Есть исходник для Bascom AVR, не понятно за что отвечают переменные Steeringrear и Steeringfront.
Еще не ясно что значит Reset Motor?
Подскажите пожалуйста.
- $regfile = "attiny44.dat"
 $crystal = 8000000
 $framesize = 32
 $hwstack = 64
 $swstack = 48
 Waitms 100
 Dim Diff As Long 'Difference between target position and measured position
 Dim Difflast As Long 'Previous Difference value
 Dim Prop As Single 'Proportional Value
 Dim Integral As Single 'Integral Value
 Dim Deriv As Single 'Derivative Value
 Dim Rate As Single 'Rate calculation used for Derivative
 Dim Control As Single 'Calculated value used to control steering
 Dim Mpos As Long 'Measured Position
 Dim Sensors As Byte 'Byte used to hold sensor values
 Dim I As Long , X As Long , Temp As Single , Mystr As String * 16
 Dim Tlong As Long , Myint As Integer
 'Aliases
 Speed Alias Pwm1a
 Motor Alias Porta.7
 Steeringfront Alias Servo(2)
 Steeringrear Alias Servo(1)
 'PID Constants
 Const Kp = 4.5 'Gain factor for proportional
 Const Kd = .4 'Gain factor for derivitive
 Const Ki = .1 'Gain Factor for Integral
 Const Interval = .01 'Not used
 Const Tpos = 0 'Target position of sensors
 Const Upperlimit = 30 'Maximum control value
 Const Lowerlimit = -30 'Minimum control value
 'Other Constants '
 Const Scenterf = 101
 Const Scenterr = 105
 Const Fast = 650
 Const Medium = 640
 Const Slow = 600
 Const Nogo = 512
 'Configuration Statements
 Config Timer1 = Pwm , Prescale = 1 , Pwm = 10 , Compare A Pwm = Clear Down , Compare B Pwm = Disconnect
 Config Servos = 2 , Servo1 = Portb.0 , Servo2 = Portb.1 , Reload = 8
 'Config Ports
 Config Porta = Input
 Config Porta.6 = Output
 Config Porta.7 = Output
 Config Portb = Output
 'Turn on Internal Pullups
 Porta = &B00011111
 'Turn off Motor
 Set Motor
 Speed = Nogo
 'Enable everything
 Enable Timer1
 Enable Interrupts
 Steeringfront = Scenterf
 Steeringrear = Scenterr
 Wait 2
 Difflast = 0
 Reset Motor
 Speed = Medium
 Do
 Sensors = Not Pina
 Sensors = Sensors And &B00011111
 Select Case Sensors
 Case &B00001 'Right most sensor
 Mpos = 4
 'Speed = Slow
 Case &B00011 'Right Sensors
 Mpos = 3
 Case &B00010 'Right Mid sensor
 Mpos = 2
 Case &B00111 'Center Right
 Mpos = 1
 Case &B00110 'Center Right
 Mpos = 1
 Case &B00100 'Centered on the line
 Mpos = 0
 Case &B01100 'Center Left
 Mpos = -1
 Case &B11100 'Center Left
 Mpos = -1
 Case &B01000 ' Left Mid Sensor
 Mpos = -2
 Case &B11000 ' Left sensors
 Mpos = -3
 Case &B10000 'Left most sensor
 Mpos = -4
 Case &B00000 'lost line
 If Mpos < 0 Then Mpos = -5 Else Mpos = 5
 End Select
 Diff = Tpos - Mpos
 Prop = Diff * Kp 'Calculate Proportional
 Integral = Integral + Diff 'Calculate Integral
 Integral = Integral * Ki
 Rate = Diff - Difflast 'Calculate Differential
 Deriv = Rate * Kd
 Difflast = Diff
 Control = Prop + Deriv 'New control value
 Control = Control + Integral
 If Control > Upperlimit Then Control = Upperlimit 'Keep within safe range
 If Control < Lowerlimit Then Control = Lowerlimit
 Temp = Scenterf - Control
 Myint = Temp 'Convert Single to Integer
 Steeringfront = Myint
 Temp = Scenterr + Control
 Myint = Temp
 Steeringrear = Myint 'Convert Single to Integer
 Waitms 5 'wait 5ms between loops (200 times a second)
 Loop
 End
Добавлено спустя 2 часа 19 минут 12 секунд:
Тишина...
Бейсик никто не знает?
Выложить тоже самое, но переделанное на C?
