Благодаря отличной работе почты я ста обладателем двух комплектов шасси вместо одного желаемого. Поэтому ненужный продаю. Собственно выглядит так:
Описание комплекта от китайского продавца:
100% Brand New.
    Size: 22 x 12xm(L x W); Wheel Size:6.5cm (Dia.) x 2.7cm (H)
    Mechanical structure is simple, it is easy to install.
    This car is the tachometer encoder
    With a 4 AA battery box and power switch. (Batteries not included.)
    Can be used for distance measurement, velocity.
    Can use with other devices to realize function of tracing, obstacle avoidance, distance testing, speed testing, wireless remote control.
    Gear Motor reduction radio: 1:48.
    Note: motor power supply is 3V~6V. All the parameter above is tested without load.
Package Content:
    1 x Car Chassis
    2 x Gear Motor(1:48)
    2 x Car Tire
    2 x Speed Encoder
    2 x Fastener
    1 x Universal Wheel
    1 x Battery Box (Batteries not included )
    All Necessary Screw And Nut
