					roboforum.ruТехнический форум по робототехнике.  |
void init_spi(void)
  PCONP |= (1 << 8);   //Power ON
  /* Configure Pin Connect Block */
  PINSEL1|=0x0000003C; //MOSI & MISO
  PINSEL0|=0xC0000000; //SCK
  /* Set to highest speed for SPI at 10 MHz- > 1.25 MHz */
  //S0SPCCR=0x8;
  /* Device selected as master */
  //SPI Mode 3:
  //CPOL=1
  //CPHA=1
  //MASTER mode
  //MSB first
  S0SPCCR= 32;     //SPI clk = PCLK_SPI/S0SPCCR
  S0SPCR = 0x0838;  //830
char spi(char data)
{ char data_in;
  /* Write data out */
  S0SPDR=data;
  /* Wait for transfer to be completed */
  while ( !(S0SPSR & SPIF) );
  data_in=S0SPDR;
  return data_in;
}void SPI0Handler (void) __irq
  DWORD regValue;
  unsigned int data_spi;
  if (S0SPSR);                  // (dummy) read status register
  data_spi = S0SPDR;             // read data received
  S0SPDR   = spi_counter;        // next data to transmit
  S0SPINT  = 0x01;               // reset interrupt flag
  VICVectAddr = 0;               // reset VIC
  SPIdata=data_spi;
  SPIflag=1;
  spi_counter++;
void init_SPI( void )
  PCONP |= (1 << 8);   //SPI0 Power ON
  //S0SPCR = 0x00;
  PINSEL0|=(1U<<30)|(1U<<31); //SCK
  PINSEL1|=(1U<<0 )|(1U<<1 ); //SSEL
  PINSEL1|=(1U<<2 )|(1U<<3 ); //MISO
  PINSEL1|=(1U<<4 )|(1U<<5 ); //MOSI
  S0SPCCR = 0x8;       //Clock select - max clock speed = PLCK/8
  S0SPCR = 0x089C;       // 8 bit, CPHA=1, CPOL=1, slave mode, LSB first, interrupt enabled
           //0898
  if ( install_irq( SPI0_INT, (void *)SPI0Handler, HIGHEST_PRIORITY) == FALSE ) //Install IRQ
   printf("SPI IRQ install error!\n");
   while(1);
