mini2440 подготовка рабочего места к связи с устройством
Re: mini2440 подготовка рабочего места к связи с устройством
Сообщение setar » 04 окт 2010, 17:26
rotax писал(а):1. как сделать так чтобы при загрузке поднимался автоматически wlan интерфейс и как сделать так чтобы сетевые настройки сохранялись после перезагрузки?
правим /etc/conf.d/net :
# VLAN (802.1q support)
# For VLAN support, emerge net-misc/vconfig
# Specify the VLAN numbers for the interface like so
# Please ensure your VLAN IDs are NOT zero-padded
#vlans_eth0="1 2"
# You may not want to assign an IP the the physical interface, but we still
# need it up.
#config_eth0=( "null" )
# You can also configure the VLAN - see for vconfig man page for more details
#vconfig_eth0=( "set_name_type VLAN_PLUS_VID_NO_PAD" )
#vconfig_vlan1=( "set_flag 1" "set_egress_map 2 6" )
#config_vlan1=( "172.16.3.1 netmask 255.255.254.0" )
#config_vlan2=( "172.16.2.1 netmask 255.255.254.0" )
# NOTE: Vlans can be configured with a . in their interface names
# When configuring vlans with this name type, you need to replace . with a _
#config_eth0.1=( "dhcp" ) - does not work
#config_eth0_1=( "dhcp" ) - does work
# NOTE: Vlans are controlled by their physical interface and not per vlan
# This means you do not need to create init scripts in /etc/init.d for each
# vlan, you must need to create one for the physical interface.
# If you wish to control the configuration of each vlan through a separate
# script, or wish to rename the vlan interface to something that vconfig
# cannot then you need to do this.
#vlan_start_eth0="no"
# If you do the above then you may want to depend on eth0 like so
# RC_NEED_vlan1="net.eth0"
# NOTE: depend functions only work in /etc/conf.d/net
# and not in profile configs such as /etc/conf.d/net.foo
вот моя типовая настройка :
vlans_eth0="1 2"
config_eth0="null"
vconfig_eth0="set_name_type VLAN_PLUS_VID_NO_PAD"
config_vlan1="192.168.0.19/24"
routes_vlan1="default via 192.168.0.1"
config_vlan2="null"
Добавлено спустя 5 минут:
rotax писал(а):2. как сделать чтобы xfce запускался автоматически?
:) изврат, вам всё равно только в тексте работать
это делается установкой какого нибудь менеджера например xdm
Добавлено спустя 3 минуты 6 секунд:
rotax писал(а):3. после загрузки linux-a системное время переводится на 4 часа назад, как решить эту проблемму?
убедиться что линк /etc/localtime ведет на нужный файл зоны (например /usr/share/zoneinfo/Europe/Moscow)
или
/etc/conf.d/hwclock
clock="UTC" заменить на clock="local"
Добавлено спустя 5 минут 26 секунд:
rotax писал(а):4. панель задач в xfce выглядит как окошко с полосой заголовка и 4-я кнопками (свер. расп. мин. закр.) как привести ее в нормальный вид?
поставить xfce, в системе её как бы нету , это лишь зависимости частичные подтянутые другими пакетами
Добавлено спустя 1 минуту 57 секунд:
rotax писал(а):5. не удается прикрутить bluetooth мышь, система ее обнаруживает однако для подключения необходим пакет bluez, когда устанавливаю его emerge -v bluez, установка проходит как бы нормально без ошибок однако потом появляется сообщение что данного пакета в моей системе не обнаружено, так же при начале установки выводится размер данного пакета 0В. это глюк репозитария или я чего то не так делаю?
пакет bluez 975кб
сделаете сначала emerge --sync
Сообщение =DeaD= » 31 окт 2010, 14:36
setar писал(а):настроим сеть
# net-setup eth0
выбираем сеть тип «wired» и параметры чтобы подключиться к вашей домашней сети (фиксированый ip или dhcp)
Это обязательный пункт? У меня инет через VPN хитровыдуманный на этой же машинке.
Сообщение galex1981 » 01 ноя 2010, 08:17
Просто если нужна сеть, то пункт обязательный...
Сообщение =DeaD= » 01 ноя 2010, 09:27
Вот я и не знаю - нужна потом сеть для скачивания всяких пакетов или нет :pardon:
Сообщение galex1981 » 01 ноя 2010, 09:29
Для скачивания пакетов из репозитория конечно нужна!
Сообщение =DeaD= » 01 ноя 2010, 09:30
Блин! А мне понадобится что-то скачивать? :D
Сообщение galex1981 » 01 ноя 2010, 09:33
Как пользователю может и нет, если использовать готовую RootFs со всеми пакетами, если что то добавлять, то понадобится
Сообщение =DeaD= » 01 ноя 2010, 09:49
Так я и пытаюсь узнать - мне чтобы сделать всё что setar написал надо будет сеть или нет? :)
Сообщение galex1981 » 01 ноя 2010, 09:57
Для тогоо что Setar написал сеть точно нужна будет.
Сообщение setar » 01 ноя 2010, 11:29
нужна будет по любому :)
Сообщение =DeaD= » 01 ноя 2010, 11:57
Ок, значит буду мучать, а то что описано - это к реальной сетевой подключаемся?
Там вроде еще какая-то схема была, когда создаём виртуальную сетевую между виндой и линуксом.
Сообщение setar » 01 ноя 2010, 12:05
как это сделано в виртуалке не важно (это уже нужно решать отдельно)
с точки зрения виртуального компа у нас в системе физическая проводная сетевая карта, её и настраиваем
я делаю проброс (соединение мост) на airport (wifi карту)
Сообщение =DeaD= » 01 ноя 2010, 12:35
Я к тому что когда указанным способом я завожу в виртуалке сеть это будет в самой винде еще одна новая виртуальная сетевая видимая как реальная или виртуалка поработит мою обычную сетевуху?
Сообщение galex1981 » 01 ноя 2010, 13:17
Еще одна новая виртуалка...
Сообщение newegor » 20 ноя 2010, 22:04
Не могу правильно настроить proftpd для доступа из сети по ftp. Файл конфига брал от сюда, вот что в логе клиента:
Команда: USER anonymous
Ответ: 331 Анонимное подключение, укажите ваш e-mail адрес в качестве пароля
Команда: PASS **************
Ответ: 530-Unable to set anonymous privileges.
Ответ: 530 Login Failed.
Ошибка: Критическая ошибка
Ошибка: Невозможно подключиться к серверу
А вот что в логе proftpd:
Ноя 20 20:44:54 RF-dev proftpd[8691] 127.0.0.1: ProFTPD 1.3.3c (maint) (built Сбт Ноя 20 2010 20:39:08 MSK) standalone mode STARTUP
Ноя 20 20:46:11 RF-dev proftpd[8698] 127.0.0.1 (::ffff:192.168.1.3[::ffff:192.168.1.3]): ExtendedLog '/var/log/proftpd/extended.log' uses unknown format nickname 'default'
Ноя 20 20:46:11 RF-dev proftpd[8698] 127.0.0.1 (::ffff:192.168.1.3[::ffff:192.168.1.3]): FTP session opened.
Ноя 20 20:46:11 RF-dev proftpd[8698] 127.0.0.1 (::ffff:192.168.1.3[::ffff:192.168.1.3]): ftp: Directory ~ftp/ is not accessible.
Ноя 20 20:46:11 RF-dev proftpd[8698] 127.0.0.1 (::ffff:192.168.1.3[::ffff:192.168.1.3]): FTP session closed.
Ноя 20 20:56:08 RF-dev proftpd[17381] 127.0.0.1 (::ffff:192.168.1.3[::ffff:192.168.1.3]): ExtendedLog '/var/log/proftpd/extended.log' uses unknown format nickname 'default'
Ноя 20 20:56:08 RF-dev proftpd[17381] 127.0.0.1 (::ffff:192.168.1.3[::ffff:192.168.1.3]): FTP session opened.
Ноя 20 20:56:08 RF-dev proftpd[17381] 127.0.0.1 (::ffff:192.168.1.3[::ffff:192.168.1.3]): ftp: Directory ~ftp/ is not accessible.
Ноя 20 20:56:08 RF-dev proftpd[17381] 127.0.0.1 (::ffff:192.168.1.3[::ffff:192.168.1.3]): FTP session closed.
Что может быть не так?
newegor
Вернуться в mini2440
