приводимый ниже конфиг открывает доступ на чтение запись по анонимному соединению в папку /home/ftp
у Вас есть эта папка ?
setar писал(а):приводимый ниже конфиг открывает доступ на чтение запись по анонимному соединению в папку /home/ftp
calculate ~ # calculate -d /dev/sda1 -s CLS --set-hostname=RF-dev --set-lang=ru_ RU --set-video_resolution="1024x768" --set-user_comment="Roboforum Build"
Installation Calculate Linux Scratch
Collecting system information
Computer name: RF-dev
Network devices: eth0 (DHCP)
Installed system: Calculate Linux Scratch 10.4
Hardware
Machine hardware name: i686
Language: ru_RU
Keymap: ru_RU
Timezone: UTC
Quantity processors: 1
Location
Working volume: ram
Installation volume: /dev/sda1
File system: reiserfs
Installation templates
Basic: 1default, 2locale, 3patch, 4deprecated, 5compatible, desktop
Perform pre-install checkups
Update found: Calculate Linux Scratch 10.4
Volume formatting will start through 10 seconds.
Press Ctrl+C to cancel...
Unpacking system
Formatting new volume... done.
Mounting new volume... done.
Unpacking system image into new volume...
ovr: 0:00:00 100% [========================================================================================================================================================================================]
done.
Update config
Apply template "install/1default"... done.
Apply template "install/2locale"... done.
Apply template "install/3patch"... done.
Apply template "install/4deprecated"... done.
Apply template "install/5compatible"... done.
Apply template "install/desktop"... done.
rm: cannot remove `/var/calculate/tmp/.tmp.1000268': Directory not empty
System setup
Update /etc/inittab... done.
Create new initrd file... done.
Remove unused localization... done.
Prepare system for reboot
Change boot record...sh: cannot create temp file for here-document: No space left on device
error.
Unmount installed system volume...error writing /etc/mtab.tmp: No space left on device
error.
calculate ~ #
Update config
System setup
error.
error.
calculate ~ # df -h
Filesystem Size Used Avail Use% Mounted on
rootfs 125M 125M 0 100% /
df: `/newroot': No such file or directory
df: `/newroot/mnt/cdrom': No such file or directory
df: `/newroot/mnt/livecd': No such file or directory
none 125M 125M 0 100% /
/dev/sr0 1.4G 1.4G 0 100% /mnt/cdrom
/dev/loop0 1.4G 1.4G 0 100% /mnt/livecd
rc-svcdir 1.0M 88K 936K 9% /lib/rc/init.d
udev 10M 208K 9.8M 3% /dev
shm 125M 0 125M 0% /dev/shm
df: `/mnt/install': No such file or directory
calculate ~ # mo
moc modinfo module-rebuild monitest more mount mount.fuse mount.nfs4 mountpoint mouse-test
mode3 modprobe mogrify montage most mount.cifs mount.nfs mount.ntfs-3g mount.vboxsf
calculate ~ # mount /mnt/
calculate/ cdrom/ floppy/ gentoo/ .keep key/ livecd/
calculate ~ # mkdir /mnt/test
calculate ~ # mount /dev/sda1 /mnt/test/
calculate ~ # df -h
/dev/sda1 20G 6.3G 14G 32% /mnt/test
calculate ~ #
>>> Downloading 'ftp://ftp.proftpd.org/distrib/source/proftpd-1.3.2d.tar.bz2'
--2011-07-26 09:47:14-- ftp://ftp.proftpd.org/distrib/source/proftpd-1.3.2d.tar.bz2
=> «/var/calculate/remote/distfiles/proftpd-1.3.2d.tar.bz2»
Распознаётся ftp.proftpd.org... 86.59.114.198
Устанавливается соединение с ftp.proftpd.org|86.59.114.198|:21... соединение установлено.
Выполняется вход под именем anonymous ... Выполнен вход в систему!
==> SYST ... готово. ==> PWD ... готово.
==> TYPE I ... готово. ==> CWD (1) /distrib/source ... готово.
==> SIZE proftpd-1.3.2d.tar.bz2 ... готово.
==> PASV ... готово. ==> RETR proftpd-1.3.2d.tar.bz2 ...
No such file «proftpd-1.3.2d.tar.bz2».
!!! Couldn't download 'proftpd-1.3.2d.tar.bz2'. Aborting.
* Fetch failed for 'net-ftp/proftpd-1.3.2d', Log file:
* '/var/calculate/tmp/portage/net-ftp/proftpd-1.3.2d/temp/build.log'
* Messages for package net-ftp/proftpd-1.3.2d:
* IMPORTANT: 1 news items need reading for repository 'gentoo'.
* Use eselect news to read news items.
RF-dev ~ # wget ftp://ftp.proftpd.org/distrib/source/proftpd-1.3.2d.tar.bz2
--2011-07-26 09:48:13-- ftp://ftp.proftpd.org/distrib/source/proftpd-1.3.2d.tar.bz2
=> «proftpd-1.3.2d.tar.bz2»
