Лайнтрейсер с ПИД алгоритмом. Вопросы по исходнику.
Сообщение osc » 28 сен 2010, 23:13
Здравствуйте!
Есть исходник для Bascom AVR, не понятно за что отвечают переменные Steeringrear и Steeringfront.
Еще не ясно что значит Reset Motor?
Подскажите пожалуйста.
$regfile = "attiny44.dat"
$crystal = 8000000
$framesize = 32
$hwstack = 64
$swstack = 48
Waitms 100
Dim Diff As Long                                            'Difference between target position and measured position
Dim Difflast As Long                                        'Previous Difference value
Dim Prop As Single                                          'Proportional Value
Dim Integral As Single                                      'Integral Value
Dim Deriv As Single                                         'Derivative Value
Dim Rate As Single                                          'Rate calculation used for Derivative
Dim Control As Single                                       'Calculated value used to control steering
Dim Mpos As Long                                            'Measured Position
Dim Sensors As Byte                                         'Byte used to hold sensor values
Dim I As Long , X As Long , Temp As Single , Mystr As String * 16
Dim Tlong As Long , Myint As Integer
'Aliases
Speed Alias Pwm1a
Motor Alias Porta.7
Steeringfront Alias Servo(2)
Steeringrear Alias Servo(1)
'PID Constants
Const Kp = 4.5                                              'Gain factor for proportional
Const Kd = .4                                               'Gain factor for derivitive
Const Ki = .1                                               'Gain Factor for Integral
Const Interval = .01                                        'Not used
Const Tpos = 0                                              'Target position of sensors
Const Upperlimit = 30                                       'Maximum control value
Const Lowerlimit = -30                                      'Minimum control value
'Other Constants                                           '
Const Scenterf = 101
Const Scenterr = 105
Const Fast = 650
Const Medium = 640
Const Slow = 600
Const Nogo = 512
'Configuration Statements
Config Timer1 = Pwm , Prescale = 1 , Pwm = 10 , Compare A Pwm = Clear Down , Compare B Pwm = Disconnect
Config Servos = 2 , Servo1 = Portb.0 , Servo2 = Portb.1 , Reload = 8
'Config Ports
Config Porta = Input
Config Porta.6 = Output
Config Porta.7 = Output
Config Portb = Output
'Turn on Internal Pullups
Porta = &B00011111
'Turn off Motor
Set Motor
Speed = Nogo
'Enable everything
Enable Timer1
Enable Interrupts
Steeringfront = Scenterf
Steeringrear = Scenterr
Wait 2
Difflast = 0
Reset Motor
Speed = Medium
Do
      Sensors = Not Pina
      Sensors = Sensors And &B00011111
      Select Case Sensors
         Case &B00001                                       'Right most sensor
         Mpos = 4
         'Speed = Slow
         Case &B00011                                       'Right Sensors
         Mpos = 3
         Case &B00010                                       'Right Mid sensor
         Mpos = 2
         Case &B00111                                       'Center Right
         Mpos = 1
         Case &B00110                                       'Center Right
         Mpos = 1
         Case &B00100                                       'Centered on the line
         Mpos = 0
         Case &B01100                                       'Center Left
         Mpos = -1
         Case &B11100                                       'Center Left
         Mpos = -1
         Case &B01000                                       ' Left Mid Sensor
         Mpos = -2
         Case &B11000                                       ' Left sensors
         Mpos = -3
         Case &B10000                                       'Left most sensor
         Mpos = -4
         Case &B00000                                       'lost line
         If Mpos < 0 Then Mpos = -5 Else Mpos = 5
      End Select
   Diff = Tpos - Mpos
   Prop = Diff * Kp                                         'Calculate Proportional
   Integral = Integral + Diff                               'Calculate Integral
   Integral = Integral * Ki
   Rate = Diff - Difflast                                   'Calculate Differential
   Deriv = Rate * Kd
   Difflast = Diff
   Control = Prop + Deriv                                   'New control value
   Control = Control + Integral
   If Control > Upperlimit Then Control = Upperlimit        'Keep within safe range
   If Control < Lowerlimit Then Control = Lowerlimit
   Temp = Scenterf - Control
   Myint = Temp                                             'Convert Single to Integer
   Steeringfront = Myint
   Temp = Scenterr + Control
   Myint = Temp
   Steeringrear = Myint                                     'Convert Single to Integer
   Waitms 5                                                 'wait 5ms between loops (200 times a second)
Loop
End
Добавлено спустя 2 часа 19 минут 12 секунд:
Тишина...
Бейсик никто не знает?
Выложить тоже самое, но переделанное на C?
osc
прог. языки: c, c#
ФИО: Евгений
Re: Лайнтрейсер с ПИД алгоритмом. Вопросы по исходнику.
Сообщение EdGull » 28 сен 2010, 23:49
Reset это установка в 0
Для чего нужны эти переменные нужно спрашивать у автора или читать комментарии
Добавлено спустя 2 минуты 19 секунд:
alias он и в африке алиас
или не понятно что такое серва?
Сообщение osc » 29 сен 2010, 17:59
EdGull, я конкретно спросил что не понятно, не надо гадать.
PS: разобрался.
Последний раз редактировалось osc 30 сен 2010, 16:57, всего редактировалось 1 раз.
osc
прог. языки: c, c#
ФИО: Евгений
Сообщение Radist » 29 сен 2010, 22:25
Не нравятся мне такие вопрошающие. Наезды безличные (типа простого бейсика мы не знаем), наезды личные. А ну как и мой ответ топикстартеру не понравится и меня он пошлет лесом? Неприятно.
Насколько я понял, в качестве моторов используются сервы, переделанные на постоянное вращение. Из названий переменных можно вычленить слова "перед" и "зад". А также есть установка серв в центральное положение, что эквивалентно останову. Вот что эти переменные означают (на мой взгляд). А в проге я не разбирался - мне не хочется тратить время на грубияна. ПИД алгоритм - он и в Африке ПИД алгоритм, его можно на любом языке реализовать.
Radist
прог. языки: асемблер AVR
Сообщение osc » 30 сен 2010, 17:00
Radist, спасибо за исчерпывающий ответ, разобрался, те самые переменные это вроде define в си.
osc
прог. языки: c, c#
ФИО: Евгений
