grem@grem-laptop:~$ vlc
VLC media player 0.9.9a Grishenko
[00000001] main libvlc debug: VLC media player - version 0.9.9a Grishenko - (c) 1996-2009 the VideoLAN team
[00000001] main libvlc debug: libvlc was configured with ./configure '--build=i486-linux-gnu' '--enable-maintainer-mode' '--enable-release' '--prefix=/usr' '--enable-libtool' '--enable-fast-install' '--with-binary-version=2ubuntu1' '--disable-update-check' '--disable-gnome' '--disable-gtk' '--disable-familiar' '--disable-fb' '--enable-ggi' '--enable-sdl' '--enable-esd' '--enable-mad' '--enable-jack' '--enable-pulse' '--enable-lirc' '--enable-a52' '--enable-aa' '--enable-dvbpsi' '--enable-mozilla' '--with-mozilla-pkg=libxul-plugin' '--disable-kde' '--enable-mp4' '--enable-dvb' '--disable-satellite' '--enable-ogg' '--enable-vorbis' '--enable-shout' '--enable-qt4' '--disable-slp' '--enable-flac' '--disable-skins' '--disable-basic-skins' '--enable-skins2' '--enable-freetype' '--enable-mkv' '--enable-speex' '--enable-caca' '--enable-live555' '--enable-libmpeg2' '--enable-fribidi' '--enable-cdio' '--enable-mod' '--enable-theora' '--enable-modplug' '--enable-dvdnav' '--enable-gnutls' '--enable-ffmpeg' '--enable-ncurses' '--enable-smb' '--disable-gnomevfs' '--enable-bonjour' '--enable-mpc' '--enable-vcd' '--enable-vcdx' '--enable-notify' '--enable-twolame' '--enable-faad' '--disable-zvbi' '--enable-telx' '--enable-mediacontrol-bindings' '--disable-atmo' '--enable-taglib' '--enable-libass' '--enable-libdca' '--enable-realrtsp' '--disable-dv' '--enable-x264' '--enable-alsa' '--enable-v4l' '--enable-v4l2' '--enable-pvr' '--enable-svgalib' '--enable-dvd' '--without-dvdcss' 'build_alias=i486-linux-gnu' 'CFLAGS=-g -O2' 'LDFLAGS=-Wl,--as-needed' 'CPPFLAGS=' 'CXXFLAGS=-g -O2'
[00000001] main libvlc debug: translation test: code is "ru"
Bus error
vovan@vovan-laptop:~$ ssh vovan-pc.local
Last login: Fri Jun 19 22:09:37 2009 from vovan-laptop.local
vovan@vovan-pc:~$ vlc
[00000001] main libvlc debug: libvlc was configured with ./configure '--prefix=/usr' '--enable-dvdread' '--enable-jack' '--enable-dvdnav' '--disable-rpath' '--enable-qt4' '--enable-faad' '--enable-alsa' '--enable-skins2' '--enable-dvb' '--enable-v4l' '--enable-theora' '--enable-flac' '--enable-snapshot' '--enable-hal' '--enable-dbus' '--enable-ogg' '--enable-dbus-control' '--enable-shared' '--enable-nls' '--enable-lirc' '--enable-shout' '--enable-pvr' '--enable-release' '--program-suffix=' '--enable-realrtsp' '--enable-loader' '--enable-live555' '--with-live555-tree=/usr/lib/live-media' 'CFLAGS=-march=i686 -mtune=generic -O2 -pipe' 'CXXFLAGS=-march=i686 -mtune=generic -O2 -pipe' 'PKG_CONFIG_PATH=/usr/lib/pkgconfig:/opt/kde/lib/pkgconfig:/opt/qt/lib/pkgconfig'
[00000402] inhibit interface error: Failed to connect to the D-Bus session daemon: dbus-launch failed to autolaunch D-Bus session: Autolaunch error: X11 initialization failed.
[00000402] main interface error: no suitable interface module
[00000001] main libvlc error: interface "inhibit,none" initialization failed
[00000001] main libvlc: Запуск vlc с интерфейсом по умолчанию. Используйте 'cvlc' для запуска vlc без интерфейса.
[00000408] qt4 interface error: Could not connect to X server
[00000408] skins2 interface error: Cannot open display
[00000408] skins2 interface error: cannot initialize OSFactory
Интерфейс удаленного управления запущен. Введите 'help' для справки.
