ЗЫ. Не надо давать шанс проводам замкнуть!
#include <OneWire.h>
OneWire ds(10);
int Motor1EN = 7;
int Motor1dir = 5;
int Motor1step = 6;
void setup ()
Serial.begin(9600);
pinMode(Motor1EN, OUTPUT);
pinMode(Motor1dir, OUTPUT);
pinMode(Motor1step, OUTPUT);
digitalWrite(Motor1EN, LOW);
digitalWrite(Motor1dir, LOW);
digitalWrite(Motor1step, HIGH);
void loop ()
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
Serial.println("No more addresses.");
Serial.println();
ds.reset_search();
delay(250);
return;
Serial.print("ROM =");
for( i = 0; i < 8; i++) {
Serial.write(' ');
Serial.print(addr[i], HEX);
if (OneWire::crc8(addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return;
Serial.println();
switch (addr[0]) {
case 0x10:
Serial.println(" Chip = DS18S20");
type_s = 1;
break;
case 0x28:
Serial.println(" Chip = DS18B20");
type_s = 0;
break;
case 0x22:
Serial.println(" Chip = DS1822");
type_s = 0;
break;
default:
Serial.println("Device is not a DS18x20 family device.");
return;
ds.reset();
ds.select(addr);
ds.write(0x44, 1);
delay(1000);
present = ds.reset();
ds.select(addr);
ds.write(0xBE);
Serial.print(" Data = ");
Serial.print(present, HEX);
Serial.print(" ");
for ( i = 0; i < 9; i++) {
data[i] = ds.read();
Serial.print(data[i], HEX);
Serial.print(" ");
Serial.print(" CRC=");
Serial.print(OneWire::crc8(data, 8), HEX);
Serial.println();
int16_t raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3;
if (data[7] == 0x10) {
raw = (raw & 0xFFF0) + 12 - data[6];
} else {
byte cfg = (data[4] & 0x60);
if (cfg == 0x00) raw = raw & ~7;
else if (cfg == 0x20) raw = raw & ~3;
else if (cfg == 0x40) raw = raw & ~1;
celsius = (float)raw / 16.0;
fahrenheit = celsius * 1.8 + 32.0;
Serial.print(" Temperature = ");
Serial.print(celsius);
Serial.print(" Celsius, ");
Serial.print(fahrenheit);
Serial.println(" Fahrenheit");
if (celsius == 30) {stepMotor1(0, 10000);}
if (celsius == 24) {stepMotor1(1, 10000);}
void stepMotor1(int dir, int step)
digitalWrite(Motor1EN, HIGH);
if (dir)
digitalWrite(Motor1dir, HIGH);}
else
{ digitalWrite(Motor1dir, LOW);}
for (int i=0;i<step; i++)
delay(30);
digitalWrite(Motor1step, LOW);
delay(1);
delay(70);
