AT90USBxxx parts can operate both as USB device or USB host, accurately in host mode
AT90USBxxx operates as reduced host controller. A reduced host controller has a unique USB
port and does not handle full USB tree with hub. It means that a reduced host controller is
designed to handle a unique point to point connection with a unique USB device. A reduced host
application supports a known targeted device list (VID/PID list). Only the devices listed within
this list are supported by the application. In addition the AT90USBxxx USB software library is
able to support a targeted list of CLASS/SUBCLASS/PROTOCOL.
к561ЛА7 писал(а):Запускаю таймер в тексте программы,
КАк можно по его завершению чего нибудь сделать без прерываний?
while (TCNT0<255); // подождать пока насчитает 255
PORTC.0 = 1; // включить светодиод
statistic писал(а):то к561ЛА7 вставте условие хотя бы в бесконечный цикл.
Если вы пытаетесь добиться частоты, то это аппаратно можно сделать.У вас какой контроллер?
