P.S: Или лучше перемкнуть просто?
#define FIRST_PIN 0 // первый вывод
#define LAST_PIN 19 // последний вывод
void Test1(byte pin)
if(pin < 10) Serial.print(" PIN: ");
else Serial.print(" PIN: ");
Serial.print(pin);
pinMode(pin, OUTPUT);
digitalWrite(pin, 0);
Serial.print(" LOW: ");
if(!digitalRead(pin)) Serial.print("OK ");
else Serial.print("FAIL");
digitalWrite(pin, 1);
Serial.print(" HIGH: ");
if(digitalRead(pin)) Serial.print("OK ");
pinMode(pin, INPUT);
Serial.print(" PULL UP: ");
void Test2(byte pin)
Serial.print(" ");
delay(5);
if(!digitalRead(pin))Serial.println("SHORT");
else Serial.println("OK");
void setup() {
Serial.begin(9600);
Serial.println("Test of short circuit on GND or VCC and between pins:");
Serial.println();
for(byte i = FIRST_PIN; i <= LAST_PIN; i++)
for(byte j = FIRST_PIN; j <= LAST_PIN; j++)
pinMode(j, INPUT);
digitalWrite(j, 0);
Test1(i);
pinMode(j, OUTPUT);
digitalWrite(j, 0);
Test2(i);
pinMode(j, INPUT);
digitalWrite(j, 0);
void loop() {}
PIN: 0 LOW: FAIL HIGH: OK PULL UP: OK OK
PIN: 1 LOW: OK HIGH: FAIL PULL UP: FAIL SHORT
PIN: 2 LOW: OK HIGH: OK PULL UP: OK OK
PIN: 3 LOW: OK HIGH: OK PULL UP: OK OK
PIN: 4 LOW: OK HIGH: OK PULL UP: OK OK
PIN: 5 LOW: OK HIGH: OK PULL UP: OK OK
PIN: 6 LOW: OK HIGH: OK PULL UP: OK OK
PIN: 7 LOW: OK HIGH: OK PULL UP: OK OK
PIN: 8 LOW: OK HIGH: OK PULL UP: OK OK
PIN: 9 LOW: OK HIGH: OK PULL UP: OK OK
PIN: 10 LOW: OK HIGH: OK PULL UP: OK OK
PIN: 11 LOW: OK HIGH: OK PULL UP: OK OK
PIN: 12 LOW: OK HIGH: OK PULL UP: OK OK
PIN: 13 LOW: OK HIGH: OK PULL UP: FAIL OK
PIN: 14 LOW: OK HIGH: OK PULL UP: OK OK
PIN: 15 LOW: OK HIGH: OK PULL UP: OK OK
PIN: 16 LOW: OK HIGH: OK PULL UP: OK OK
PIN: 17 LOW: OK HIGH: OK PULL UP: OK OK
PIN: 18 LOW: OK HIGH: OK PULL UP: OK OK
PIN: 19 LOW: OK HIGH: OK PULL UP: OK OK
как видно из лога на 0, 1 и 13 выводах выявлены неисправности - это нормально, потому как 0 и 1 выводы заняты UARTом, а на 13 выводе светодиод.
