tp-link:green:wps
Jan 1 00:00:33 OpenWrt kern.notice kernel: [ 6.530000] JFFS2 notice: (463) j ffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (0 un checked, 0 orphan) and 6 of xref (0 dead, 2 orphan) found.
Jan 1 00:00:33 OpenWrt kern.notice kernel: [ 7.290000] SCSI subsystem initia lized
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 7.460000] usbcore: registered new interface driver usbfs
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 7.460000] usbcore: registered new interface driver hub
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 7.460000] usbcore: registered new device driver usb
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 7.750000] ehci_hcd: USB 2.0 'Enha nced' Host Controller (EHCI) Driver
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 7.750000] ehci-platform ehci-plat form: Generic Platform EHCI Controller
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 7.750000] ehci-platform ehci-plat form: new USB bus registered, assigned bus number 1
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 7.780000] ehci-platform ehci-plat form: irq 3, io mem 0x1b000000
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 7.800000] ehci-platform ehci-plat form: USB 2.0 started, EHCI 1.00
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 7.800000] hub 1-0:1.0: USB hub fo und
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 7.800000] hub 1-0:1.0: 1 port det ected
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 7.810000] ohci_hcd: USB 1.1 'Open ' Host Controller (OHCI) Driver
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 7.820000] uhci_hcd: USB Universal Host Controller Interface driver
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 7.840000] Initializing USB Mass S torage driver...
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 7.840000] usbcore: registered new interface driver usb-storage
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 7.840000] USB Mass Storage suppor t registered.
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 19.950000] eth0: link up (100Mbps/ Full duplex)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 28.270000] eth0: link down
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 29.340000] Compat-wireless backpor t release: compat-wireless-2012-07-13
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 29.340000] Backport based on wirel ess-testing.git master-2012-07-16
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 29.340000] compat.git: wireless-te sting.git
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 29.450000] cfg80211: Calling CRDA to update world regulatory domain
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 29.450000] cfg80211: World regulat ory domain updated:
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 29.450000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 29.450000] cfg80211: (2402000 KH z - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 29.450000] cfg80211: (2457000 KH z - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 29.450000] cfg80211: (2474000 KH z - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 29.450000] cfg80211: (5170000 KH z - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 29.450000] cfg80211: (5735000 KH z - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.100000] cfg80211: World regulat ory domain updated:
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.100000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.100000] cfg80211: (2402000 KH z - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.100000] cfg80211: (2457000 KH z - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.100000] cfg80211: (2474000 KH z - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.100000] cfg80211: (5170000 KH z - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.100000] cfg80211: (5735000 KH z - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jan 1 00:00:33 OpenWrt kern.debug kernel: [ 30.390000] ath: EEPROM regdomain: 0x0
Jan 1 00:00:33 OpenWrt kern.debug kernel: [ 30.390000] ath: EEPROM indicates default country code should be used
Jan 1 00:00:33 OpenWrt kern.debug kernel: [ 30.390000] ath: doing EEPROM coun try->regdmn map search
Jan 1 00:00:33 OpenWrt kern.debug kernel: [ 30.390000] ath: country maps to r egdmn code: 0x3a
Jan 1 00:00:33 OpenWrt kern.debug kernel: [ 30.390000] ath: Country alpha2 be ing used: US
Jan 1 00:00:33 OpenWrt kern.debug kernel: [ 30.390000] ath: Regpair used: 0x3 a
Jan 1 00:00:33 OpenWrt kern.debug kernel: [ 30.400000] ieee80211 phy0: Select ed rate control algorithm 'minstrel_ht'
Jan 1 00:00:33 OpenWrt kern.debug kernel: [ 30.400000] Registered led device: ath9k-phy0
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.400000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.400000] cfg80211: Calling CRDA for country: US
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.400000] cfg80211: Regulatory do main changed to country: US
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.400000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.400000] cfg80211: (2402000 KH z - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.400000] cfg80211: (5170000 KH z - 5250000 KHz @ 40000 KHz), (300 mBi, 1700 mBm)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.400000] cfg80211: (5250000 KH z - 5330000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.400000] cfg80211: (5490000 KH z - 5600000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.400000] cfg80211: (5650000 KH z - 5710000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.400000] cfg80211: (5735000 KH z - 5835000 KHz @ 40000 KHz), (300 mBi, 3000 mBm)
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.780000] i2c /dev entries driver
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.910000] usbcore: registered new interface driver usbserial
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.910000] USB Serial support regi stered for generic
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.910000] usbcore: registered new interface driver usbserial_generic
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 30.910000] usbserial: USB Serial D river core
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 31.050000] Linux video capture int erface: v2.00
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 31.170000] USB Serial support regi stered for cp210x
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 31.170000] usbcore: registered new interface driver cp210x
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 31.170000] cp210x: v0.09:Silicon L abs CP210x RS232 serial adaptor driver
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 31.280000] USB Serial support regi stered for FTDI USB Serial Device
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 31.280000] usbcore: registered new interface driver ftdi_sio
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 31.280000] ftdi_sio: v1.6.0:USB FT DI Serial Converters Driver
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 31.390000] USB Serial support regi stered for pl2303
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 31.390000] usbcore: registered new interface driver pl2303
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 31.390000] pl2303: Prolific PL2303 USB to serial adaptor driver
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 31.540000] usbcore: registered new interface driver uvcvideo
Jan 1 00:00:33 OpenWrt kern.info kernel: [ 31.540000] USB Video Class driver (1.1.1)
Jan 1 00:00:34 OpenWrt daemon.notice netifd: Interface 'lan' is now up
Jan 1 00:00:34 OpenWrt daemon.notice netifd: Interface 'loopback' is now up
Jan 1 00:00:35 OpenWrt user.notice ifup: Enabling Router Solicitations on lan ( eth0)
Jan 1 00:00:35 OpenWrt kern.info kernel: [ 35.400000] eth0: link up (100Mbps/ Full duplex)
Jan 1 00:00:36 OpenWrt user.notice ifup: Enabling Router Solicitations on loopb ack (lo)
Jan 1 00:00:37 OpenWrt daemon.notice netifd: Interface 'wifi_sta' is now up
Jan 1 00:00:38 OpenWrt user.notice ifup: Enabling Router Solicitations on wifi_ sta (radio0)
Jan 1 00:00:38 OpenWrt authpriv.info dropbear[979]: Running in background
Jan 1 00:00:41 OpenWrt user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Jan 1 00:00:41 OpenWrt user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Jan 1 00:00:44 OpenWrt daemon.info dnsmasq[1218]: started, version 2.62 cachesi ze 150
Jan 1 00:00:44 OpenWrt daemon.info dnsmasq[1218]: compile time options: IPv6 GN U-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack
Jan 1 00:00:44 OpenWrt daemon.info dnsmasq-dhcp[1218]: DHCP, IP range 192.168.2 17.100 -- 192.168.217.249, lease time 12h
Jan 1 00:00:44 OpenWrt daemon.info dnsmasq[1218]: using local addresses only fo r domain lan
Jan 1 00:00:44 OpenWrt daemon.info dnsmasq[1218]: reading /tmp/resolv.conf.auto
Jan 1 00:00:44 OpenWrt daemon.info dnsmasq[1218]: using nameserver 192.168.1.1# 53
Jan 1 00:00:44 OpenWrt daemon.err dnsmasq[1218]: failed to load names from /etc /hosts: Permission denied
Jan 1 00:00:44 OpenWrt daemon.info dnsmasq-dhcp[1218]: read /etc/ethers - 0 add resses
Jan 1 00:00:44 OpenWrt daemon.notice ser2net[1230]: ser2net startup
Jan 1 00:00:44 OpenWrt user.info sysinit: stty: /dev/ttyUSB0: No such file or d irectory
Jan 1 00:00:44 OpenWrt user.info sysinit: stty: /dev/ttyUSB1: No such file or d irectory
Jan 1 00:00:44 OpenWrt user.info sysinit: stty: /dev/ttyUSB2: No such file or d irectory
Jan 1 00:00:44 OpenWrt user.info sysinit: stty: /dev/ttyUSB3: No such file or d irectory
Jan 1 00:00:44 OpenWrt user.info sysinit: stty: /dev/ttyUSB4: No such file or d irectory
Jan 1 00:00:44 OpenWrt user.info sysinit: stty: /dev/ttyUSB5: No such file or d irectory
Jan 1 00:00:45 OpenWrt user.info sysinit: setting up led USB
Jan 1 00:00:45 OpenWrt user.info sysinit: sh: write error: Invalid argument
Jan 1 00:00:45 OpenWrt user.info sysinit: /etc/rc.common: eval: line 1: can't c reate /sys/class/leds/tp-link:green:3g/device_name: nonexistent directory
Jan 1 00:00:45 OpenWrt user.info sysinit: /etc/rc.common: eval: line 1: can't c reate /sys/class/leds/tp-link:green:3g/activity_interval: nonexistent directory
Jan 1 00:00:45 OpenWrt user.info sysinit: setting up led WLAN
Jan 1 00:00:45 OpenWrt user.info sysinit: setting up led LAN
Jan 1 00:03:01 OpenWrt authpriv.info dropbear[1461]: Child connection from 192. 168.217.2:1841
Jan 1 00:03:13 OpenWrt authpriv.notice dropbear[1461]: Password auth succeeded for 'root' from 192.168.217.2:1841
Jan 1 00:03:19 OpenWrt kern.info kernel: [ 199.900000] usb 1-1: new high-speed USB device number 2 using ehci-platform
Jan 1 00:03:25 OpenWrt kern.err kernel: [ 205.020000] usb 1-1: device descript or read/64, error -71
Jan 1 00:03:25 OpenWrt kern.err kernel: [ 205.260000] usb 1-1: device descript or read/64, error -71
Jan 1 00:03:25 OpenWrt kern.info kernel: [ 205.490000] usb 1-1: new high-speed USB device number 3 using ehci-platform
Jan 1 00:03:25 OpenWrt kern.err kernel: [ 205.620000] usb 1-1: device descript or read/64, error -71
Jan 1 00:03:25 OpenWrt kern.err kernel: [ 205.860000] usb 1-1: device descript or read/64, error -71
Jan 1 00:03:26 OpenWrt kern.info kernel: [ 206.090000] usb 1-1: new high-speed USB device number 4 using ehci-platform
Jan 1 00:03:26 OpenWrt kern.err kernel: [ 206.510000] usb 1-1: device not acce pting address 4, error -71
Jan 1 00:03:26 OpenWrt kern.info kernel: [ 206.630000] usb 1-1: new high-speed USB device number 5 using ehci-platform
Jan 1 00:03:27 OpenWrt kern.err kernel: [ 207.050000] usb 1-1: device not acce pting address 5, error -71
Jan 1 00:03:27 OpenWrt kern.err kernel: [ 207.050000] hub 1-0:1.0: unable to e numerate USB device on port 1
vovenarg писал(а):, если я хочу к нему по Ethernet подключить ардуину,
Что думаете делать с OR-WRT? почему вообще она не работает, если OpenWRT работает? Она же на ней основана?
Delirium писал(а):Мой logread:
root@OpenWrt:~# df -h
Filesystem Size Used Available Use% Mounted on
rootfs 476.8M 22.2M 454.6M 5% /
/dev/root 2.3M 2.3M 0 100% /rom
tmpfs 14.2M 80.0K 14.2M 1% /tmp
tmpfs 512.0K 0 512.0K 0% /dev
/dev/sda 476.8M 22.2M 454.6M 5% /overlay
overlayfs:/overlay 476.8M 22.2M 454.6M 5% /
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 3.03
S: Manufacturer=Linux 3.3.8 ehci_hcd
S: Product=Generic Platform EHCI Controller
S: SerialNumber=ehci-platform
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=125f ProdID=d00a Rev= 1.00
S: Manufacturer=A-DATA
S: Product=A-DATA USB Flash Drive
S: SerialNumber=ae45edf72615f5
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr= 98mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=125us
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=83(I) Atr=03(Int.) MxPS= 64 Ivl=16ms
