Машинка не едет по черной линии
Сообщение dik » 31 мар 2018, 08:10
Доброе время суток! Не откажите советом или помощью!
Собрали машинку на deek-robot motor shield Изображение
залили скетч
#define ENA_PIN   3 // ENA attach to pin5
#define ENB_PIN   11// ENB attach to pin6
#define MOTOR_L_1 12 // MOTOR_L_1 attach to pin8
#define MOTOR_L_2 9 // MOTOR_L_1 attach to pin9
#define MOTOR_R_1 13 // MOTOR_R_1 attach to pin10
#define MOTOR_R_2 8 // MOTOR_R_1 attach to pin11
#define FORWARD 0  //define forward=0,car move forward
#define BACK    1 //define back=1,car move back
#define LIGHT_LEFT_1_PIN  A0 //attach the left first Tracking module pinA0 to A0
#define LIGHT_LEFT_2_PIN  A1 //attach the left second Tracking module pinA0 to A1
#define LIGHT_MIDDLE_PIN  A2 //attach the module Tracking module pinA0 to A2
#define LIGHT_RIGHT_1_PIN A3 //attach the right  second Tracking module pinA0 to A3
#define LIGHT_RIGHT_2_PIN A4 //attach the right first Tracking module pinA0 to A4
#define SPEED 180 //define SPEED=180,it is the rotate speed of motor
unsigned char flag = 3;
unsigned char angle = 90;
void setup()
  /* set below pins as OUTPUT */
  pinMode(ENA_PIN, OUTPUT);
  pinMode(ENB_PIN, OUTPUT);
  pinMode(MOTOR_L_1, OUTPUT);
  pinMode(MOTOR_L_2, OUTPUT);
  pinMode(MOTOR_R_1, OUTPUT);
  pinMode(MOTOR_R_2, OUTPUT);
void loop()
  if (analogRead(LIGHT_LEFT_1_PIN) > 758) //if read the value of the left first Tracking module pinA0 is more than 758
    flag = 1;//flag=1
  else if (analogRead(LIGHT_LEFT_2_PIN) > 758) //if read the value of the left second Tracking module pinA0 is more than 758
    flag = 2;
  else if (analogRead(LIGHT_MIDDLE_PIN) > 758) //if read the value of the module Tracking module pinA0 is more than 758
    flag = 3;
  else if (analogRead(LIGHT_RIGHT_2_PIN) > 758) //if read the value of the right  second Tracking module pinA0 is more than 758
    flag = 4;
  else if (analogRead(LIGHT_RIGHT_1_PIN) > 758) //if read the value of the right first Tracking module pinA0 is more than 758
    flag = 5;
  else
    flag = 6;
  CAR_move(FORWARD, SPEED, SPEED); //car move forward with speed 180
void CAR_move(unsigned char direction, unsigned char speed_left, unsigned char speed_right)
  switch (direction)
    case 0:
      digitalWrite(MOTOR_L_1, HIGH); digitalWrite(MOTOR_L_2, LOW); //left motor clockwise rotation
      digitalWrite(MOTOR_R_1, HIGH); digitalWrite(MOTOR_R_2, LOW); break; //right motor clockwise rotation
    //car move back with speed 180
    case 1:
      digitalWrite(MOTOR_L_1, LOW); digitalWrite(MOTOR_L_2, HIGH);
      digitalWrite(MOTOR_R_1, LOW); digitalWrite(MOTOR_R_2, HIGH); break;
    default: break;
  analogWrite(ENA_PIN, speed_left); //write speed_left to ENA_PIN,if speed_left is high,allow left motor rotate
  analogWrite(ENB_PIN, speed_right); //write speed_right to ENB_PIN,if speed_right is high,allow right motor rotate
датчики на линию срабатывают но колёса все время крутятся вперед
подскажите пожалуйста как поправить!
dik
Re: Машинка не едет по черной линии
Сообщение Myp » 31 мар 2018, 13:14
так и должно быть, в программе происходит сканирование датчиков, но результат сканирования нигде потом не используется.
просто даётся команда ехать вперёд.
при этом есть ещё некая переменная отвечающая за угол, которая тоже не используется...
могу посоветовать лишь найти полную программу, а не этот огрызок.
Сообщение dik » 08 апр 2018, 17:52
Искал код полной программы так и не нашел. Может кому попадалась рабочая программка. Подскажите пожалуйста где искать?
dik
