\ chu (vum@eml.ru) 19:00 16.01.2014
\ rf 2.4 GHz band scanner
\ http://maniacbug.github.io/RF24/scanner_8pde-example.html
marker =rf-scanner=
&128 constant rf24-channels
here rf24-channels cells allot constant bands
: 0bands bands rf24-channels cells 0 fill ;
: 1+! ( a -- ) dup @ 1+ swap ! ; \ инкремент переменной, представленной адресом a
: scan-rf ( n --- ) \ n = количество проверок
0bands
radio-pw? 0= if radio-on then nRF24_CE low
0 ?do
rf24-channels 0
do i radio-ch!
radio-rx+
\ see 6.4 of nRF24L01+ Product Specification v1.0
[ 40 us/ ] literal
?delay
nRF24_CE low \ standby-I
cd? if bands i cells + 1+! then
loop
loop
radio-off
: scan-rf.
0 \ total channels
bands rf24-channels 0
do
i cells over + @
?dup if i 3 u0.r $3a emit \ number&colon
0 do $2a emit loop cr \ star bar
swap 1+ swap \ total count
then
loop
drop
." total: " base @ swap decimal . base !
." channels" cr
: scanrf ( n --- )
." start scanning @ " ?time. scan-rf
." stop scanning @ " ?time. scan-rf.
\ nRF24_init regular twi.init
\ ~~~~~~~~~~eof~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
\ occupy 216 cells
\amforth 5.2 ATmega32A 16000 kHz
reset source= 5
> regular twi.init
ok
> nRF24_init
ok
> decimal
ok
> 200 scanrf
start scanning @ 6.22.03.2014 10:11:07
stop scanning @ 6.22.03.2014 10:12:19
029:**
030:***
032:*
045:****
046:**
047:**
048:*
049:*****
050:******
051:****
052:****
053:********
054:********
055:****
056:****
057:*
058:**
059:***
060:*
064:*
total: 20 channels
ok
> ?nrf24.
CONFIG..........00001001
EN_AA...........00111111
EN_RXADDR.......00000011
SETUP_AW........00000011
SETUP_RETR......00000011
RF_CH...........01111111
RF_SETUP........00001111
STATUS..........00001110
OBSERVE_TX......00000000
CD..............00000000
RX_ADDR_P0......E7 E7 E7 E7 E7
RX_ADDR_P1......C2 C2 C2 C2 C2
RX_ADDR_P2......C3
RX_ADDR_P3......C4
RX_ADDR_P4......C5
RX_ADDR_P5......C6
TX_ADDR.........E7 E7 E7 E7 E7
RX_PW_P0........0
RX_PW_P1........0
RX_PW_P2........0
RX_PW_P3........0
RX_PW_P4........0
RX_PW_P5........0
FIFO_STATUS.....00010001
DYNPD...........00000000
FEATURE.........00000000
ok
\ sim900.f
\ ~ilya
\ 12.02.2014
\ SIM900_TXD - PH0
\ SIM900_RXD - PH1
\ SIM900_RST - PL2
\ SIM900_PWR - PL3
\ ...... ............ .............. .. sim900 ........ ............ .. ........ "AT"
marker =sim900=
\ USART2
&214 constant UDR2 \ USART I/O Data Register
&208 constant UCSR2A \ USART Control and Status Register A
$80 constant UCSR2A_RXC2 \ USART Receive Complete
$40 constant UCSR2A_TXC2 \ USART Transmitt Complete
$20 constant UCSR2A_UDRE2 \ USART Data Register Empty
$10 constant UCSR2A_FE2 \ Framing Error
$08 constant UCSR2A_DOR2 \ Data overRun
$04 constant UCSR2A_UPE2 \ Parity Error
$02 constant UCSR2A_U2X2 \ Double the USART transmission speed
$01 constant UCSR2A_MPCM2 \ Multi-processor Communication Mode
&209 constant UCSR2B \ USART Control and Status Register B
$80 constant UCSR2B_RXCIE2 \ RX Complete Interrupt Enable
$40 constant UCSR2B_TXCIE2 \ TX Complete Interrupt Enable
$20 constant UCSR2B_UDRIE2 \ USART Data register Empty Interrupt Enable
$10 constant UCSR2B_RXEN2 \ Receiver Enable
$08 constant UCSR2B_TXEN2 \ Transmitter Enable
$04 constant UCSR2B_UCSZ22 \ Character Size
$02 constant UCSR2B_RXB82 \ Receive Data Bit 8
$01 constant UCSR2B_TXB82 \ Transmit Data Bit 8
&210 constant UCSR2C \ USART Control and Status Register C
$C0 constant UCSR2C_UMSEL2 \ USART Mode Select
$30 constant UCSR2C_UPM2 \ Parity Mode Bits
$08 constant UCSR2C_USBS2 \ Stop Bit Select
$06 constant UCSR2C_UCSZ2 \ Character Size
$01 constant UCSR2C_UCPOL2 \ Clock Polarity
&212 constant UBRR2 \ USART Baud Rate Register Bytes
&258 constant PORTH \ PORT H Data Register
&267 constant PORTL \ PORT L Data Register
250 constant rbufsize \ ............ ............
PORTH 0 portpin: SIM900_RXD \
PORTH 1 portpin: SIM900_TXD \
PORTL 2 portpin: SIM900_RST \
PORTL 3 portpin: SIM900_PWR \
rbufsize buffer: rx-tx-buf
variable b-count
: sim900-init
SIM900_RXD pin_input
SIM900_TXD pin_output
SIM900_PWR pin_output
SIM900_RST pin_output
: usart2-init ( n -- )
( &8) UBRR2 c! \ ...... 16 ...... ................ 115200
UCSR2B_RXCIE2 \ .................... .... .................. ..............
UCSR2B_RXEN2 \ .......... .......
UCSR2B_TXEN2 \ ................ .......
or or UCSR2B c!
: b2begin rx-tx-buf rbufsize erase 0 b-count ! ;
: b2buf ( n -- ) rx-tx-buf b-count @ + c! ;
: 1b-rcv
UDR2 c@
b-count @ rbufsize <
if
b2buf 1 b-count +!
else
b2begin \ .............. .......... .. .............. ........
b2buf
then
: 1b-send 1000 0 do UCSR2A c@ UCSR2A_UDRE2 and if leave then loop UDR2 c! ;
: cr-send $0d 1b-send $0a 1b-send ;
: s1 b2begin over + swap ?do i c@ 1b-send loop cr-send ;
: t1 rx-tx-buf b-count @ cr type ;
: test
b2begin
sim900-init
100 ms
SIM900_PWR high
['] 1b-rcv 102 int! +int
8 usart2-init
100 ms
SIM900_PWR low
1000 ms
( &8) UBRR2 c! \ При 16 МГц скорость 115200
UCSR2B_RXCIE2 \ Прерывение по получению символа
UCSR2B_RXEN2 \ Прием вкл.
UCSR2B_TXEN2 \ Передача вкл.
or or UCSR2B c!
;: usart2-init ( n -- )
[ UCSR2B_RXCIE2 \ Прерывение по получению символа
or or
] literal
UCSR2B c!
;chu писал(а):
or or
] literal
UCSR2B c!
сократив объём шитого кода и ускорив исполнение слова...
chu писал(а):ps. и все таки вопрос таймаутов остается открытым...хотя твоё решение интересно.
может быть catch\throw ? к примеру на аппаратном таймере - t2 вроде пока свободен.
), который сформировался в процессе освоения nRF24L01+ и изучения его работы, и предназначенный для экспериментов с этим девайсом.
marker =nRF24L01+=
\ Pins
\ m328p
\ PORTD 4 portpin: nRF24_CE
\ PORTD 5 portpin: nRF24_CSN
\ PORTD 3 portpin: nRF24_IRQ \ == INT1
\ m32A
PORTC 2 portpin: nRF24_CE \ Chip Enable Activates RX or TX mode
PORTC 3 portpin: nRF24_CSN \ SPI Chip Select
\ nRF24l01+ Register Map
$00 constant nRF24_CONFIG \ Configuration Register
$01 constant nRF24_EN_AA \ Enable ‘Auto Acknowledgment’
$02 constant nRF24_EN_RXADDR \ Enabled RX Addresses
$03 constant nRF24_SETUP_AW \ Setup of Address Widths (common for all data pipes)
$04 constant nRF24_SETUP_RETR \ Setup of Automatic Retransmission
$05 constant nRF24_RF_CH \ RF Channel
$06 constant nRF24_RF_SETUP \ RF Setup Register
$07 constant nRF24_STATUS \ Status Register (In parallel to the SPI command
\ word applied on the MOSIpin, the STATUSregister is shifted serially out on the MISOpin)
$08 constant nRF24_OBSERVE_TX \ Transmit observe register
$09 constant nRF24_CD \ Carrier Detect. See page 74
\ Data pipes
$0A constant nRF24_RX_ADDR_P0 \ 0xE7E7E7E7E7
$0B constant nRF24_RX_ADDR_P1 \ 0xC2C2C2C2C2
$0C constant nRF24_RX_ADDR_P2 \ 0xC3
$0D constant nRF24_RX_ADDR_P3 \ 0xC4
$0E constant nRF24_RX_ADDR_P4 \ 0xC5
$0F constant nRF24_RX_ADDR_P5 \ 0xC6
$10 constant nRF24_TX_ADDR \ Transmit address.
\ Used for a PTX device only. (LSByte is written first)
\ Set RX_ADDR_P0 equal to this address to handle automatic acknowledge
\ if this is a PTX device with Enhanced ShockBurst™ enabled. See page 65.
\ Number of bytes in RX payload in data pipe (1 to 32 bytes).
\ 0=Pipe not used
$11 constant nRF24_RX_PW_P0
$12 constant nRF24_RX_PW_P1
$13 constant nRF24_RX_PW_P2
$14 constant nRF24_RX_PW_P3
$15 constant nRF24_RX_PW_P4
$16 constant nRF24_RX_PW_P5
$17 constant nRF24_FIFO_STATUS \ FIFO Status Register
$1C constant nRF24_DYNPD \ Enable dynamic payload length
$1D constant nRF24_FEATURE \ Feature Register
\ nRF24L01+ commands
$00 constant nRF24_REG@ \
$20 constant nRF24_REG! \
$61 constant nRF24_RX_PLOAD@ \
$a0 constant nRF24_TX_PLOAD! \
$e1 constant nRF24_FLUSH_TX \
$e2 constant nRF24_FLUSH_RX \
$e3 constant nRF24_REUSE_TX_PL \
$ff constant nRF24_NOP \
$60 constant RX_PL_WID@ \
$a1 constant ACK_PAYLOAD! \ ( pipe --- )
$b0 constant TX_PAYLOAD_NOACK! \
\ some nRF24l01+ registers fields & constants
: bit ( n --- m ) $7 and 1 swap lshift ;
nRF24_STATUS $70 bitmask: nrf24_flags
nRF24_CONFIG 1 bit bitmask: radio-pw
nRF24_CONFIG 0 bit bitmask: radio-rx
nRF24_RF_CH $7f bitmask: radio-ch
nRF24_RF_SETUP 5 bit 3 bit or
bitmask: air-rate
nRF24_SETUP_RETR $0f bitmask: arc
nRF24_SETUP_RETR $f0 bitmask: ard
nRF24_OBSERVE_TX $f0 bitmask: plos_cnt
nRF24_OBSERVE_TX $0f bitmask: arc_cnt
nRF24_RX_PW_P0 $3f bitmask: rx_pw \ Number of bytes in RX payload in data pipe
> 5 bit dup .x .b
20 00100000 ok
>> nrf24_flags .x
7 ok
> .b
01110000 ok
> air-rate .x .b
6 00101000 ok
\ base nRF24l01+ transactions over spi
: nrf24? ( -- n ) \ read nRF24L01+ STATUS
nRF24_NOP
nRF24_CSN low
c!@spi
nRF24_CSN high
: nrf24@ ( ra -- c ) \ ra - адрес регистра nRF24, 1байт
nRF24_REG@ or
nRF24_CSN low
spi! spi@
nRF24_CSN high
: nrf24! ( c ra -- )
nRF24_REG! or
nRF24_CSN low
spi! spi!
nRF24_CSN high
: nrf24-cmd! ( cmd --- )
nRF24_CSN low spi!
nRF24_CSN high
: nRF24_init
nRF24_CSN over over pin_output high
nRF24_CE over over pin_output low
+spi 0 spi-mode!
nrf24_flags nrf24!
\ установка, сброс, проверка
\ отдельных битов в регистре r,
\ m - маска
: #bit+ ( m r --- ) dup >r nrf24@ or r> nrf24! ;
: #bit- ( m r --- ) >r invert r@ nrf24@ and r> nrf24! ;
: #tst? ( m r --- f ) nrf24@ and ;
\ установка группы бит с в битовом поле m в регистре r
: #set+ ( c m r --- )
dup >r
nrf24@
over invert and
>r and
r> or r>
nrf24!
, остальным предлагаю поверить - это работает!\ установка группы бит с в битовом поле m в регистре r
over invert over nrf24@ and
>r -rot and
r> or swap nrf24!
: radio-pw? ( -- f ) radio-pw #tst? ; \ power on?
: radio-off ( -- ) radio-pw #bit- ; \ power off
: radio-on ( -- ) radio-pw #bit+ pause 5 ms ; \ power up set bit
: radio-ch! ( n -- ) radio-ch #set+ ;
: radio-ch@ ( -- n ) radio-ch #tst? ;
: radio-rx? ( -- f ) radio-rx #tst? ; \ test if receiver
: radio-rx+ \ RX mode
radio-rx #bit+ \ PRIM_RX set 1
nRF24_CE high
[ &130 us/ ] \ RX setting
literal ?delay
: radio-tx+ \ TX mode
nRF24_CE low
radio-rx #bit- \ clear PRIM_RX
; \ standby-I
: cd? ( -- f ) [ 0 bit ] literal nRF24_CD #tst? ; \ RPD
\ Air data rate
$0 constant 1Mbps
$08 constant 2Mbps
$20 constant 250Kbps
: rf-rate! ( m -- ) air-rate #set+ ;
: rf-rate@ ( -- m ) air-rate #tst? ;
\ Automatic Retransmission
: retx-delay! ( n --- ) 4 lshift ard #set+ ;
: retx-delay@ ( --- n ) ard #tst? 4 rshift ;
: retx-count! ( n --- ) arc #set+ ;
: retx-count@ ( --- n ) arc #tst? ;
\ nRF24L01+dumpreg.f
\ chu 17:15 01.03.2014
\ Read & Display all nRF24L01+ registers
marker =?nrf24.=
: nRF24[@]. ( ra n --- ) \
swap
nRF24_REG@ or
nRF24_CSN low spi!
0 ?do spi@ .x loop
nRF24_CSN high
: ?nrf24.
base @ decimal
cr
." CONFIG.........." nRF24_CONFIG nrf24@ .b cr \ Configuration Register
." EN_AA..........." nRF24_EN_AA nrf24@ .b cr \ Enable ‘Auto Acknowledgment’
." EN_RXADDR......." nRF24_EN_RXADDR nrf24@ .b cr \ Enabled RX Addresses
." SETUP_AW........" nRF24_SETUP_AW nrf24@ .b cr \ Setup of Address Widths (common for all data pipes)
." SETUP_RETR......" nRF24_SETUP_RETR nrf24@ .b cr \ Setup of Automatic Retransmission
." RF_CH..........." nRF24_RF_CH nrf24@ .b cr \ RF Channel
." RF_SETUP........" nRF24_RF_SETUP nrf24@ .b cr \ RF Setup Register
." STATUS.........." nRF24_STATUS nrf24@ .b cr \ Status Register (In parallel to the SPI command
." OBSERVE_TX......" nRF24_OBSERVE_TX nrf24@ .b cr \ Transmit observe register
." CD.............." nRF24_CD nrf24@ .b cr \ Carrier Detect. See page 74
\ Data pipes
." RX_ADDR_P0......" nRF24_RX_ADDR_P0 5 nRF24[@]. cr \ 0xE77735F0D3
." RX_ADDR_P1......" nRF24_RX_ADDR_P1 5 nRF24[@]. cr \ 0xC2C2C2C2C2
." RX_ADDR_P2......" nRF24_RX_ADDR_P2 nrf24@ .x cr \ 0xC3
." RX_ADDR_P3......" nRF24_RX_ADDR_P3 nrf24@ .x cr \ 0xC4
." RX_ADDR_P4......" nRF24_RX_ADDR_P4 nrf24@ .x cr \ 0xC5
." RX_ADDR_P5......" nRF24_RX_ADDR_P5 nrf24@ .x cr \ 0xC6
." TX_ADDR........." nRF24_TX_ADDR 5 nRF24[@]. cr \ Transmit address.
\ Set RX_ADDR_P0 equal to this address to handle automatic acknowledge if this is a PTX
\ device with Enhanced ShockBurst™ enabled. See page 65.
\ Number of bytes in RX payload in data pipe (1 to 32 bytes). 0=Pipe not used
." RX_PW_P0........" nRF24_RX_PW_P0 nrf24@ . cr
." RX_PW_P1........" nRF24_RX_PW_P1 nrf24@ . cr
." RX_PW_P2........" nRF24_RX_PW_P2 nrf24@ . cr
." RX_PW_P3........" nRF24_RX_PW_P3 nrf24@ . cr
." RX_PW_P4........" nRF24_RX_PW_P4 nrf24@ . cr
." RX_PW_P5........" nRF24_RX_PW_P5 nrf24@ . cr
." FIFO_STATUS....." nRF24_FIFO_STATUS nrf24@ .b cr \ FIFO Status Register
\ ." The DYNPD register is used to enable the dynamic payload feature on each Rx pipe."
." DYNPD..........." nRF24_DYNPD nrf24@ .b cr \ Enable dynamic payload length
." FEATURE........." nRF24_FEATURE nrf24@ .b cr \ Feature Register
base !
\ ====EOF========================================================================
\ nRF24_STATUS test
\ Data pipe number for the payload available for reading from RX_FIFO
\ 110: Not Used
\ 111: RX FIFO Empty
: rx-pipe? ( -- n ) nrf24? 1 rshift $7 and ; \ read only
: tx-full? ( -- f ) nrf24? [ 0 bit ] literal and ; \ read only
: rx-data? ( -- f ) nrf24? [ 6 bit ] literal and ; ( RX_DR )
: tx-sent? ( -- f ) nrf24? [ 5 bit ] literal and ; ( TX_DS )
: rtx-max? ( -- f ) nrf24? [ 4 bit ] literal and ; ( MAX_RT )
: tx-end ( -- f ) nrf24? [ 5 bit 4 bit or ] literal and ;
: rx-done ( -- ) [ 6 bit ] literal ( RX_DR ) nRF24_STATUS #bit+ ;
: tx-sent ( -- ) [ 5 bit ] literal ( TX_DS ) nRF24_STATUS #bit+ ;
: rtx-fix ( -- ) [ 4 bit ] literal ( MAX_RT ) nRF24_STATUS #bit+ ;
\ nRF24_FIFO_STATUS
: rx-empty? ( -- f ) [ 0 bit ] literal ( RX_EMPTY ) nRF24_FIFO_STATUS #tst? ;
: tx-empty? ( -- f ) [ 4 bit ] literal ( TX_EMPTY ) nRF24_FIFO_STATUS #tst? ;
\ nRF24_OBSERVE_TX
: tx-lost? ( --- n ) plos_cnt #tst? &4 rshift ;
: rtx-count? ( --- n ) arc_cnt #tst? ;
\ n==0..5
: ?pipe dup 0 6 within 0= abort" illegal pipe#" ;
\ c==Number of bytes in RX payload in data pipe n1
: pipe#? ( n1 --- c ) ?pipe rx_pw rot + #tst? ;
: pipe#! ( c n1 --- ) ?pipe rx_pw rot + #set+ ;
: pipe ( n --- m ra ) ?pipe bit nRF24_EN_RXADDR ;
: pipe+ ( n --- ) pipe #bit+ ; \ set
: pipe- ( n --- ) pipe #bit- ; \ clear
: pipe? ( n - f ) pipe #tst? ; \ test
: auto-ack ( n --- m ra ) ?pipe bit nRF24_EN_AA ;
: auto-ack+ ( n --- ) auto-ack #bit+ ;
: auto-ack- ( n --- ) auto-ack #bit- ;
: auto-ack? ( n - f ) auto-ack #tst? ;
: +dyn [ 2 bit ] literal ( EN_DPL ) nRF24_FEATURE #bit+ ;
: -dyn [ 2 bit ] literal ( EN_DPL ) nRF24_FEATURE #bit- ;
: dyn-pl ( n --- m ra ) ?pipe bit nRF24_DYNPD ;
: dyn-pl+ ( n --- ) dyn-pl #bit+ ;
: dyn-pl- ( n --- ) dyn-pl #bit- ;
: dyn-pl? ( n - f ) dyn-pl #tst? ;
\ block transfers over spi
: >spi ( a c --- ) over + swap ?do i c@ spi! loop ;
: <spi ( a c --- ) over + swap ?do spi@ i c! loop ;
\ LSByte is first
: <end ( a c -- a1 c 0 ) dup -rot + swap 0 ;
: spi< ( a c --- ) <end ?do 1- dup c@ spi! loop drop ;
: spi> ( a c --- ) <end ?do 1- spi@ over c! loop drop ;
\ radio transceiver addresses maintenance
\ LSByte is written first
\ a=address c=count ra=register_address
: addrs! ( a c ra --- )
nRF24_CSN low
nRF24_REG! or spi! spi<
nRF24_CSN high
: addrs@ ( a c ra --- )
nRF24_CSN low
nRF24_REG@ or spi! spi>
nRF24_CSN high
: addrs_w! ( n --- )
dup 3 6 within 0= abort" illegal address width"
2 - nRF24_SETUP_AW nrf24!
: addrs_w@ ( --- n )
nRF24_SETUP_AW nrf24@ &3 and 2 +
0
5 -- transmitter
5 -- receiver0
5 -- receiver1
1 -- receiver2
1 -- receiver3
1 -- receiver4
1 -- receiver5
constant /addresses
here dup /addresses dup allot 0 fill constant radio
: ?receiver ( a1 #pipe -- a2 )
case
0 of receiver0 endof
1 of receiver1 endof
2 of receiver2 endof
3 of receiver3 endof
4 of receiver4 endof
5 of receiver5 endof
endcase
: ?addr_w ( #pipe -- aw )
case
0 2 range of addrs_w@ endof
2 6 range of 1 endof
endcase
\ Transmit address. Used for a PTX device only.
: tx-addr! ( a c --- ) \ ram version
addrs_w@ over = 0= abort" wrong transmitter address width "
nRF24_TX_ADDR addrs!
: tx-addr@ radio transmitter addrs_w@ nRF24_TX_ADDR addrs@ ;
: tx?addr.
tx-addr@
radio transmitter addrs_w@ over over
over + swap do i c@ .x loop
2 spaces ." == " type cr
\ Receive address data # pipe
\ LSByte is written first.
\ Write the number of bytes defined by SETUP_AW
\ если строка ( а с ) длинная, те с>>addrs_w (SETUP_AW), то
\ в качестве адреса будут использованы младшие addrs_w символы.
\ те строка будет обрезана слева, например
\ если SETUP_AW=5,
\ и s" my_remote_node" 1 rx-addr! ,
\ то nRF24_RX_ADDR_P1 == "_node"
: rx-addr! ( a c #pipe --- )
?pipe dup ( a c # # )
nRF24_RX_ADDR_P0 + >r ( a c # | r: reg )
?addr_w
over over < abort" too short address string" \ test if c < aw
>r ( a c | r: reg aw ) + r@ -
r> r> addrs!
: rx-addr@ ( #pipe --- )
?pipe radio ( # a1 )
over ?receiver ( # a2 )
over ?addr_w ( # a2 c )
rot ( a2 c # )
nRF24_RX_ADDR_P0 + ( a2 c reg )
addrs@
: pipes? 6 0 do i rx-addr@ loop ;
: pipes.
radio
6 0 do
i dup ." RX_ADDR_P" .x ." = "
over over
?receiver over
?addr_w over over
." = " type cr drop
loop
drop
: rx?addr. pipes? pipes. ;
&32 constant #fifo \ максимальная длина пакета, байт
\ буферы для приемника и передатчика со счетчиком
here dup #fifo 1+ dup allot 0 fill ( erase ) constant rx-packet
here dup #fifo 1+ dup allot 0 fill ( erase ) constant tx-packet
: rx0buff rx-packet #fifo 1+ 0 fill ;
: tx0buff tx-packet #fifo 1+ 0 fill ;
\ flush_tx Delete all packets from the Tx FIFO.
: tx0fifo nRF24_FLUSH_TX nrf24-cmd! ;
\ flush_rx Delete all packets from the Rx FIFO.
: rx0fifo nRF24_FLUSH_RX nrf24-cmd! ;
\ flush rx&tx fifos & clear all status flags
: tr-clear
nrf24_flags #bit+
rx0fifo
tx0fifo
\ загрузка TX FIFO передатчика из буфера
\ W_TX_PAYLOAD counted string at memory
\ нет проверки c == 1..32
: >tx-fifo ( a c --- )
nRF24_CSN low
nRF24_TX_PLOAD! spi! >spi
nRF24_CSN high
\ чтение RX FIFO приемника в буфер
\ R_RX_PAYLOAD counted string at memory
: <rx-fifo ( a c --- )
nRF24_CSN low
nRF24_RX_PLOAD@ spi! <spi
nRF24_CSN high
\ Reuse last transmitted payload.
\ TX payload reuse is active until W_TX_PAYLOAD or FLUSH TX is executed.
\ TX payload reuse must not be activated or deactivated during package transmission.
: retx! \ retransmit
nRF24_REUSE_TX_PL nrf24-cmd!
\ Read RX payload width for the top
\ R_RX_PAYLOADin the RX FIFO.
\ note: Flush RX FIFO if
\ the read value is larger than 32 bytes.
: rx-count@ ( -- n ) \ packet-count@
nRF24_CSN low
RX_PL_WID@ spi! spi@
nRF24_CSN high
\ Used in RX mode.
\ Write Payload to be transmitted together with
\ ACK packet on PIPE n
: >rx-ack+ ( a c n -- ) \ >packet-ack
?pipe
nRF24_CSN low
ACK_PAYLOAD! or spi! >spi
nRF24_CSN high
\ Used in TX mode.
\ Disables AUTOACK on this specific packet.
: >tx-noack ( a c --- ) \ >packet-noack
nRF24_CSN low
TX_PAYLOAD_NOACK! spi! >spi
nRF24_CSN high
: startx
nRF24_CE high [ 10 us/ ] literal ?delay
nRF24_CE low [ 130 us/ ] literal ?delay
\ occupies 2026 cells
\ ==EOF===================================================================
\ nRF24L01+ranger.f
\ chu ( vum@eml.ru ) 13:26 21.03.2014
\ nRF24L01+.f required
\ Product Specification v1.0
\ Appendix C - Constant carrier wave output for testing
\ Configuration
\ 1. Set PWR_UP= 1 and PRIM_RX= 0 in the CONFIGregister.
\ 2. Wait 1.5ms PWR_UP->standby.
\ 3. In the RF register set:
\ - CONT_WAVE= 1.
\ - PLL_LOCK= 1.
\ - RF_PWR.
\ 4. Set the wanted RF channel.
\ 5. Set CEhigh.
\ 6. Keep CEhigh as long as the carrier is needed.
\ RF_PWR bits
$0 constant -18dBm
$2 constant -12dBm
$4 constant -6dBm
$6 constant 0dBm
\ &4 bit constant pll_lock
\ &7 bit constant cont_wave
nRF24_RF_SETUP &7 bit &4 bit or bitmask: rf-test
nRF24_RF_SETUP &2 bit &1 bit or bitmask: rf-pwr
: carrier+ ( c1 c2 --- ) \ c1==rf_channel, c2==rf_output_power
radio-pw? 0= if
radio-on then
radio-tx+
rf-pwr #set+
rf-test #bit+
radio-ch!
nRF24_CE high
\ The nRF24L01+ should now output an unmodulated centered carrier.
: carrier-
nRF24_CE low
rf-test #bit-
radio-off
: rfpw-tst ( c1 c2 --- ) \ c1==rf_channel, c2==rf_output_power
carrier+ ." The nRF24L01+ now output an unmodulated centered carrier." cr
begin pause key? until key drop
carrier- ." The output carrier stoped." cr
\ ====== mobile receiver range led indicator ===========================
marker =range-led=
\ m328p
PORTB 0 portpin: blue
PORTB 1 portpin: green
PORTB 2 portpin: red
: 0led
blue over over pin_output high
green over over pin_output high
red over over pin_output high
: b+ blue low ;
: b- blue high ;
: g+ green low ;
: g- green high ;
: r+ red low ;
: r- red high ;
\ carrier+ must be executed on transmitter side of the rf channel
: range-led ( c --- ) \ c==rf channel
radio-ch! 0led
begin
radio-rx+
[ 40 us/ ]
literal ?delay \ If no packets are received the RPD is latched
nRF24_CE low \ at the end of a receive period as a result
\ of host MCU setting CE low (6.4 RPD measurements)
\ standby-I
cd? if r- g+ else g- r+ then
key? until
key drop
0led
marker =bootstrap=
\ start-up
\ подменяет собой дефолтный applturnkey
\ сохраняя его в eeprom value old-start-up
\ смотрит источник сброса:
\ флаги источников
\ биты сброса
$1 constant PORF
$2 constant EXTRF
$4 constant BORF
&8 constant WDRF
$10 constant JTRF
PORF
EXTRF or
BORF or
WDRF or
JTRF or
constant COLD
: POWER? ( --- f ) rstf c@ PORF BORF or and ;
: COLD? ( --- f ) rstf c@ COLD and 0= ;
: DEADLINE? ( --- f ) rstf c@ WDRF and ;
: MANUAL? ( --- f ) rstf c@ EXTRF and ;
' turnkey defer@ value my-old-start-up \
: restore-turnkey my-old-start-up is turnkey ;
: start-ranger nRF24_init &13 ( radio-channel ) range-led ;
: start-up
my-old-start-up execute
COLD? if noop
then
POWER? if start-ranger \ require nRF24L01+ files.f
then
MANUAL? if noop
then
DEADLINE? if noop
then
: insert-key ['] start-up is turnkey ;
\ insert-key
\ =eof==================================================================
> &13 0dBm rfpw-tst
но лучше поздно чем никогда.From: Andreas Wagner
Have you had success with sending text strings between the nRF24L01 radios?
\ chu 9:33 22.03.2014
marker =tune-up=
: my-tune
6 bit \ MASK_RX_DR
5 bit or \ MASK_TX_DS
4 bit or \ MASK_MAX_RT
3 bit or \ EN_CRC
\ 2 bit or \ CRCO
] literal
nRF24_CONFIG #bit+ \ no interrupt, 1byte crc enable
$3e nRF24_EN_AA #bit- \ no auto-ack but 0&1 pipes
$0f retx-count! \ Up to 15 Re-Transmit on fail of AA
$0f retx-delay! \ Wait 4000µS
\ occupy 59 cells
: setup-listen ( c -- ) \ rf-channel
my-tune
radio-rx+ rx0buff
radio-ch! +dyn 0 dyn-pl+
?nrf24.
> &13 setup-listen
CONFIG..........01111011
EN_AA...........00000001
SETUP_RETR......11111111
RF_CH...........00001101
RX_ADDR_P2......C3
RX_ADDR_P3......C4
RX_ADDR_P4......C5
RX_ADDR_P5......C6
RX_PW_P0........0
RX_PW_P1........0
RX_PW_P2........0
RX_PW_P3........0
RX_PW_P4........0
RX_PW_P5........0
DYNPD...........00000001
FEATURE.........00000100
ok
: setup-sender ( c -- ) \ rf-channel
my-tune
radio-tx+ tx0buff
?nrf24.
> &13 setup-sender
CONFIG..........01111010
RX_ADDR_P2......C3
RX_ADDR_P3......C4
RX_ADDR_P4......C5
RX_ADDR_P5......C6
RX_PW_P0........0
RX_PW_P1........0
RX_PW_P2........0
RX_PW_P3........0
RX_PW_P4........0
RX_PW_P5........0
ok
> \ chu 22:41 19.03.2014
\ 14:08 26.03.2014
marker =listener=
\ : rx-empty? ( -- f ) [ 0 bit ] literal ( RX_EMPTY ) nRF24_FIFO_STATUS #tst? ;
\ : rx-done ( -- ) [ 6 bit ] literal ( RX_DR ) nRF24_STATUS #bit+ ;
: rx-clear rx0fifo rx-done ; \ clear rx fifo & rx_dr status flag
: pipe-name. ( # --- )
\ cr
rx-pipe? radio
over ?receiver
swap ?addr_w
." from " type ." : "
\ распечатать содержимое буфера, если = длина пакета = 0 - не печатаем
: msg. rx-packet count ?dup if type else drop then cr ;
: get-packet
rx-packet rx-count@
#fifo over < throw \ если длина пакета >32 = исключение!
over 1+ over <rx-fifo
swap c!
: get-msg
['] get-packet catch if \ если исключение,
." invalid packet (="
base @ decimal rx-count@ .
base ! ." )" cr
rx0buff rx-clear
then
: more-msg rx-empty? if rx-done then ;
: stop-listen
key?
if key $03 = \ control-C
else 0
then
: listen
rx-clear \ flash rx fifo & clear status flags
." radio " &2400 radio-ch@ + . ." MHz" cr
." start listening @ " ?time.
." press ^C to terminate listening" cr cr
begin rx-data?
if
?time. pipe-name. get-msg msg. more-msg
then
stop-listen until
." stop listening @ " ?time.
\ chu 2:34 24.03.2014
marker =sender=
\ : tx-end
\ 5 bit ( TX_DS )
\ 4 bit ( MAX_RT ) or
\ ] literal
\ nrf24? and
\ : tx-sent [ 5 bit ] literal ( TX_DS ) nRF24_STATUS #bit+ ;
\ : rtx-fix [ 4 bit ] literal ( MAX_RT ) nRF24_STATUS #bit+ ;
\ : tx-empty? [ 4 bit ] literal ( TX_EMPTY ) nRF24_FIFO_STATUS #tst? ;
: (send)
tx-empty?
if ." tx empty" cr
else
startx begin tx-end until
rtx-max? throw
tx-sent
then
: send
['] (send) catch
if rtx-fix tx-lost? . ." lost packet" cr
." no link: " radio-ch@ &2400 over +
$ef00 + throw \ исключение= номер rf канала - нет связи
then
: >tx ( a c -- )
tx-full? if
send begin
tx-full? 0=
until then
>tx-fifo
\ ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~> listen
radio 2413 MHz
start listening @ 3.16.04.2014 21:10:14
> s" Hello world! I'm nRF24L01+ radio" >tx send
ok
> ?nrf24.
RX_ADDR_P2......C3
RX_ADDR_P3......C4
RX_ADDR_P4......C5
RX_ADDR_P5......C6
RX_PW_P0........0
RX_PW_P1........0
RX_PW_P2........0
RX_PW_P3........0
RX_PW_P4........0
RX_PW_P5........0
ok
>3.16.04.2014 21:14:07
from : Hello world! I'm nRF24L01+ radio> s" I am transmitter" >tx send ?nrf24.
RX_ADDR_P2......C3
RX_ADDR_P3......C4
RX_ADDR_P4......C5
RX_ADDR_P5......C6
RX_PW_P0........0
RX_PW_P1........0
RX_PW_P2........0
RX_PW_P3........0
RX_PW_P4........0
RX_PW_P5........0
ok
>3.16.04.2014 21:21:24
stop listening @ 3.16.04.2014 21:22:00
ok
> ?nrf24.
RX_ADDR_P2......C3
RX_ADDR_P3......C4
RX_ADDR_P4......C5
RX_ADDR_P5......C6
RX_PW_P0........0
RX_PW_P1........0
RX_PW_P2........0
RX_PW_P3........0
RX_PW_P4........0
RX_PW_P5........0
ok
>Note: Flush RX FIFO if the read value is larger than 32 bytes.
> s" this string is longer then fifo 32-bytes width buffer" dup . >tx send
53 ok
> ?nrf24.
RX_ADDR_P2......C3
RX_ADDR_P3......C4
RX_ADDR_P4......C5
RX_ADDR_P5......C6
RX_PW_P0........0
RX_PW_P1........0
RX_PW_P2........0
RX_PW_P3........0
RX_PW_P4........0
RX_PW_P5........0
ok
>> listen
radio 2413 MHz
start listening @ 3.16.04.2014 21:38:03
3.16.04.2014 21:38:12
from : invalid packet (=53 )> s" good width string" dup . >tx send
17 ok
>3.16.04.2014 21:40:04
stop listening @ 3.16.04.2014 21:40:28
ok
>chu писал(а):при работе с часиками ds1307 были замечены лаги. видимо причина в том, что в момент считывания происходила смена (обновление) значения регистров. вылечил (надеюсь) таким образом - после считывания, повторно читаю значение секунд и сравниваю с уже прочитанным, если не совпадают - повторяю всю операцию заново.
search\ search.frt
\ Author: J.L. Bezemer http://thebeez.home.xs4all.nl/4tH/
marker =search=
0 constant false
\ -1 constant true
: search
swap >r >r over ( a1 n1 a1)
over r@ - r> swap ( a1 n1 a1 n2 n3)
begin
dup -1 > ( a1 n1 a1 n2 n3 f)
if ( a1 n1 a1 n2 n3)
-rot 2dup ( a1 n1 n3 a1 n2 a1 n2)
r@ over ( a1 n1 n3 a1 n2 a1 n2 a2 n2)
compare ( a1 n1 n3 a1 n2 f)
if ( a1 n1 n3 a1 n2)
swap ( char+) 1+ swap ( a1 n1 n3 a1+1 n2)
rot 1- false ( a1 n1 a1+1 n2 n3 -f)
else ( a1 n1 n3 a1 n2)
rot + ( a1 n1 a1 n2+n3)
2>r 2drop 2r> ( a1 n2+n3)
true dup ( a1 n2+n3 f f)
then
else ( a1 n1 a1 n2 n3)
drop 2drop false true
then ( a1 n1 -f f)
until
r> drop
search - это что-то строковое?ilya73 писал(а): "вкусное" слово
Вернуться в МиниБот — национальный класс роботов
