UART и WinAVR
UART и WinAVR
Сообщение Олег » 30 окт 2006, 17:23
Как в WinAVR рабоать с UART?
В документации на WinAVR нашел:
Defines
#define  FILE   struct __file
#define  stdin   (__iob[0])
#define  stdout   (__iob[1])
#define  stderr   (__iob[2])
#define  EOF   (-1)
#define  putc(__c, __stream)   fputc(__c, __stream)
#define  putchar(__c)   fputc(__c, stdout)
#define  getc(__stream)   fgetc(__stream)
#define  getchar()   fgetc(stdin)
Functions
int  fclose (FILE *__stream)
int  vfprintf (FILE *__stream, const char *__fmt, va_list __ap)
int  vfprintf_P (FILE *__stream, const char *__fmt, va_list __ap)
int  fputc (int __c, FILE *__stream)
int  printf (const char *__fmt,...)
int  printf_P (const char *__fmt,...)
int  sprintf (char *__s, const char *__fmt,...)
int  sprintf_P (char *__s, const char *__fmt,...)
int  snprintf (char *__s, size_t __n, const char *__fmt,...)
int  snprintf_P (char *__s, size_t __n, const char *__fmt,...)
int  vsprintf (char *__s, const char *__fmt, va_list ap)
int  vsprintf_P (char *__s, const char *__fmt, va_list ap)
int  vsnprintf (char *__s, size_t __n, const char *__fmt, va_list ap)
int  vsnprintf_P (char *__s, size_t __n, const char *__fmt, va_list ap)
int  fprintf (FILE *__stream, const char *__fmt,...)
int  fprintf_P (FILE *__stream, const char *__fmt,...)
int  fputs (const char *__str, FILE *__stream)
int  fputs_P (const char *__str, FILE *__stream)
int  puts (const char *__str)
int  puts_P (const char *__str)
size_t  fwrite (const void *__ptr, size_t __size, size_t __nmemb, FILE *__stream)
int  fgetc (FILE *__stream)
int  ungetc (int __c, FILE *__stream)
char *  fgets (char *__str, int __size, FILE *__stream)
char *  gets (char *__str)
size_t  fread (void *__ptr, size_t __size, size_t __nmemb, FILE *__stream)
void  clearerr (FILE *__stream)
int  feof (FILE *__stream)
int  ferror (FILE *__stream)
int  vfscanf (FILE *__stream, const char *__fmt, va_list __ap)
int  vfscanf_P (FILE *__stream, const char *__fmt, va_list __ap)
int  fscanf (FILE *__stream, const char *__fmt,...)
int  fscanf_P (FILE *__stream, const char *__fmt,...)
int  scanf (const char *__fmt,...)
int  scanf_P (const char *__fmt,...)
int  sscanf (const char *__buf, const char *__fmt,...)
int  sscanf_P (const char *__buf, const char *__fmt,...)
FILE *  fdevopen (int(*put)(char), int(*get)(void), int opts __attribute__((unused)))
может кто-то знает, когда какая из этих функций используется? :?:
Олег
Сообщение avr123.nm.ru » 30 окт 2006, 20:52
я написал о USART в задаче-упражнении 5  -  avr123.nm.ru/z5.htm
еще там посмотрите:
http://hubbard.engr.scu.edu/embedded/avr/avrlib
Сообщение Олег » 30 окт 2006, 23:44
В задаче 5 рассказывается на прмере CodeVisionAVR.
В CodeVisionAVR программа получается раза в два больше чем на WinAVR.
Может есть какой-нибудь пример UART на WinAVR? :?:
Олег
Сообщение aesok » 31 окт 2006, 00:58
Олег писал(а):Может есть какой-нибудь пример UART на WinAVR? :?:
Посмотрите на своем диске:
X:\WinAVR\doc\examples\largedemo
Если будут вопросы, или у вас старая версия WinAVR, пишите отвечю.
Анатолий.
aesok
Сообщение avr123.nm.ru » 31 окт 2006, 03:50
Ну тады снова : ПАФТАРЯЮ
еще там посмотрите:
Сообщение Олег » 31 окт 2006, 11:10
Анатолий.
Наверное у меня старая версия WinAVR, у меня такого примера нет. Если не трудно выложите этот пример на форуме.
Олег
Сообщение Олег » 31 окт 2006, 11:16
еще там посмотрите:
Это интересная вещь, но я не могу разобраться как это все дело подключить к WinAVR? :?:
Олег
Сообщение avr123.nm.ru » 31 окт 2006, 12:48
у меня он в папке - C:\WinAVR\examples\largedemo
Сообщение avr123.nm.ru » 31 окт 2006, 12:49
советую свежий WinAVR скачать и с VMLAB использовать.
Сообщение Олег » 31 окт 2006, 14:21
Как в WinAVR посмотреть объем полученной программы? :?:
Какую  программу можно использовать вместо VMLAB, но чтобы она поддерживала ATTiny2313? :?:
Олег
Сообщение avr123.nm.ru » 31 окт 2006, 14:49
AVR Stusio  (45 + 22  Мб)  atmel.ru  soft
Сообщение Олег » 31 окт 2006, 15:35
Чем эта функция:
* Send a C (NUL-terminated) string down the UART Tx.
void printstr(const char *s)
 while (*s)
     if (*s == '\n')
   putchr('\r');
     putchr(*s++);
отличается от этой:
* Same as above, but the string is located in program memory,
* so "lpm" instructions are needed to fetch it.
void printstr_p(const char *s)
 char c;
 for (c = pgm_read_byte(s); c; ++s, c = pgm_read_byte(s))
     if (c == '\n')
   putchr('\r');
     putchr(c);
Олег
Сообщение Myp » 31 окт 2006, 17:54
така же как предидущая, but the string is located in program memory, so "lpm" instructions are needed to fetch it.
Сообщение aesok » 31 окт 2006, 19:36
Анатолий.
Я рекомендую вам установить новую версию WinAVR, которая вышла весной. Ваша версия avr-libc 1.2.x при работе с файлами использует днамическое вделение памяти (функция malloc) в функции открытия файлов, а это дополнительно  около 500 инструкций кода.  avr-libc 1.4.x не использует malloc для функций ввода вывода.
Для использовния нужно:
1. Фнукця которая выводит в поток 1 сомвол.
int
uart_putchar(char c, FILE *stream)
 if (c == '\n')
   uart_putchar('\r', stream);
 loop_until_bit_is_set(UCSRA, UDRE);
 UDR = c;
 return 0;
2. Далее в "main", для avr-libc 1.2:
    usart_init();
    fdevopen(&uart_putchar, NULL, 0);
   printf("\r\nHello\r\n");
для avr-libc 1.4:
FILE uart_str = FDEV_SETUP_STREAM(uart_putchar, NULL, _FDEV_SETUP_W);
main()
   usart_init();
   stdout = &uart_str;
Анатолий.
PS: Я ошибся, правильное название примера "stdiodemo".
PSS: Уточните вопрос, Вас интнрисует "работа с UART" или "работа с UART c помощю стандартных функций ввода вывода"?
aesok
Сообщение Олег » 31 окт 2006, 20:42
Меня интересует вообще работа с UART.
А именно как вывести через UART константу находящуюся во Flash памяти и как получить через UART какое-нибудь слово, а потом сравнить его с имеющимися. :?:
Олег
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 19
