некоторого индустриального применения.
KPG
Re: Форт-система
Сообщение Виктор Казаринов » 31 окт 2022, 23:01
Полезная информация. MISC рулят. А наше непонимание программ на Форте преодолимо.
Виктор Казаринов
Skype: victorkazarinov
прог. языки: почти все понемногу
ФИО: Казаринов Виктор Геннадьевич
