loox писал(а):в чем собственно проблема?
почему не подходит?
Myp писал(а):у шильда управление от ардуины идёт через сдвиговый регистр с последовательным входом 74HCT595N
I have an arduino leonardo and motor shield v1.2, and they are not compatibles.
How can i connect both of them using a protoboard for use motor shield v1.2 in
Do you have any diagram to see how to map between leonardo pins and engine shield?
Thanks
It is more complicated than simply mapping pins. The AF_Motor Library uses timers to control the PWM frequency for speed control. You would need to modify the library and re-write the timer code to match the 32U4 timers in the Leonardo.
It would be much simpler to either use one of the compatible Arduinos (Mega 1280 & 2560, Diecimila, Duemilanove, and UNO) or switch to the V2 motor shield which works with all Arduinos.
