Proteus 7.1 sp0 - DEMO
Сообщение avr123.nm.ru » 05 мар 2007, 12:37
downloads.labcenter.co.uk/prodemo.exe
Советую скачать.
Пример работы с PROTEUS    http://proteus123.narod.ru/01.htm
Апноут микрочипа  AN696  -  Сервопривоод с энкодером и ПИД регулированием -  сделан  в примерах  нового  Proteus 7.1 sp0 - DEMO   там еще несколько апноутов по электроприводу
выложено в примеры.
Я проверил - шагание по Си и АСМ инструкциям - F11 -
работает  в этой демо версии !
Какие компоненты  моделируются:
http://www.labcenter.co.uk/vmodels/peripherals.htm
Proteus Version 7.1
Design Suite 7 represents over 12 months development and constitutes a major architectural release. The following is a brief summary of some of the changes and new functionality:
ISIS Schematic Capture:
New User Interface
Context Highlighting provides visual indication of which object the mouse is over.
Mouse cursors indicate which action will be performed on an object.
Modeless selection and modeless wiring optimise efficiency.
Conventional use of mouse buttons - left to place and select, right for context menu,
Block operations enhanced with adjustable tag-boxes and definable pickup points.
Improved mouse wheel pan and zoom aid design navigation.
New Design Explorer
Provides a spreadsheet like view of the design parts list and net list.
Parts list view shows the design by sheets, parts and pins.
Netlist view shows the design by sheets, nets and pins.
Drilling into a pin toggles between the part and net views.
Cross probing onto both the schematic and PCB is supported at sheet, part and net level.
ARES PCB Layout
New User Interface
New 3D Visualisation Engine - available in Advanced Feature Set (level 2/2+/3) only.
Provides 3D Visualisation of the current layout.
Intuitive and simple navigation with the mouse.
Simple command set and live preview allows easy application of 3D info by users.
Single command applies 3D data from the library set to existing layouts.
Import custom 3D models via the standard *.3ds file format.
Simulation (ProSPICE/VSM)
New Simulation Advisor
Structured simulation message display
Colour coded messaging according to severity.
Messages carry source and timecode information.
Where appropriate, you can cross-probe back to the source component or net.
Error messages carry context sensitive help to assist with troubleshooting problems.
New Simulation Diagnostics System
Provides full control over which trace modes are enabled for a simulation run.
Detailed diagnostic information available for system messages, CPU's and peripheral devices.
Diagnostics can be enabled at warning, trace or debug levels for each grouping.
Invaluable debugging aid allowing full textual reporting on simulation activity.
Enhanced, Industrial Grade Instrumentation
New Oscilloscope instrument including cursors, printing, one-shot modes, etc.
New Logic Analyser instrument including cursors, printing, one-shot modes, etc.
New Microcontrollers
Proteus VSM for PIC24 - This is a separately licensed product. .
Proteus VSM for ARM7 extended with LPC2131/2/4/6/8 and LPC2101/2/3 variants.
Proteus VSM for PIC18 extended with PIC18F24J10/44J10/25J10/45J10 variants.
Proteus VSM for PIC16 extended with PIC16F877A/876A/874A/873A variants.
New, Advanced Peripheral Models
New modesl for ENC28J10 and RTL8019AS Ethernet Controllers.
Hundreds of new embedded peripherals added - more information here.
Proteus Design Suite 7.1 is available free of charge to all customers whose USC is valid as of 01st February 2007.
Последний раз редактировалось avr123.nm.ru 05 мар 2007, 16:07, всего редактировалось 1 раз.
Сообщение avr123.nm.ru » 05 мар 2007, 15:36
http://www.labcenter.co.uk/index.html?/ ... herals.htm
Instrumentation and Analysis Tools
4 канальный цифровой осциллограф !!!
4-channel DSO with X-Y operation, AC or DC coupled inputs and measurement cursors
40-Channel Logic Analyser with a 40000 x 52 bit capture buffer and measurement cursors
Counter/Timer instrument measures time intervals, signal frequency and pulse counts
RS232 Terminal with configurable baud rate,data bits,stop bits,parity and Rx/Tx Polarity
DC and AC Voltmeters display true RMS values integrated over a definable time constant
DC and AC Ammeters display true RMS values integrated over a definable time constant
Protocol Analysers
Interactive Circuit Stimulus Tools
Сообщение Nova_Project » 05 мар 2007, 16:19
У меня вот такую ошибку пишет при симуляции
Internal exception: Access violation in module "prospice.dll"
Real time simulatio failed to start
Nova_Project
Сообщение avr123.nm.ru » 05 мар 2007, 16:35
Вы что-то свое делаете или примеры ?
Я еще только примеры попробовал. Но уверен он должен нормально работать.
Глюков у ПРОТЕУСА всегда в избытке но  они обычно очевидные и их легко учесть.
Сообщение Nova_Project » 05 мар 2007, 17:41
avr123.nm.ru писал(а):Вы что-то свое делаете или примеры ?
Вот примеры какраз и запускал...
Nova_Project
Сообщение avr123.nm.ru » 05 мар 2007, 18:46
Я шахматы запускал ВСЕ.  И апноут микрочип AN696
Еще сеть one-wire  и  управление мотором L297 и L298
У вас что не работает ?
Причем полная версия 6.9 sp5  у меня осталась и тоже работает.
Сообщение GIGAWAT » 05 мар 2007, 22:56
2AVR123
А где бы посмотреть список моделируемых микроконтроллеров ?
Список переферии я уже посмотрел.
GIGAWAT
Сообщение Myp » 05 мар 2007, 22:58
вот злой 123avr не захотел посмотреть есть ли там L293 =/
может кто другой глянет? у кого установлен
если тут не написано значит нету??? =/
Последний раз редактировалось Myp 05 мар 2007, 23:12, всего редактировалось 1 раз.
Сообщение GIGAWAT » 05 мар 2007, 23:06
Так, список МК я нашел, моей mega169 там нету  :cry:
:?: Нет ли информации о наличии модели  mega169 для протэуса ?
GIGAWAT
Сообщение avr123.nm.ru » 05 мар 2007, 23:12
Myp писал(а):вот злой 123avr не захотел посмотреть есть ли там L293 =/
выше же линк на МОДЕЛИ имеющиеся.  L293 там НЕТ.
там другие драйверы.
Сообщение Myp » 05 мар 2007, 23:14
сообразил уже
яж не виноват что медленно соображаю=)
Сообщение avr123.nm.ru » 06 мар 2007, 01:46
http://www.pic16.com/down02/Proteus7.0.rar
вот вроде с крякой - НЕ ПРОВЕРЯЛ !
Сообщение avr123.nm.ru » 06 мар 2007, 16:59
Пример PROTEUS подключения двух семисегментных индикаторов через 74199 к микроконтроллеру занимая всего 2 ножки PIC.
ТАм же работа с АЦП PIC
PIC 12C671 ADC.rar
Сообщение Tracer » 13 мар 2007, 14:55
А М8 опять для корпуса TQFP не дописали?
Tracer
Сообщение bgn62 » 17 мар 2007, 06:38
В версии 7.0 изменена библиотека AVR.dll, при копировании ее в версию 6.9.5 под
именем  AVR_7_0.DLL и ссылкой в процессоре на нее требует “API Версии 1.41”.
может кто-нибудь знает, что это за штука и где ее взять?
Reading netlist...
ERROR: [U1] mixed model AVR_7_0.DLL failed to authorize - Requires API Version 1.41.
Читая netlist...
ОШИБКА: [U1] смешивал модель AVR_7_0.DLL потерпевшую неудачу, чтобы уполномочивать - Требует. API Версии 1.41
bgn62
Сейчас этот форум просматривают: Bing [Bot], Yandex [Bot] и гости: 2
