AVR + WG12864A
AVR + WG12864A
Сообщение elesy » 16 окт 2010, 18:34
Народ прошу помощи!
Кто работал с данным дисплеем? Уже мозги сломал. Камень М128. Порт С - данные, порт В - управление. Пишу под пингвином. Код ниже
#include <avr/io.h>
#include "symbol.h"
#define DI   3
#define RW   4
#define E   2
#define CS1   6
#define   CS2   5
#define   RST   7
void pause(unsigned int a)
    unsigned int i;
    for (i=a; i>0; i--);
void lcd_dat(unsigned char data)
    PORTC  = data;
    PORTB |= _BV(E);
      asm("nop"); asm("nop");
    PORTB |= _BV(E);
    PORTB &= ~_BV(E);
    PORTB &= ~_BV(DI);
void lcd_com(unsigned char comm)
    PORTC = comm;
    PORTB |= _BV(E);
    PORTB &= ~_BV(E);
void gotoxy(unsigned char x, unsigned char y)
   if (x<64)
       PORTB |= _BV(CS1);
   else {
      PORTB |= _BV(CS2);
      x = x-64;
   lcd_com(0x40+x);
   lcd_com(0xb8+y/8);
void clear_screen(void)
    unsigned char i,j;
    PORTB |= _BV(CS1) | _BV(CS2);
    for (j=0; j<64; j++)
        lcd_com(0xb8+j);
        for (i=0; i<64;i++)
          lcd_dat(0x00);
void wg12864_init(void)
    DDRC  = 0xff;
    PORTC = 0x00;
    PORTB = _BV(RST)|_BV(CS1)|_BV(CS2);
    DDRB  = _BV(RST)|_BV(CS1)|_BV(CS2)|_BV(DI)|_BV(RW)|_BV(E);
    lcd_com(0x3f);
    lcd_com(0xc0);
    lcd_com(0x40);
    lcd_com(0xb8);
    clear_screen();
    PORTB &=~(_BV(CS1)|_BV(CS2));
void put_pixel(const unsigned char x, const unsigned char y, const unsigned char color)
   unsigned char temp=0;
   PORTB = _BV(RST);
   if ((x>128)||(y>64)) return;
   gotoxy(x,y);
   PORTC = 0xff;
   DDRC  = 0x00;
   PORTB |= (_BV(RW)|_BV(DI));
   pause(8);
   PORTB |= _BV(E);
   PORTB &= ~_BV(E);
   PORTB |= _BV(E);
     temp = PORTC;
   PORTB &= ~_BV(E);
   if (color==1) temp |= _BV(y%8);
   else temp &= ~_BV(y%8);
   PORTB &= ~(_BV(RW)|_BV(DI));
   DDRC  = 0xff;
   gotoxy(x,y);
   lcd_dat(temp);
   PORTB = _BV(RST);
int sign(int x)
    if (x<0) return -1;
    if (x>0) return 1;
    return 0;
int abs(int x)
   if (x<0) return -x;
   else return x;
void line(unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2, unsigned char color)
void rectangle(unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2, unsigned char color)
void put_char(unsigned char x0, unsigned char y0, unsigned char code, unsigned char mode)
   unsigned char i,x,y;
   x = x0;
   y = y0;
   PORTB = _BV(RST)|_BV(CS1);
   if((x>128)||(y>64)) return;
   for(i=0; i<6; i++) {
      if (x>=64) {
         x = x-64;
         PORTB |= _BV(CS2);
         PORTB &= ~_BV(CS1);
      lcd_com(0x40+x);
      lcd_com(0xb8+y);
      if (i<=4) {
         if (mode == 1)
             lcd_dat(~sym[code][i]);
         else
             lcd_dat(sym[code][i]);
      if (i==5) {
         if (mode==1)
             lcd_dat(0xff);
         else
             lcd_dat(0x00);
      x = x+1;
int main(void)
   unsigned char data[10]={0x24,0x39,0x35,0x2f,0x24,0x25,0x86,0x26,0x32,0x30};
   unsigned char data2[8]={0x20,0x10,0x01,0x02,0x08,0x06,0x04,0x0a};
   unsigned char i;
   pause(40000);
   wg12864_init();
   for (i=0; i<10; i++)
       put_char(10+6*i, 1, data[i],1);
   for (i=0; i<8; i++)
       put_char(10+6*i, 3, data2[i], 0);
   for(;;)
[/code]
[code]
const char sym[][5] =
{0x3e,0x51,0x49,0x45,0x3e},   //0x00<==>0
{0x00,0x42,0x7f,0x40,0x00},   //0x01<==>1
{0x42,0x61,0x51,0x49,0x46},   //0x02<==>2
{0x21,0x41,0x45,0x4b,0x31},   //0x03<==>3
{0x18,0x14,0x12,0x7f,0x10},   //0x04<==>4
{0x27,0x45,0x45,0x45,0x39},   //0x05<==>5
{0x3c,0x4a,0x49,0x49,0x30},   //0x06<==>6
{0x01,0x71,0x09,0x05,0x03},   //0x07<==>7
{0x36,0x49,0x49,0x49,0x36},   //0x08<==>8
{0x06,0x49,0x49,0x29,0x1e},   //0x09<==>9
{0x7e,0x11,0x11,0x11,0x7e},    //0x0a<==>A
{0x7f,0x49,0x49,0x49,0x36},   //0x0b<==>B
{0x3e,0x41,0x41,0x41,0x22},   //0x0c<==>C
{0x7f,0x41,0x41,0x22,0x1c},   //0x0d<==>D
{0x7f,0x49,0x49,0x49,0x41},   //0x0e<==>E
{0x7f,0x09,0x09,0x09,0x01},   //0x0f<==>F
{0x3e,0x41,0x49,0x49,0x3a},   //0x10<==>G
{0x7f,0x08,0x08,0x08,0x7f},   //0x11<==>H
{0x00,0x41,0x7f,0x41,0x00},   //0x12<==>I
{0x20,0x40,0x41,0x3f,0x01},   //0x13<==>J
{0x7f,0x08,0x14,0x22,0x41},   //0x14<==>K
{0x7f,0x40,0x40,0x40,0x40},   //0x15<==>L
{0x7f,0x02,0x0c,0x02,0x7f},   //0x16<==>M
{0x7f,0x04,0x08,0x10,0x7f},   //0x17<==>N
{0x3e,0x41,0x41,0x41,0x3e},   //0x18<==>O
{0x7f,0x09,0x09,0x09,0x06},   //0x19<==>P
{0x3e,0x41,0x51,0x21,0x5e},   //0x1a<==>Q
{0x7f,0x09,0x19,0x29,0x46},   //0x1b<==>R
{0x46,0x49,0x49,0x49,0x31},   //0x1c<==>S
{0x01,0x01,0x7f,0x01,0x01},   //0x1d<==>T
{0x3f,0x40,0x40,0x40,0x3f},   //0x1e<==>U
{0x1f,0x20,0x40,0x20,0x1f},   //0x1f<==>V
{0x3f,0x40,0x70,0x40,0x3f},   //0x20<==>W
{0x63,0x14,0x08,0x14,0x63},   //0x21<==>X
{0x07,0x08,0x70,0x08,0x07},   //0x22<==>Y
{0x61,0x51,0x49,0x45,0x43},   //0x23<==>Z
{0x20,0x54,0x54,0x54,0x78},   //0x24<==>a
{0x7F,0x48,0x44,0x44,0x38},   //0x25<==>b
{0x38,0x44,0x44,0x44,0x20},   //0x26<==>c
{0x38,0x44,0x44,0x48,0x7F},   //0x27<==>d
{0x38,0x54,0x54,0x54,0x18},   //0x28<==>e
{0x08,0x7E,0x09,0x01,0x02},   //0x29<==>f
{0x0C,0x52,0x52,0x52,0x3E},   //0x2a<==>g
{0x7F,0x08,0x04,0x04,0x78},   //0x2b<==>h
{0x00,0x44,0x7D,0x40,0x00},   //0x2c<==>i
{0x20,0x40,0x44,0x3D,0x00},   //0x2d<==>j
{0x7F,0x10,0x28,0x44,0x00},   //0x2e<==>k
{0x00,0x41,0x7F,0x40,0x00},   //0x2f<==>l
{0x7C,0x04,0x18,0x04,0x78},   //0x30<==>m
{0x7C,0x08,0x04,0x04,0x78},   //0x31<==>n
{0x38,0x44,0x44,0x44,0x38},   //0x32<==>o
{0x7C,0x14,0x14,0x14,0x08},   //0x33<==>p
{0x08,0x14,0x14,0x18,0x7C},   //0x34<==>q
{0x7C,0x08,0x04,0x04,0x08},   //0x35<==>r
{0x48,0x54,0x54,0x54,0x20},   //0x36<==>s
{0x04,0x3F,0x44,0x40,0x20},   //0x37<==>t
{0x3C,0x40,0x40,0x20,0x7C},   //0x38<==>u
{0x1C,0x20,0x40,0x20,0x1C},   //0x39<==>v
{0x3C,0x40,0x30,0x40,0x3C},   //0x3a<==>w
{0x44,0x28,0x10,0x28,0x44},   //0x3b<==>x
{0x0C,0x50,0x50,0x50,0x3C},   //0x3c<==>y
{0x44,0x64,0x54,0x4C,0x44},   //0x3d<==>z
{0x7e,0x11,0x11,0x11,0x7e},   //0x3e<==>A
{0x7f,0x49,0x49,0x49,0x33},   //0x3f<==>Б
{0x7f,0x49,0x49,0x49,0x36},   //0x40<==>В
{0x7f,0x01,0x01,0x01,0x03},   //0x41<==>Г
{0x70,0x29,0x27,0x21,0x7f},   //0x42<==>Д
{0x7f,0x49,0x49,0x49,0x41},   //0x43<==>E
{0x77,0x08,0x7f,0x08,0x77},   //0x44<==>Ж
{0x41,0x49,0x49,0x49,0x36},   //0x45<==>З
{0x7f,0x10,0x08,0x04,0x7f},   //0x46<==>И
{0x7c,0x21,0x12,0x09,0x7c},   //0x47<==>Й
{0x7f,0x08,0x14,0x22,0x41},   //0x48<==>K
{0x20,0x41,0x3f,0x01,0x7f},   //0x49<==>Л
{0x7f,0x02,0x0c,0x02,0x7f},   //0x4a<==>M
{0x7f,0x08,0x08,0x08,0x7f},   //0x4b<==>H
{0x3e,0x41,0x41,0x41,0x3e},   //0x4c<==>O
{0x7f,0x01,0x01,0x01,0x7f},   //0x4d<==>П
{0x7f,0x09,0x09,0x09,0x06},   //0x4e<==>P
{0x3e,0x41,0x41,0x41,0x22},   //0x4f<==>C
{0x01,0x01,0x7f,0x01,0x01},   //0x50<==>T
{0x47,0x28,0x10,0x08,0x07},   //0x51<==>У
{0x1c,0x22,0x7f,0x22,0x1c},   //0x52<==>Ф
{0x63,0x14,0x08,0x14,0x63},   //0x53<==>X
{0x7f,0x40,0x40,0x40,0xff},   //0x54<==>Ц
{0x07,0x08,0x08,0x08,0x7f},   //0x55<==>Ч
{0x7f,0x40,0x7f,0x40,0x7f},   //0x56<==>Ш
{0x7f,0x40,0x7f,0x40,0xff},   //0x57<==>Щ
{0x01,0x7f,0x48,0x48,0x30},   //0x58<==>Ъ
{0x7f,0x48,0x30,0x00,0x7f},   //0x59<==>Ы
{0x00,0x7f,0x48,0x48,0x30},   //0x5a<==>Э
{0x22,0x41,0x49,0x49,0x3e},   //0x5b<==>Ь
{0x7f,0x08,0x3e,0x41,0x3e},   //0x5c<==>Ю
{0x46,0x29,0x19,0x09,0x7f},   //0x5d<==>Я
{0x20,0x54,0x54,0x54,0x78},   //0x5e<==>a
{0x3c,0x4a,0x4a,0x49,0x31},   //0x5f<==>б
{0x7c,0x54,0x54,0x28,0x00},   //0x60<==>в
{0x7c,0x04,0x04,0x04,0x0c},   //0x61<==>г
{0xe0,0x54,0x4c,0x44,0xfc},   //0x62<==>д
{0x38,0x54,0x54,0x54,0x18},   //0x63<==>e
{0x6c,0x10,0x7c,0x10,0x6c},   //0x64<==>ж
{0x44,0x44,0x54,0x54,0x28},   //0x65<==>з
{0x7c,0x20,0x10,0x08,0x7c},   //0x66<==>и
{0x7c,0x41,0x22,0x11,0x7c},   //0x67<==>й
{0x7c,0x10,0x28,0x44,0x00},   //0x68<==>к
{0x20,0x44,0x3c,0x04,0x7c},   //0x69<==>л
{0x7c,0x08,0x10,0x08,0x7c},   //0x6a<==>м
{0x7c,0x10,0x10,0x10,0x7c},   //0x6b<==>н
{0x38,0x44,0x44,0x44,0x38},   //0x6c<==>o
{0x7c,0x04,0x04,0x04,0x7c},   //0x6d<==>п
{0x7C,0x14,0x14,0x14,0x08},   //0x6e<==>p
{0x38,0x44,0x44,0x44,0x20},   //0x6f<==>c
{0x04,0x04,0x7c,0x04,0x04},   //0x70<==>т
{0x0C,0x50,0x50,0x50,0x3C},   //0x71<==>у
{0x30,0x48,0xfc,0x48,0x30},   //0x72<==>ф
{0x44,0x28,0x10,0x28,0x44},   //0x73<==>x
{0x7c,0x40,0x40,0x40,0xfc},   //0x74<==>ц
{0x0c,0x10,0x10,0x10,0x7c},   //0x75<==>ч
{0x7c,0x40,0x7c,0x40,0x7c},   //0x76<==>ш
{0x7c,0x40,0x7c,0x40,0xfc},   //0x77<==>щ
{0x04,0x7c,0x50,0x50,0x20},   //0x78<==>ъ
{0x7c,0x50,0x50,0x20,0x7c},   //0x79<==>ы
{0x7c,0x50,0x50,0x20,0x00},   //0x7a<==>ь
{0x28,0x44,0x54,0x54,0x38},   //0x7b<==>э
{0x7c,0x10,0x38,0x44,0x38},   //0x7c<==>ю
{0x08,0x54,0x34,0x14,0x7c},   //0x7d<==>я
{0x08,0x08,0x3E,0x08,0x08},   //0x7e<==>+
{0x00,0x50,0x30,0x00,0x00},   //0x7f<==>,
{0x08,0x08,0x08,0x08,0x08},   //0x80<==>-
{0x20,0x10,0x08,0x04,0x02},   //0x81<==>/
{0x23,0x13,0x08,0x64,0x62},   //0x82<==>%
{0x00,0x36,0x36,0x00,0x00},   //0x83<==>:
{0x00,0x00,0x02,0x05,0x02},   //0x84<==>"
{0x00,0x00,0x00,0x00,0x00},   //0x85<==>пробел
{0x00,0x60,0x60,0x00,0x00}    //0x86<==>.
[/code]
[code]
MCU     = atmega128
CC      = avr-gcc
OBJCOPY = avr-objcopy
CFLAGS  = -mcall-prologues -Os -mmcu=$(MCU) -Wall -Wstrict-prototypes
all: glcd_rom.hex
clean:
      rm -f *.o *.out *.map glcd_rom.hex
glcd_rom.hex: glcd.out
      $(OBJCOPY) -R .eeprom -O ihex glcd.out glcd_rom.hex
glcd.out: glcd.o
      $(CC) $(CFLAGS) -o glcd.out -Wl,-Map,glcd.map,--cref glcd.o
glcd.o: glcd.c symbol.h
      $(CC) $(CFLAGS) -c glcd.c
Кто может подсказать куда копать?
elesy
ФИО: Зайцев Иван Алексеевич
Re: AVR + WG12864A
Сообщение Romikgy » 16 окт 2010, 19:38
Romikgy
Re: AVR + WG12864A
Сообщение elesy » 16 окт 2010, 19:55
Я оттуда и взял код
elesy
Re: AVR + WG12864A
Сообщение Romikgy » 16 окт 2010, 22:48
тогда что не работает ?
Romikgy
Re: AVR + WG12864A
Сообщение elesy » 18 окт 2010, 07:09
Перепроверил все. Нашел Ошибку в распайке - исправил. Сейчас экран засвечиваеться , но одна половина чистая, на второй мусор.
elesy
Re: AVR + WG12864A
Сообщение Romikgy » 18 окт 2010, 10:30
если с распайкой всего остального все ок.... тогда косяк с адресацией....ИМХО
Romikgy
Re: AVR + WG12864A
Сообщение elesy » 18 окт 2010, 11:13
Romikgy писал(а):если с распайкой всего остального все ок.... тогда косяк с адресацией....ИМХО
Пожалуйста поподробнее
elesy
Re: AVR + WG12864A
Сообщение Romikgy » 18 окт 2010, 11:37
в минимуме проверить CS1, CS2 .... т.к. это почти что 2 девайса в одном... и каждый девайс обслуживает свою половину экрана....
Romikgy
